Author Topic: How can I get info on vintage push button switches?  (Read 2886 times)
Offline colejohnson66Topic starter
« on: October 23, 2021, 04:40:06 pm »
In EEVblog #1258, at 13:23 (https://youtu.be/AkMF_v_vNoE?list=TLPQMjMxMDIwMjE9WADSlfhGbA&t=803), there are some blue push button switches. I've seen these things in a lot of his vintage teardowns, and I can't find anything about them. Is there a name for them?
Offline ataradov
    • Personal site
Re: How can I get info on vintage push button switches?
« Reply #1 on: October 23, 2021, 05:20:29 pm »
I'm not sure who made those in the western world, but the Soviet version was called П2К (P2K) and those are some of the most versatile switches I've seen in my life.
I think they are generically called modular push button switches. Searching for that finds a very limited number of modern suppliers of not exactly the same thing, but a more modern versions:
http://www.intechswitch.com/products/UniDirectionpushbuttonswitchseries/
https://www.globalsources.com/si/AS/Yueqing-Anhe/6008852430878/pdtl/Push-Button-Switch/1172158874.htm
https://www.ebay.com/itm/Interlock-Push-Button-Switch-Piano-Type-4PDT-12-Pin-4-Row-/233167882483
I can't find the original version anywhere. It is even hard to find replacements for the Soviet ones, which is rare.
« Last Edit: October 23, 2021, 05:22:31 pm by ataradov »
Alex
The following users thanked this post: colejohnson66
Offline Benta
« Reply #2 on: October 23, 2021, 07:07:18 pm »
They were originally made by ITT/Schadow, which was then bought by C&K.
Still available, you basically put your own kit together (LEGO-style): switches, buttons, U-profile for mounting, release springs etc.
Product name is C&K F-Series pushbutton switches. I attach a data sheet:
https://www.ckswitches.com/media/1402/fpush.pdf
Cheers.
