Can you measure your cameras ?
Get an analogue video feed out onto a scope, display a good dozen frames, wave a soldering iron in front while it calibrates, and see how many frozen fields you get.
Argus4 cameras are 14 fields
I'd like to but first I'd have to know what you talking about
![Embarrassed :-[](https://www.eevblog.com/forum/Smileys/default/embarrassed.gif)
what do you mean by "fields"?
I just timed it every time the cam calibrates it takes about 1.5 seconds (so 1.5 fields if that's what you meant). I dont even need vast temp differences I switched from my hand to the window (it's relatively cold outside) and it calibrated
anyway if memory serves them BST sensors are superior to these crap microbolometers in almost every way
broader temperature range (can switch from an iceberg to a fire without need to recalibrate) and impervious to sunlight (whereas
all FLIR cams have microbolometers & will be ruined if you point them too long at the sun right?)
the only advantage of microbolometers is cheaper to make but since I suspect this aint reflected in final cost of product, that's irrelevant
