Author Topic: Pocket 386  (Read 521 times)
Offline djsbTopic starter
Pocket 386
« on: July 27, 2024, 08:30:54 pm »
Is there a better alternative to the Pocket 386 out there that uses an industrial 486 based SOC system? The Pocket 386 seems OK
but has its limitations. Here is a thread on the Vogons forum
https://www.vogons.org/viewtopic.php?t=99751
I'm tempted, but I'm waiting for further developments and improvements to be made. I'm thinking one of these would be useful for learning basic x86 assembly language and parallel port programming as well as ISA and GPIO interfacing.
What are your thoughts?
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Online ataradov
    • Personal site
Re: Pocket 386
« Reply #1 on: July 27, 2024, 10:25:26 pm »
For learning 86Box is way better. File transfer between old hardware is not well suited for fast iterations.
The only 486-based somewhat complete project I'm aware of is a weeCee. But I don't know if they are still available.
There are 486-based industrial PCs on Aliexpress, but the prices are not even close to reasonable.
« Last Edit: July 27, 2024, 11:06:24 pm by ataradov »
Alex
The following users thanked this post: djsb
Offline Postal2
  • Country: ru
Re: Pocket 386
« Reply #2 on: July 27, 2024, 10:57:07 pm »
.... What are your thoughts?
I recommend an Atom-based netbook (very cheap). You need to open it, remove the Wi-Fi and insert an adapter for the PCI bus. The ISA bus is useless, because there are software-compatible adapters for PCI. LPT is also available in a standard way, but in the PCI address space. If you need a standard 378 port, then you can take a mini-itx on Atom 230.
If you absolutely need ISA, then you need to get any cheap (or free) motherboard with such a connector.
Mini-itx links:
https://www.gigabyte.com/Motherboard/GA-GC230D-rev-10
https://www.intel.com/content/www/us/en/products/sku/42490/intel-desktop-board-d945gclf/specifications.html
For Intel GCLF, you will need to select a BIOS for correct operation of Windows 98, and the BIOS is not the latest or the first, but somewhere in the middle.
« Last Edit: July 27, 2024, 11:22:10 pm by Postal2 »
Re: Pocket 386
« Reply #3 on: July 28, 2024, 06:25:09 am »
Just bought a Pocket 386 with Windows 95 from the Tindie store. This review of it using the PicoGUS soundcard is what convinced me
I may post a review later on. Thanks.
Hertfordshire, UK
Offline Postal2
  • Country: ru
Re: Pocket 386
« Reply #4 on: July 28, 2024, 09:46:12 am »
Just bought a Pocket 386 with Windows 95 from the Tindie store. This review of it using the PicoGUS soundcard is what convinced me ....
Win 95 is hard for 386. You can use Audigi at PCI-slot, you probably haven't seen or heard how it works.
