Well, the images posted at:
https://www.eevblog.com/forum/testgear/yet-another-cheap-thermal-imager-incoming/msg545910/#msg545910are all 8/24bit rgb which do not contain all the data from the camera.
Attached are 16bit .png of frames 1-9 from my camera.
Frame 1 ID 4, Frame 5 ID 10, Frame 3 ID 8, Frame 4 ID 7 look to me like they might be sensor calibration data unique to each sensor, they "resemble" both the data frames ID 3 and the "calibration" frames ID 1 (for some definitions of " resemble")
Frame 2 ID 9 is a "gradient", the only pixels different from the gradient are # 1 and # 10 (not counting the big white patch (value 15464) in the middle.
Frame 6 ID 5 is half black and half something else, I couldn't begin to guess what it is for.
Frame 7 ID 1 is the first calibration frame, (assuming that is what ID 1 really means)
Frame 8 ID 3 is the first data frame, (there are a lot more of them than any other ID so it is logical to assume that's what they are)
Frame 9 ID 6 is the first "pre-calibration" frame, (since it occurs right before the ID 1 calibration frame (as to what is used for I'm clueless)
The Seek application produces images that are free of banding which can be clearly seen in my as well as other non-seek images.
Seek knows how to remove that banding, so I think that they may be doing something with frames 1,3,5,4. Why then would those frames be produced at the beginning of each camera initialization, and never produced again. (I should look to see if those frames are identical each time the camera is initialized.... maybe tomorrow)
Looking at Frames 5,1,3,4 I see max values of 170, 4258, 9606 and 15675. I see min values or 0 for all these frames, but since they include the "patent pixels" and maybe some dead pixels, that is understandable. I will look at removing the zero values to see if that casts any light on the range of these frames.
I think eneuro has already done this to some of the raw USB data dumps, so i may be repeating some research, but it may help my little pea brain comprehend what's going on.
...ken...
These images below may look black, but they aren't. View them with something that can read 16bit .png files.
