I guess you'll need to install MSDOS in the VM first
See above, I have already done just that 2 hours ago !
This part works...
and then run the Orcad installer.
Yes, that's what I am now trying to do, but I need disk images for that... the VM won't take directories as an input (not that I can see anyway), only disk images.
However, I think Orcad should run OK on WinXP or even Windows7 in a DOS box.
Yes but my Vintage computer is not "available" at the moment, so to speak... so for now I am trying to get it to work in a VM on my main / Linux computer, hence I need to be able to make disk images.
Am still Googling for that... one day maybe I will find the answer...
I think I will just end up buying a cheap USB floppy drive and write the install disks on actual floppies (I have dozens of them, maybe soe of them are still good/usable, who knows...), then I can get the VL to use the actual floppy drive rather than an image file...
I meant to buy a USB floppy drive anyway, for other purposes, like using on old Tektronix TDS scopes, or my messing around with vintage computer in general.
