Well I just bought an UTi220A Pro, it's an rebranded UTi260b with swapped color of the shell plastic and rubber. Price is about 273 USD. After some initial test I am shocked by how poor the design is.. It uses Type-C port, but doesn't work with Type-C to Type-C cable.. The captured image turned out to be just screenshot.. There is no way to manually set temp range, no way to get the raw sensor data, no way to record clean video, all I have is to see where is hotter or cooler on this TN display with awful viewing angle... And the software looks like a homework of an newbie programmer, it even contains some miscopied folders inside the installer.. And in order to review captured images the device must be connected, there is no way to open images saved on computer..
Overall I would say it's more like a child toy with a thermal camera, other than a professional thermal imaging tool... I am new to thermal imaging, ever read the manual of FLIR T1020 and was surprised by the functionality of a thermal camera, so I thought the UNI-T would have similar features but just worse image quality, however... I should've read the UNI-T manual before purchasing... And I broke the screw cap on the handle due to curiosity, so no way to return it now.. Anyway, the thermal resolution seems to be good, it's a pretty advantage isn't it😂 Well this isn't a very pleasing start like always, a lot more to learn haha
