I wanted to continue/finish-off the conversations(s), from the original thread. So, since (as mentioned), you have moved it here. I decided to continue it here. So, from the other/original thread (Bold emphasis added by me):
Yes, I am ok with anyone using links, to the abandoned patent application seen above. Any further details, on the binary computer I think best if I soon start a separate POST probably in the vintage computer topics section. In principal, the steel ball and moving paddle constituted a BASE ONE math operation: The moving ball as a 'mass impulse' means, with positional encoding... Thus the moving (falling) ball embodies an inherent self-clock.
I had, subsequently, moved up the organizational chain, after filing that jumbo patent. Look for a post later, probably in VINTAGE COMPUTER topics. The decimal system is where the 'cool' sh*t' really gets rolling. I think I can put together an essay on the 10 digit 'RAM' block, of approx size of a basket ball.
You could run decent code using 100 digits of RAM storage. Both system types are physically BASE ONE, I swear! (Hint: Binary or Decimal systems build the BASE up by concatenating base-one impulses using dedicated 'positional encoding'.
- RJHayward
"constituted a BASE ONE math operation:"I would suggest, it is still a BASE 2 device. But, the concept of these BASE ONE devices, does exist in electronics, and is used. Let me explain.
A normal output on a modern (CMOS) gate (e.g. NAND), can go to (almost) the full supply rail swing. E.g. +3.3 V or Ground (0 V), for binary logic levels, 1 and 0, respectively.
But there are other types of outputs, called open-collector (open-drain these days), or tri-state.
These types, as well as being able to go to logic 0 and 1 (when a suitable resistor to the positive rail, is connected, in the case of the open collector/drain types), can go into an off/inactive/open state.
In the case of tri-state outputs, it is when the output enable (may be called something else), deactivates the outputs, and puts them into the tri-state/input/open/hi-z state. In the case of microcontrollers, this is usually when the port output direction register, is set into a bit pattern, that makes them go high impedance (naming schemes can differ).
So, what I am trying to say is, that those devices, have a BASE ONE like mode, whereby they are off/inactive/high-impedance. Which allows other devices to control the (if there are many related pins, often called a) bus.
In the case of open collector/drain, it can be used to make a wired-OR (or in a different configuration, not discussed here, wired-AND).
So, it is a binary (Base two system), which can be put into (or left in), a BASE ONE state, if you want. But, really (while it is working/computing), it represents a BASE TWO (binary) system.
tl;dr
Overall it is a binary system, because it has two possible states. Even though, some of the time (because the balls are elsewhere, or it is full of balls, at the moment), it may seem as if it is a base one system.
Analogy:
One might have an NE555 timer, which has been set to time for exactly ten minutes. So, once it is powered up and triggered. The output (connected to a lamp, LED or buzzer etc), is in the off state (logic 0).
So, for the next 10 minutes, you could (incorrectly, in my opinion), call it a BASE ONE system.
But (to prove me right), after the ten minutes is up, the output will change (to on, logic 1), the lamp/buzzer will turn on, illustrating the fact, that it was indeed a binary (base two) system. Since it has now moved to the other state.
Until either the power is switched off, or it is restarted, and will be off, for another ten minutes.
