Author Topic: Yet another cheap thermal imager incoming.. Seek Thermal  (Read 1055511 times)
Offline waldo
Re: Yet another cheap thermal imager incoming.. Seek Thermal
« Reply #575 on: October 31, 2014, 03:02:43 pm »
Apple currently refuses connections to Bluetooth devices that lack their authentication chip.  But when Bluetooth low energy came out, Apple decided not to restrict access to BLE devices, so there may be hope for them yet.
Offline IanB
« Reply #576 on: October 31, 2014, 04:37:29 pm »
What does this mean? I have been able to pair a generic Bluetooth keyboard with my iDevices and it works fine.
Offline miguelvp
« Reply #577 on: October 31, 2014, 05:03:38 pm »
I think the restriction is that iOS requires Bluetooth LE (low energy)
Also it has had problems on one of the recent updates, but I don't think they will change the compatibility.
    • Mike's Electric Stuff
« Reply #578 on: October 31, 2014, 05:04:45 pm »
I believe keyboards are about the only generic, non Apple-taxed thing they will pair with.
Day Job: Mostly LEDs
Offline iRad
  • Are you sure it's safe?
« Reply #579 on: October 31, 2014, 05:12:07 pm »
What does that have to do with the Seek Thermal camera for iOS? It is not a Blue Tooth device. AND, it evidently has the authentication chip.
Offline NsyncSys
« Reply #580 on: October 31, 2014, 07:06:39 pm »
Hey folks.  I got my camera a couple of weeks ago - I was order # 1100 or so.
I was looking for answers to some of the very issues you folks are discussing - glad I found you!
My major complaints that I hope Seek addresses are mostly software, but here they are:
1 - Thermal gradient issue
2 - inability to turn off auto-scaling in the thermal mapping - moving the camera can result in a wild shifting of colors.
3 - Poor display definition - with a built in visible light camera it would be easy to boost the apparent definition.  For example perform edge detection on the visible light and apply as an alpha channel to the IR display.
4 - Poor display contrast - this is seriously easy stuff to bump the contrast so details can be distinguished.
5 - Software does not remember user settings - it asks every single time to associate the camera with the software.
6 - Inability to use for advertised abilities such as stud finding.  Mine will not even pick up the thermal gradients where I *know* the wires run warm, nor the embedded hot water pipes in the foundation that I can feel with bare feet.  The demo pic of footprints in the carpet or bare floor are myth as far as I can tell.  I can see where the cat has been snoozing on the couch.  I'm quite sure addressing issues 2-5 would help here.
PS: Thanks for the software - I'll be rigging a cable this weekend to play.
Jon
« Reply #581 on: October 31, 2014, 07:12:17 pm »
Flir have a patent on that. there is also the issue of different positions and fields of view of cams on different phones. maybe someone will write an app for it though
I suspect this is a deliberate tactic to hide noise.
« Last Edit: October 31, 2014, 07:13:56 pm by mikeselectricstuff »
Offline eneuro
« Reply #582 on: October 31, 2014, 08:24:58 pm »
Apple is probably the most proprietary-centric consumer product manufacturer out there.
Anyway, may be better if Seek Thermal will leave them alone with their greatness if they do not want to be involved in similar lawsuits and release PC version with drivers for Linux, Window$, etc  for price <$100 :-DD
Apple and GTAT: What went wrong - update
"GTAT is prohibited from modifying any equipment, specifications, manufacturing process or materials without Apple’s prior consent. Apple can modify any of these terms at any time and GTAT must immediately implement Apple’s modifications."
Apple? No thanks  :rant:
« Last Edit: October 31, 2014, 08:30:11 pm by eneuro »
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine”  - Nikola Tesla
Offline marshallh
    • retroactive
« Reply #583 on: October 31, 2014, 08:43:23 pm »
order # 30xx received!
Verilog tips
BGA soldering intro
Offline datsthat
« Reply #584 on: October 31, 2014, 08:49:52 pm »
I found this vid comparing Seek with Therm-app.  sorry if this is a not so smart question to ask as I don't have much thermal background (or anything else :palm:)  With future software revisions, does anybody think its posbile for seek to look similar to therm app?
http://youtu.be/5FvVJE-qLhw
Don't forget about Karma
Offline marshallh
    • retroactive
« Reply #585 on: October 31, 2014, 08:53:27 pm »
Not a chance... Seek sensor is so small it can't resolve finer details, even though its resolution is much great than the FLIR one.
Therm-app has a much bigger sensor, hence the expense. Opgal have no doubt ported their existing proven processing code isntead of having to write new code from the ground up like Seek.
Verilog tips
BGA soldering intro
« Reply #586 on: October 31, 2014, 09:05:57 pm »
Ther therm-app lens alone probably costs more than the Seek
Offline efahrenholz
« Reply #587 on: October 31, 2014, 09:23:36 pm »
My camera finally arrived today. I definitely am plagued by the gradient issue as everyone else is. I noticed something interesting though, it seems to be thermally related. Cold out of the box it had no gradient. As it warmed up, a gradient began to show itself, so I placed the imager in the freezer. Gradient went down, even the noise level decreased as expected.
How about this, is it possible the gradient we see is coming from side radiation of the lens housing? Maybe it is picking it up off the PCB? I also wanted to point out the gradient appears from the side where the housing is thinnest...strange thermal characteristic?
Offline datsthat
« Reply #588 on: October 31, 2014, 09:58:21 pm »
gradient on mine is always hotter bottom right hand
« Reply #589 on: October 31, 2014, 10:09:57 pm »
An update, I've just discovered that if I use the direct url for the Thermal App I can install it from New Zealand, even though a search on Google Play won't show it.
Direct url :https://play.google.com/store/apps/details?id=com.tyriansystems.SeekThermal&hl=en&rdid=com.tyriansystems.SeekThermal
Didn't work for me - after the "please login to download" prompt I get "Page not found"
Offline waldo
« Reply #590 on: October 31, 2014, 10:23:11 pm »
Does APK Downloader help in those situations?
http://apps.evozi.com/apk-downloader/
Offline Fraser
« Reply #591 on: October 31, 2014, 11:35:57 pm »
@Mike, URL works OK from my Moto G but no camera found for download. Not sure if you need the Seek plugged in to install ?  My Seek has just arrived at its USA destinatiom so hopefully not long until I can test it.
Offline efahrenholz
« Reply #592 on: November 01, 2014, 02:57:18 am »
Here's a thermie of my cat. Really shows the detail the camera can achieve.
Offline Hyperion
« Reply #593 on: November 01, 2014, 04:59:11 am »
I used the site discussed below to get the apk and then used ApkInstall app to install it (not apkInstall which is a different one) or you can side-install with the other methods.
http://forum.xda-developers.com/showthread.php?t=2636539
OF course there is some question about the security of using a site that downloads an apk for you: in theory they could add something malicious to it, but I haven't found any cases of this by googling this specific site, and my downloaded apk seems to be fine. Also it seemed that at first the download would not work but eventually it does if you retry enough: either site problems or you need to wait for the site to cache it on their end before it will process the link correctly.
(Trying to make a "fake" USA based account or modifying your preferences / clearing caches to try and trick Play Store into working in your country is a WASTE OF TIME and the new Google Play Store versions have defeated all the old "tricks" you will read about in blogs/forums and see in youtube videos).
« Last Edit: November 01, 2014, 05:02:50 am by Hyperion »
Offline Hyperion
« Reply #594 on: November 01, 2014, 05:01:59 am »
The box packaging says to install the app before connecting the camera. (The camera app will auto-launch on most phones when it's plugged in). If the Play Store says it's not available it's because you are outside USA/Canada and/or your device is not compatible with the software.
Offline Marco
« Reply #595 on: November 01, 2014, 06:11:21 am »
There's a patent on round corners (and weels for that matter). If you worry about patents this incredibly weak then you can forget about producing anything ever. A moment of careful consideration will tell you that the military significance of sensor fusion means this kind of very basic stuff is too well travelled for patents to be relevant.
« Last Edit: November 01, 2014, 06:14:46 am by Marco »
« Reply #596 on: November 01, 2014, 09:51:04 am »
No - the app can be installed, and run in demo mode without the camera, at least when installing from a .apk file
Offline amyk
Offline Hyperion
« Reply #598 on: November 01, 2014, 11:20:11 am »
That doesn't look quite right unless it's an inverted palette... the eyes should be much hotter:
http://traveldave.com/wp-content/uploads/2010/02/thermalcat2_sm.jpg
https://athermallife.files.wordpress.com/2012/02/cat.jpg
http://cnet1.cbsistatic.com/hub/i/2014/01/07/7d42182c-8533-11e3-bc97-14feb5ca9861/208f1d19dc978f193aaa148996f169d7/flirone.jpg
That is the "Black" pallet. Which is the inverse of "White".
In "black" hottest objects are darkest, so the cat looks as expected. I still think "Tyrian" is my favorite.
Offline jaybeez
« Reply #599 on: November 01, 2014, 12:36:49 pm »
Hi Everybody,
I've been following the discussion here for several weeks. All of you are great. I heard about the Seek on the night vision forum I frequent, but discussion and interest there seems to have fizzled out.
efahrenholz,
those cat photos look excellent. did you wait until just after a shutter event to take the snap shot? there is very little noise in your photo, compared to others I have seen. maybe an option to force a shutter event when taking a snapshot would be a good improvement to the app?
