I had purchased a damaged FLIR T620 that has a broken screen and didn't seem to boot. I've tried using the update tool however it doesn't seem to retain the update, once I reboot I can see via that the /FlashFS directory that gets created after the update disappears. I made a quick video of some of it:
I was wondering if anyone happen to have some ideas as to why the flash update isn't being retained? I know there was effort to revert the firmware to older firmware on the FLIR E40, I read through a lot of the E40-related thread and if they had ran into the same problem.
I was able to capture the authentication to the FTP using Wireshark:
User: anonymous
Password: NcFTP@
however maybe the privilege of "anonymous" isn't sufficient to see and write to the real root directory and it's writing to a "chroot"-like root, this would explain why the update isn't taking and the system reverts when it reboots.
I was able to figure out the pinouts on the 12-pin receptacle that's seen in many FLIR boards.
12-pin connector:
Digi-Key Part Number: (
1195-3392-1-ND )
Connector Manufacturer: HARTING
Connector Manufacturer Part Number: 15210122601000
26-pin connector:
1195-3395-1-ND )
Connector Manufacturer Part Number: 15210262601000
I'm working through the 26-pin receptacle that's also common on FLIR boards and will update.
Open to ideas! Thanks!
** Update 2020-06-27:
* Found some I2C in 26-pin receptacle, added photo and decoded I2C output.
* Attached UART output in uart_output.20200627.1.txt for reference
What was happening was when I ran the upgrade, it was installing the files into /FlashFS/ however it was creating that directory. That directory *should* of existed prior to the install. I had issued the cmd `diskutil -L` and saw:
Store "Intel Virtual File System":
Device Name: "DSK1:"
Description.: Intel Virtual File System
Partitions: 0
Mount Count: 0
Device Type: FLASH
Device Flags: |STORAGE_DEVICE_FLAG_READWRITE|
Device Attributes: |AUTOFORMAT|
Number of Sectors: 216513
Bytes per Sector: 512
Free Sectors: 0
Biggest Partition Creatable (sectors): 0
No partitions found on "DSK1:"!
so basically the partition somehow is corrputed. I preformed a low-level format using `diskutil`
-F <s> -l Low-level format store
then created a partition on DSK1 with the size of the whole device:
diskutil -C DSK1: -p Part00 -x 216510
and now I see this `diskutil -L`
Received shell command message:
Partitions: 1
Mount Count: 1
Device Type: FLASH
Device Attributes:
Free Sectors: 0
Partiton "Part00" on "DSK1:":
Partition Name: "Part00"
File System: exfat.dll
Volume Name: FlashFS
Volume Attributes: Volume Flags: |TRANSACTION_SAFE|WFSC_SUPPORTED|LOCKFILE_SUPPORTED|STORE|
Number of Sectors: 216510
Partition Type: DOS4_FAT (FAT16)
Partition Attributes: |MOUNTED|
and when I list directory, I get:
Directory of \
01/01/1998 04:00a <DIR> StorageCard
01/01/1998 04:00a <DIR> FlashFS
01/08/2010 07:17p 4,096 Printer.swap
01/08/2010 11:17a <DIR> profiles
01/08/2010 11:17a <DIR> Documents and Settings
01/08/2010 11:17a <DIR> My Documents
01/08/2010 11:17a <DIR> Program Files
01/08/2010 11:17a <DIR> Temp
01/08/2010 11:17a <DIR> Windows
1 File(s) 4,096 bytes
8 Dir(s) 50,008,064 bytes free
Device now boots up fine however looks like calibration data is missing. In UART logs "uart_output-afterflash.20200627.1.txt" :
Exception 'Raised Exception' (-1): Thread-Id=066e0032(pth=90a8b33c), Proc-Id=0705000a(pprc=903b23a0) 'uicore.exe', VM-active=075000a(pprc=903b23a0) 'uicore.exe'
PC=400608c4(coredll.dll+0x000508c4) RA=883ba2c0(kernel.dll+0x000062c0) SP=0032dd34, BVA=0032ddfc
uicore: 1263010518:964: Info: Cascades version: 3.8.13
uicore: 1263010520:610: Error: FLIR::modules::SystemInfo::UpdateLensInfo: Failed to read calibration resource: FLIR::core_interace::ResourceManager::OpenResource: Failed to open resource: .calib.lens.le.isMeasured, return code: 0xab010004
PC=400608c4(coredll.dll+0x000508c4) RA=883ba2c0(kernel.dll+0x000062c0) SP=0032e490, BVA=0032e558
uicore: 1263010521:168: Error: FLIR::modules::ImageOps::OpenResources: Zoom disabled.
PC=400608c4(coredll.dll+0x000508c4) RA=883ba2c0(kernel.dll+0x000062c0) SP=0032e714, BVA=0032e7d8
POST 20100108 20:15:21 - uicore.exe: pdfReader tid 0x065F0236 qid 82
PC=400608c4(coredll.dll+0x000508c4) RA=883ba2c0(kernel.dll+0x000062c0) SP=0032e9c8, BVA=0032ea90
uicore: 1263010521:881: Error: FLIR::modules::VoiceAnnotation::OpenResources: Couldnt open resources for VoiceAnnotation; IGNORNG during dev
POST 20100108 20:15:21 - uicore.exe: Created modules in 2431 ms
CamAppThread: 256 buffers, 21 Hz
** Update 2020-07-04:
I was able to get it working! The fixed required the missing files
Flashfs/system/calib.rsc
Flashfs/system/appcore.d/config.d/conf.cfg
Flashfs/system/maps/*
Flashfs/system/appcore.d/*
The *.rsc required updating of the serial number and CRC value.
The unit boots up fine and shows the imager's image . Since the map files were from another unit, it's not calibrated to this unit and there's dead pixels that's not compensated for. Next bit is to figure out where that information stored.
It's worth noting that the UART/JTAG socket is accessible behind the sticker in the battery shroud, see IMG_6120.jpeg.
H/T to Chanc3 for helping me on this.
