Don't care; I'm having fun.
It is more fun with 16bit thermal LUT tables like this
iron -those Seek images looks very noisy and since there is no sharp edges maybe it is better smooth flat areas a little bit while image looks much better and applying 16bit thermal LUTs makes those images more friendly to human eye, so it should be option in Seek software to adjust smooth and noise reduction levels manualy when needed as I've did in my thermal interface
Anyway it is interesting why Seek do not provide for the moment any thermal LUT scale like in Flir's cameras, while it is a must to have feature in such software
Will see when Seek will add this to his official app-can't understand why it is not already done.
Today implementing such thermal interface OSD, to be able adjust thermal LUT temperature ranges and center pointer cursors, so looking for any good Flir's or SKF'a user manuals to see how it is already done and improve it.
BTW: Jpeg 100% quality and PNG compression level 9 with 16bit LUTs looks no so bad, so quick switch between those JPG100/PNG9/GRAY16bit output images seams to be quite usefull save feature and should be fine for the moment to play with this dongle and publish thermal images taken from this device including video recording in 16bit LUT RGB mode.
Edit: Those
SKF TKTI 21 & 31 users manual has realy nice detailed menu options explained
For example it has a few cursors with different emissivity setting for more accurate temperature readings which is a feature what we must to have in our custom Seek Thermal interface
Nice sharp thermal images from this SKF TKTI 160x120 (FPA) thermal camera and powerfull PC software for analysis
