Author Topic: Thermal Imaging Gallery II  (Read 60039 times)
Offline bap2703
  • Country: io
Re: Thermal Imaging Gallery II
« Reply #125 on: February 12, 2021, 07:58:47 pm »
The lens has been disassembled
Finally you made it  :-+
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
« Reply #126 on: February 15, 2021, 07:12:58 pm »
Seek Reveal Pro FF.
1st image - a cold day, accidentally getting the sun in the image - notice the wiggly 'comet tail'
2nd, 3rd and 4th image - the tail remained on the sensor for a few moments, long enough to take these shots, but after a calibration flag event it was nulled out and the image was fine.
5th image onwards - selection of random images from the Seek. All 320x240, exactly as-shot.
Rubber bands bridge the gap between WD40 and duct tape.
Online DaJMasta
    • medpants.com
« Reply #127 on: February 16, 2021, 02:51:31 am »
Not especially great quality images, but some neat ones I got a couple weeks back after a few inches of snow.  Very funny to see a sort of underlighting effect where the snow on top was dark and the bottom of things were warm.  An odd perspective in the tree branches, and free underbody lighting for all the cars parked on the road.
Offline globoy
« Reply #128 on: February 16, 2021, 08:59:31 pm »
New poster here.  Psyched to find this forum.
This is image from a home-made (Lepton3.5) camera.  Black fox on rear deck with a few inches of snow on a cold day.
Offline Ultrapurple
« Reply #129 on: August 09, 2021, 09:14:45 pm »
A couple of deer seen with a Therm-App Pro and 35mm lens, ThermViewer software superresolution to 1280x960. Image straight off the camera, no processing. Notice how you can see the warmth of their hoof prints.
Bonus: the second file is an animated GIF of three deer, made with the Therm-App Pro - but you'll have to download it, as the forum doesn't seem to support animated GIFs.
« Last Edit: August 11, 2021, 08:45:27 am by Ultrapurple »
The following users thanked this post: frenky
Offline Ultrapurple
« Reply #130 on: August 09, 2021, 10:10:37 pm »
And the same deer - plus a friend - seen using a FLIR T4325ZS 320x240 PTZ security camera (standard 13mm lens).
« Last Edit: August 11, 2021, 08:42:21 am by Ultrapurple »
Offline Ultrapurple
« Reply #131 on: August 10, 2021, 07:04:20 am »
If anyone fancies reprocessing the two-deer image, here's the raw image data. I'd love to see what can be done with it.
Offline dizzyzzid
« Reply #132 on: August 12, 2021, 01:30:49 pm »
Quote from: Ultrapurple
link=topic=188172.msg3624295#msg3624295 date=1628579060
Done with python and opencv2 and very simple sharpening filter.
You gain a bit of detail on the deer but the background gets a little noisy.
Which looks promising for me as I don't care about the temperature accuracy at all, spotting purposes only.
Run time is around:
818 µs ± 50.7 µs per loop (mean ± std. dev. of 7 runs, 1000 loops each)
Can I ask what the distance was between the camera to deer?
Offline Ultrapurple
« Reply #133 on: August 12, 2021, 01:42:33 pm »
Thanks dizzyzzid - you've certainly brought up a lot of detail in the deer's bodies.
The distance to the deer was very roughly 30ft (10m). I was watching them from an upstairs window.
Offline JimM
« Reply #134 on: August 12, 2021, 07:35:54 pm »
Here is Ultrpurple's deer image after conversion to binary data and saved as a PGM P5 file using Objective-C code. Then simply contrast-stretch by 1%x1% in ImageMagick and save as PNG. Note the image is reversed (mirrored) from the original image posted by Ultrapurple.
Edit to add: Changed contrast-stretch to 2%x0% to minimize blowout at top end. Also flipped image to correct orientation.
« Last Edit: August 13, 2021, 05:49:04 pm by JimM »
Offline frenky
  • Country: si
    • Frenki.net
« Reply #135 on: August 13, 2021, 08:32:55 am »
Took image from dizzyzzid upscaled it with http://waifu2x.udp.jp/ and cropped. ;)
Soon we will be able to see a wolf in deer eyes reflection. ;D
Offline Ultrapurple
« Reply #136 on: August 13, 2021, 09:07:16 am »
This is getting to be fun.
I took frenky's image, did a tiny bit of gamma modification and quite a lot of area-selective noise reduction on the background, then flipped the image back the right way round.
If you look carefully at that reflection in the deer's eye you'll see it's not actually a wolf: it's a farm cat who self-identifies as a wolf.
« Last Edit: August 13, 2021, 09:10:04 am by Ultrapurple »
Offline JimM
« Reply #137 on: August 13, 2021, 07:21:30 pm »
I know this topic is on pictures rather radiometric data., however does anyone know how to get temperatures from the raw data that Ultrapurple posted for the Therm-App images?
Offline frenky
  • Country: si
    • Frenki.net
« Reply #138 on: August 13, 2021, 07:50:30 pm »
He posted file with matrix of temperatures. Image is 640x480 so his file contains 640 columns and 480 lines of data.
Each value is temperature of single pixel. First pixel has value 1944 which is probably 19.44*C.
Offline JimM
« Reply #139 on: August 13, 2021, 09:32:30 pm »
frenky, Ok that kind of makes sense, the minimum value in the file is 1832 and maximum is 3303, so that's a minimum temp of 18.32 deg C and maximum 33.03 deg C. Wonder why they didn't just use floating point values. Would have been a smaller file.
Edit to add: Those temperatures may not actually be the target temperatures. See this post from Stackoverflow:
https://stackoverflow.com/questions/56695676/how-to-open-a-txt-file-of-ir-temperatures-as-an-image-in-matlab-or-other-analysi and specifically the following:
"edit, since writing this I've found that the output .txt file of temperatures is actually sensor temperatures which need to be corrected for emissivity and background temperature to obtain the target temperatures. (One way to do this is to use the software which comes free with the camera to create new output .csv files of temperatures and use those instead)."
« Last Edit: August 17, 2021, 06:03:32 pm by JimM »
Offline Ultrapurple
« Reply #140 on: August 18, 2021, 09:05:01 am »
Perhaps this should move to a new thread.
It is worth noting that (at least in the case of the Therm-App series) the 'temperature' of the pixels depends on the lens used. This particular Therm-App Pro was purchased with that specific 35mm lens and, as it's a very early unit, I suspect Opgal may have taken a little more care over calibration than may normally be the case.
There is no overriding reason that the pixel data should be an accurate representation of the actual scene temperature, though it may be a happy accident that it works out that way. I'll have to make an image of something like ice-water beside boiling water so we can see what happens. And if I do it with different lenses we can maybe learn more.
New thread started: Deer photos and Therm-App Pro data. Let's leave this thread for pretty pictures, as was originally intended.
Offline IwuzBornanerd
« Reply #141 on: August 18, 2021, 11:30:49 pm »
Okay, back to making pretty pictures.  :)
While manipulating the data to make details visible is certainly useful, I like to start by getting all the thermal details with a distinct color palette.  While in some cases this produces some cool isotherms I recognize that in many cases it makes a rather "busy" image as well as noisy.  I do like the "grass" look here, though, even if it is noisy.
1247715-0
Someone who prefers gray scale only might instead apply the entire gray scale to the background & then do the same to the deer & then combine the 2 to get the following.  Not much more detail in the deer, but noticeably more in the background.
1247719-1
In similar fashion, taking the green from my distinct color palette & applying Seek's "Amber" palette to the deer yields brown deer on green grass (which I think looks pretty cool).  8)
1247723-2
As far as simply applying a single palette, I think my favorite is the standard "iron" palette:
1247727-3
And applying Seek's "HiLo" palette gives us deer on snow.  :D
1247731-4
I am not opposed to exercise, unless it is an exercise in futility.
The following users thanked this post: Ultrapurple
Offline Ultrapurple
« Reply #142 on: August 19, 2021, 07:37:06 am »
Thanks IwuzBornanerd. I too really like the brown deer on the green grass.
<irony>
If only someone could invent some kind of device that would record the scene in front of the user and then render it in natural lightness and colour...
</irony>
Offline Ultrapurple
« Reply #143 on: August 29, 2021, 07:37:31 pm »
Therm-App Pro (640×480 with superresolution to 1280x960), 35mm and 19mm lenses.
« Last Edit: August 29, 2021, 07:39:17 pm by Ultrapurple »
Offline Ultrapurple
« Reply #144 on: August 30, 2021, 08:13:29 pm »
Just a few more from the Therm-App Pro, all straight off the camera and unedited.
Offline Ultrapurple
« Reply #145 on: August 30, 2021, 08:31:03 pm »
I thought I'd busted a toe. It hurt like a really hurty thing. The bruise was obvious and it was warm in thermal imaging but the X-Ray didn't find a fracture. It settled down after a few days.
Offline Ultrapurple
« Reply #146 on: September 07, 2021, 09:26:31 am »
An old thermal imaging favourite - a really hot cup of tea.
Therm-App Pro (640x480) with superresolution to 1280x960. Lens probably 19mm.
Offline Ultrapurple
« Reply #147 on: September 09, 2021, 10:28:14 am »
I bought a tiny 5.6GHz FPV video transmitter via eBay. It seemed to be running a bit hot so I added a heatsink over the large synthesiser and smaller power amplifier chips. It was still a little on the warm side so I decided to frighten it with a thermal camera.
If the board has bits running at ~120°C with a heatsink, I can only wonder at how hot it was getting without the additional dissipating surface. Who designs these things? Or are the thermals now considered OK as long as the solder doesn't quite melt...? :scared:
Thermal image made with FLIR SC-660, standard 40mm lens plus Agema Thermovision close-up lens "20°LW" p/n 193 672.
Postscript: I added a rather larger heatsink (15x15x10mm) plus a 10x10x5mm heatsink on the other side of the board (which is also populated but with control rather than RF electronics) and the thing still runs at well over 80°C.
« Last Edit: September 10, 2021, 08:14:44 am by Ultrapurple »
Offline downtodo
  • Country: tw
« Reply #148 on: September 10, 2021, 07:35:05 am »
SSD control chip 12x12 mm
HT-301
« Last Edit: September 10, 2021, 09:31:49 am by downtodo »
The following users thanked this post: RBsonic
Offline Ultrapurple
« Reply #149 on: September 10, 2021, 10:46:37 am »
That last image - the ruler - is intriguing; it's interesting to see how the engraved marks reflect heat from different parts as the angle to the camera changes.
