Author Topic: Old keyboard with DB9 connector ?  (Read 6375 times)
Offline BravoVTopic starter
  • +++ ATH1
« on: October 16, 2019, 04:14:13 am »
I've been offered for free a NOS German made Cherry keyboard that use DB9 connector.
Is that a serial type keyboard ?
Also is there any converter/adapter so it can be used at PC say like PS/2 one or even better USB.
Offline aix
  • +++ ATH1
Re: Old keyboard with DB9 connector ?
« Reply #2 on: October 16, 2019, 04:45:03 am »
Its DB9 , not DIN5.
Offline james_s
« Reply #3 on: October 16, 2019, 04:47:33 am »
It's probably some proprietary thing. The interface is going to be some form of serial but probably not RS232. If you open it up and take a look it should be trivial to reverse engineer the hardware portion.
  • +++ ATH1
« Reply #4 on: October 16, 2019, 04:52:34 am »
That is what I'm worrying about, as may be it needs too much effort (hack/mod etc) to be used at PC, even just converting it into PS/2, not USB.
I don't have it with me yet, as I need to pay for the s/h cost.
Offline AG6QR
    • AG6QR Blog
« Reply #5 on: October 16, 2019, 05:14:33 am »
Its DB9 , not DIN5.
Are you sure it isn't DE-9?
I have never seen a nine pin connector in a DB sized shell.  I have seen thousands of DE-9 connectors, and heard them mistakenly called DB-9 many times.  But the only DB sized connectors I have seen in use were DB-25 or DB-13W3 units.
The following users thanked this post: Tom45
  • +++ ATH1
« Reply #6 on: October 16, 2019, 05:21:46 am »
Its DB9 , not DIN5.
Ok, I could be wrong calling it DB9, could be DE-9.
For sure the owner mentioned its exactly like the PC's serial connector but not clear either its male or female, but not DB25, and definitely not DIN or PS/2.
Offline james_s
« Reply #7 on: October 16, 2019, 05:57:50 am »
While technically true, I would say that is extremely pedantic. Everybody knows that the common 9 pin serial connectors are colloquially called "DB-9". At this point I think that about the only people who know what a DE-9 connector is are those who like to nitpick and show how smart they are, or people old enough to have worked with them in the late 60s-early 70s when D-shell connectors were new and cutting edge.
The following users thanked this post: dexters_lab, BravoV, rsjsouza, tooki
Offline dexters_lab
« Reply #8 on: October 17, 2019, 05:30:52 pm »
any pics?
Quantel made extensive use of de-9/db-9 on their keyboards for two decades
Offline MosherIV
« Reply #9 on: October 18, 2019, 07:17:06 am »
Early Sun workstations used 9w15w D type connectors for their keyboards.
They are distinctive compared to pc keyboards
http://blog.daveastels.com.s3-website-us-west-2.amazonaws.com/2014/12/27/type-3-keyboard.html
Edit: oops, just noticed in pics that it is actually 15w  :-[
I have seen keyboards with 9w D type at The Nation Museum of Computing, not sure what computers they are for though.
« Last Edit: October 18, 2019, 07:20:43 am by MosherIV »
  • +++ ATH1
« Reply #10 on: October 18, 2019, 09:16:37 am »
any pics?
Just got update from the owner, its a Cherry brand keyboard OEM-ed to API (Advanced Program Inc.) that produces/manufactures TEMPEST product.  :o  -> http://www.advprograms.com/
And for unknown reason, the original USB connector has been replaced with an AMP brand heavy metal cast DB-9 connector (as below left example) but with only 4 pins , not full 9 of them, and its on its way.
Going to convert it back to ordinary USB.  ::)
« Last Edit: October 18, 2019, 09:18:17 am by BravoV »
The following users thanked this post: I wanted a rude username
Offline ebastler
« Reply #11 on: October 18, 2019, 10:00:09 am »
That's too easy... And disappointingly non-vintage.  ;)
Any idea how old that keyboard actually is?
Offline SiliconWizard
« Reply #12 on: October 18, 2019, 02:55:40 pm »
It's probably much more rugged than an ordinary USB connector. And there's no locking mechanism with ordinary USB. That may be required for some work environments.
Offline james_s
« Reply #13 on: October 18, 2019, 03:18:40 pm »
TEMPEST is all about shielding, the metal shell DB9 is probably better shielded than a standard USB connector.
  • +++ ATH1
« Reply #14 on: October 19, 2019, 03:12:33 am »
Yeah, abit of disappointment.
Its probably aroud 15 years maybe as the owner mentioned.
  • +++ ATH1
« Reply #15 on: October 19, 2019, 03:14:35 am »
The keyboard's cable was somehow (not sure) replaced with non spiral one, just straight grayish colored.
Will post the connector photo once its in my hand.
  • +++ ATH1
« Reply #16 on: October 19, 2019, 05:15:06 am »
Pic speaks thousands words ...  :P
Regarding the cable, I guess its fully shielded too and installed with ferrite EMI filter.
Online Ian.M
« Reply #17 on: October 19, 2019, 11:11:37 am »
Cable mount USB plugs are always a PITA to assemble (though admittedly a full sized  USB A plug is probably the easiest), and the result is often mechanically weak compared to a factory assembled moulded plug.  Its probably easiest to swap out the cable for one with  moulded  USB A plug, starting with a decent quality off-the-shelf cable and cutting off its device end plug for bare wire ends to patch into the keyboard.
Offline ebastler
« Reply #18 on: October 19, 2019, 12:03:06 pm »
So, how does the keyboard enclosure look from the inside? Any extra shielding in there?
Online mariush
« Reply #19 on: October 19, 2019, 02:38:48 pm »
You'd be better off buying a ready made cable and connect the cable inside the keyboard : https://www.digikey.com/short/pn1bv8
Depending on shipping costs, it may be actually cheaper to buy a 1-2$ mouse from a local store and take it apart to get the cable. ex: https://www.amazon.com/Verbatim-Optical-Mouse-Accessibility-Compatible/dp/B00LPC3O3M/ or https://www.amazon.com/Generic-3-Button-Optical-Notebook-Desktop/dp/B006B3PADC/
« Last Edit: October 19, 2019, 02:44:42 pm by mariush »
  • +++ ATH1
« Reply #20 on: October 20, 2019, 06:39:32 am »
From outside, its obvious plastic case, not metal.
Will post photos once I tear it down.
  • +++ ATH1
« Reply #21 on: October 20, 2019, 06:41:16 am »
Well, actually my plan is just salvage from old unused USB keyboard's cable, its much more easier and convenient.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #22 on: October 20, 2019, 08:40:40 pm »
I used to use those chunky D connectors all the time in the 70s and 80s.
They feel great and are rock solid, now everything is flimsy and built down for weight and price!
Don't ask a question if you aren't willing to listen to the answer.
Offline RetroSwim
« Reply #23 on: November 01, 2019, 05:18:25 am »
Same story with saying "RJ45" to mean 8P8C modular, I guess. The wrong name is so ingrained (and the actual Registered Jack standard is so old and disused) that it doesn't matter any more.
(Though I still get mildly annoyed when someone says "RJ45 cable"...  :P )
D-Sub is an interesting choice for USB though, since it doesn't have the staggered pin pattern to ensure ground makes contact before anything else, it would make hot-plugging somewhat hit-and-miss.
Good score though, OP! Let us know how it turns out!
« Last Edit: November 01, 2019, 05:39:32 am by RetroSwim »
Offline helius
« Reply #24 on: November 01, 2019, 06:41:40 am »
I see you have already identified the connector style (a TEMPEST conversion of a PC USB keyboard).
But there was (at least) one computer that used a DE-9 connector natively, the Silicon Graphics Personal IRIS 4D/20 and /25. These were only in production for a few years and earlier and later SGIs used other connector styles, but the keyboards do exist.
« Last Edit: November 01, 2019, 06:44:06 am by helius »
