Author Topic: HOW TO copy MD2202-D16 memory onto another  (Read 3102 times)
Offline UnnitTopic starter
« on: January 24, 2021, 06:34:15 pm »
Hi, I am a true amator when we talk about this subject, I didn't reach this era of old computing and is a bit strange for me to understand how to address this kind of technology (for instance parallel memory), but I want to know if it is possible because I have a sewing machine and this chip is making me a lot of trouble. I need TO COPY this memory onto another similar one and I bought two of this memories but I struggled to find on the internet how to copy them and nothing heped me. Can anyone tell me a technique or a programmer and some software for it?
When I bought the memory my first attempt was to find a way to communicate with arduino, because is the cheapest solution that I have but I have also other tools on my hand like raspberry PI, serial programmers, an old PC that have serial port, parallel port.
Thank you.
https://www.aliexpress.com/item/32857010627.html?af=143650&utm_campaign=143650&aff_platform=portals-tool&utm_medium=cpa&afref=https%3A%2F%2Fwww.google.com%2F&dp=650c646e813b20ad93222653b57876d7&cv=47843&aff_fsk=_ePNSNV&mall_affr=pr3&sk=_ePNSNV&aff_trace_key=ca84b0133f97449983ec371336ec8ff2-1611513208531-09149-_ePNSNV&terminal_id=25631957ebb145d4b00dab831392d7db&tmLog=new_Detail&utm_source=admitad&utm_content=47843
https://www.digchip.com/datasheets/parts/datasheet/1761/MD2202-D16-X-pdf.php
Offline Rasz
    • My random blog.
Re: HOW TO copy MD2202-D16 memory onto another
« Reply #1 on: January 24, 2021, 07:54:22 pm »
You cant just read it in any external reader.
https://en.wikipedia.org/wiki/M-Systems DiskonChip are the real precursor to SSDs. Afaik they run flash translation layer on the main cpu thru bios extension loading trueFFS driver.
>BIOS then loads the TrueFFS software from the flash memory into the host memory, delivering full disk capabilities to the operating system.
most likely you will need to plonk it into a pc motherboard, let it load its driver, and then copy like a normal disk
model? whats inside? what software is it running? what architecture? can you take a picture of the board module is plugged into?
Offline sequoia
« Reply #2 on: January 24, 2021, 09:16:37 pm »
A treasure trove of information on DiskOnChip (DOC) devices can be found here:
http://www.digital-circuitry.com/MyLAB_IC_PROG_DISKONCHIP.htm
Easiest way to copy these (without custom software and/or hardware) would be to find computer with a DOC socket.  After BIOS (in the DOC device itself) loads it should appear as a regular 'disk' to the system (MS-DOS, etc...), so could be copied with any software that can read/write raw disk images...
Offline sequoia
« Reply #3 on: January 24, 2021, 09:24:48 pm »
Note, that there is the 'traditional' 5V versions of these and somewhat more rare 3.3V versions (these have -V3 suffix in the model/part number if I recall correctly).   So make sure replacement chip is matching voltage (plugging a 3.3V chip on 5V socket won't work...)
Offline Ijaz
  • Country: pk
« Reply #4 on: February 20, 2021, 08:34:06 am »
If you have an ISA slot PC, then you can construct a simple interface where you can use this DOC as a Hard drive in the PC and just copy, paste or format it like you do in DOS.
Another very similar design can be found here:
https://easyeda.com/atcurtis/isa-diskonchip-low-profile
« Last Edit: February 20, 2021, 08:39:32 am by Ijaz »
