Useally dust particles the laserbeam interact with and makes them visible and it was this interaction.
But even if these dustparticles are pretty big in regards something like molecules. I would reckon you still need a sensitivity able to sense this heat-energy of massless partcles interact with these dust particles. .
You can actually see these 5 to 7watt blue wavelength beams and the energy/heat messing up the dust-particles.. .
and was wondering if third-party interactions like , dust, fog, foam etc could help on the matter.
But need to try it out, but a Seek pro is certainly not the most sensitive thermal cam on the market
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
when it comes to small heat differences and like fx 5w 465nm laser beam interacting with dust particles in air..
but likely need to try and error.. just a noob on thermal sensors and the risk of hurting these and usually optic-cam-sensors and high powered-laser beams are not friends..
These intense beams and this bright intense light loves tumbling the optic cam-sensors at angled recordings.. how it is with thermal-cams sensors. I don't know if this intense light (offcourse not direct) can hurt these thermal-sensors.
Seek pro FF [IOS].
All Native with just the Seek pro..
First two a new water heater from phllips..
plus an old pavillion laptop and a metal PSU.
+ // a DIY el cheapo-beam rack
