@zrq - yes, the theory has always said that a LWIR microbolometer should be able to see a 10.6µm laser but there are precious few examples on the net of it being done. I posted the message mostly as a cautionary tale because I don't want anyone else to suffer a similar loss.
@Hydron - yes, there is a dead pixel routine but it doesn't want to work. Some of the dead pixels have stuck black but the ones surrounding are white; the dead pixel routine thinks I am viewing a scene with thermal contrast.
Fortunately I can access the raw dead pixel map file, so once I've worked out how it's set up I should be able to adjust it by hand. It'll take time (something in precious short supply) but I'm optimistic that I can improve matters. Although it would theoretically be possible to replace the sensor and recalibrate the hardware for dead pixels, gain and nonlinearity, I don't have access to the tools that set the various bias voltages. The specific sensor in the camera is a particularly 'hot' one (ie sensitive), which I think may have been handpicked by the manufacturer and 'tuned' for best results. I estimate the NETD at or fractionally below 30mK, though I recognise this is at the expense of dynamic range and other aspects of its performance.
If all else fails I can try the
dead pixel repair procedure documented on EEVblog a while ago.
I remain very cross with myself for letting this happen, though the initial test I did with the Seek suggested it should be OK. Live and learn...
@Fraser - thank you for your sympathy. Yes it was one of my better cameras
![Cry :'(](https://www.eevblog.com/forum/Smileys/default/cry.gif)
And yes, I do remember that thread. The sensor in my camera is sun-safe (I have inadvertently proved that a couple of times) but not laser-speckle-safe.
At least I took the precaution of wearing my glass spectacles, which are opaque to LWIR. I'm upset about losing a few microbolometer pixels: I can't imagine how upset I'd be if I'd lost part of my optic nerve.
