What are your experiences with this camera?
I have the feeling that the VEVOR support is not good.
There are no proper instructions for the device. There is only a quick guide.
Even after questions the support, was only sent this quick guide.
There is also no software for Windows PC included.
And this software is not provided on the homepage either.
I also contacted service here. They sent me two different links.
Both don't work.
I also noticed that all downloads are available through third party providers.
https://d2v0huudrf11kh.cloudfront.nethttps://we.tlhttp://yunpan.raytrontek.com/l/AF2ocmVEVOR doesn't seem to offer its own support here
Missing Features:
- It is not possible to access image information or delete an image via the camera menu/image viewer.It is possible to delete a picture. Long push on the Menü-Button in the viewer. Do not open the picture.
- It is not possible to set a temperature range. For example: Always a temperatur range of 10-30C°.
The scale is always adjusted dynamically. So it is not possible to take comparable before and after pictures
-Is it possible to record an IR and a normal image at the same time? That's why I have the SC240M model with two cameras
-No Windows software to download available
I think its better to buy a camera from another manufacturer.
There is simply better support there and you can find more information on the internet
But that's just my impression. What are your experiences?
Next week I will buy another model.
Probably the Guide IR PC210
Grunema
