@Seek,
If you still read the thread, do you have any plans to work on the pixel drift compensation? It works as advertised, but it needs refinement. It heavily affects any scene lower than the sensors temperature. I was getting horrible noise. Surely this isn't read noise? Perhaps you would implement a quality mode, low quality being 4 frames averaged, medium being 8 and high being 16. I'm sure a lot of people could give up the refresh for finer quality. Even at 16, it's still about 2.5 fps. I would believe 8 would be a happy middle for most people. That would help eliminate a lot of drift noise, while still providing a useful framerate. It might even be useful to capture a NUC of the same number of frames, so in medium quality mode, a NUC frame should be 8 averaged frames. I think this would allow your product to compete with the smoother image the new flir one will produce.
