Author Topic: DIY Night vision spotter (Vis/NIR) project based on a cascade design...  (Read 917 times)
Offline LambdaTopic starter
Hello ! :)
I dare to come here for presenting to you the beginning of a small DIY project i try to implement on the "corner of my kitchen table". Not exactly thermally/LWIR targeted, i have to admit, but still suitable for NIR observation.... :D Therefore, suitable for observing also objects with high temperature ...  :-[ :D
Here is a kind of night vision spotter based on a cascade architecture with using two gen 1 tubes: XX1080 "diode" (i would rather say triode) II tube from Philips, formally used in armoured vehicle/panzer periscope.
The "prototype" is made from junk box elements, some little cheap very convenient electronic modules available on Ebay for instances, old optics,...
Here is the part 1: "proof of concept".
Nothing new under the Sun, according the prior art, but a cool challenge for a hobbyist, especially not really well equiped...! :D
And again, a lot of space for improvements, for sure !
To be continued...
Best regards.
Stéphane
The following users thanked this post: aargee, doktor pyta, RO
Offline RO
Re: DIY Night vision spotter (Vis/NIR) project based on a cascade design...
« Reply #1 on: February 17, 2023, 07:57:17 pm »
Very impressive diy project  :-+
The following users thanked this post: Lambda
« Reply #2 on: February 18, 2023, 08:52:42 am »
Thank you RO.
But honestly, nothing really sophisticated neither finely crafted  :-[ :)... :D But promising and very interesting to try to design with low budget and little means.
My next move will be to use a faster lens well L0 adapted for the first upstream tube and using a relay lens L1 with a higher transmission and if possible aspherical.
To be continued ! :D
Regards.
Stéphane
