Didn't get to do much but I'm going to release the current version, I think it's stable enough. Note, I did upgrade my compiler to Visual Studio Community 2013 because it's free and I have the project under source control using the free 25 seat perforce, hopefully it doesn't cause much trouble compiling it with visual studio express.
link to post about VS Community 2013:
https://www.eevblog.com/forum/chat/visual-studio-community-2013-a-full-featured-ide-free/msg550822/#msg550822Don't try to use the sliders on a win8 tablet, it's a nightmare to use, tried on mi wife's (well, now mine) dell venue 8 pro tablet.
As for bad images etc, maybe mine is a better camera, I went around the house taking pictures so it took me more than 2 minutes and it was working ok for my needs (checking cold spots around the house)
Also I took one of the radiator and it was spot on compared to a UNI-T UT301C IR thermometer, then one of the soldering Iron and it reads lower than the 350c I had it set at, then again it's a tenma so expected. The UNI-T couldn't get a good reading even if I had it set to 0.7 emissivity.
I'll post the images later,
Full compiled executable of attached source is at: (windows 7 and up)
www.miguelvp.com/ForMike/SeekAs is without trying to use an external reference (which it doesn't work as well as before using frame 1, sorry about that) 15000 is about 0 degrees celsius and 22208 is about 163 celsius. Not sure if it's linear didn't experiment enough.
Edit: another data point, 52C is 17226, so I get:
(22208 - 15000) is to 163
like:
(17226 - 15000) is to X
X = (2226 * 163) / 7208 = 50.338 kind of close
Then again the 0 Celsius where ice cubes coming out of the freezer, will measure it with the IR thermometer
I did and they are lower than -10C, but I don't know how long I had them out, but it looks linear enough with just 3 data points.
One more:
16561 is 36.4 C
With the above ratio I get: 35.3 C
Edit: and one more:
26500 is 260 C
With the above ratio I get: 260.06 C, so it does ok at high temps
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Math: (( 26539 - 15000) * 163) / 7208 = 260.940 C, Ok shouldn't have round down, but still pretty close.
Attached picture of the 260C halogen overhead lamp that the UNI-T says it's 260C
