I got an LCII with a hard drive inside.
As I wanted a second hard drive I decided to make an adaptor to connect my other SCSI drive to it's rear SCSI port.
If I start with the external HD connected it boots from the external Hd and the internal is not visible.
If I start with the internal HD and later connect the external HD the external does not mount.
Anything I should do such as setting the external as slave? Or come pinout on my adapter that I am missing?
