Author Topic: FLIR MR160 Thermal Imaging & Moisture Meter Review, Teardown & Experiments  (Read 2625 times)
Offline HugoneusTopic starter
    • The Signal Path Video Blog
You can watch the video here: [28 Minutes]
youtu.be/CLIaCu2opcc
More videos at The Signal Path:
http://www.TheSignalPath.com
Offline Len
I was expecting you to measure the moisture content of Poochie.
DIY Eurorack Synth: https://lenp.net/synth/
Offline frenky
  • Country: si
    • Frenki.net
How come that you bought MR160 with 80x60 resolution for 600$ instead of Flir One V2 with 160x120 sensor for 250$?
Is is because MR160 would be more interesting in a teardown video?
P.S:
I really like your educational videos. Especially when you are fixing some hardware; it's like watching a detective at work. :-+
« Last Edit: January 12, 2016, 02:44:50 pm by frenky »
