Author Topic: Thermal Imaging Gallery II  (Read 60029 times)
Offline Spirit532Topic starter
    • My website
« on: May 21, 2019, 08:34:15 am »
Since the first thermal imaging gallery thread broke a few times, it was suggested that another one is started.
If you're sharing something, please add some info to your post, like this:
  • Subject: Hand
  • Camera: FLIR T440bx
  • Lens: 18mm
  • Original resolution: 320x240
  • Camera mods: None(but for example - pano head, macro adapter, peltier cooling, etc)
  • Image manipulation: JoeC's image decoder, TIFF, then upscaled with waifu2x with some denoising. Compressed to tiny JPEG.
« Last Edit: May 21, 2019, 08:50:00 am by Spirit532 »
The following users thanked this post: frenky, Lord of nothing, Stephmw
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
Re: Thermal Imaging Gallery II
« Reply #1 on: May 21, 2019, 10:04:44 am »
Thanks for doing this. Can I add a plea that when quoting a post with an embedded image, we don't re-post the image itself? It's not hard to edit out the IMG tags from the text you're quoting.
Rubber bands bridge the gap between WD40 and duct tape.
The following users thanked this post: jusaca
Offline Conure
« Reply #2 on: June 18, 2019, 07:08:00 pm »
TE-Q1
Grass, dirt and my leg on a sunny summer day.
Copper lizard in the shadow of a tree. Warm summer day. Ectothermic animals don't show up well in IR.
Horses eating grass sunny day. Notice the fabric on the right horse is transparent in IR.
« Last Edit: June 18, 2019, 07:13:26 pm by Conure »
The following users thanked this post: geggi1
Offline bugi
  • Hobbyist using the ultra slow and unsure method
« Reply #3 on: June 19, 2019, 08:40:16 am »
Transparent?... or has the horse's body warmed the fabric where it touches? Considering that where the fabric hangs more loose (around legs) it isn't as bright.
Offline jumpy9734
« Reply #4 on: June 29, 2019, 06:41:18 pm »
Camera : Seek Thermal Compact (2017 version)
Sensor Resolution : 206x156
Ironing
Cooking Stove
Frying Pan
Offline Philtron
« Reply #5 on: July 05, 2019, 11:07:16 pm »
Flir E4 320X240 pix hacked
The cat wich let me live in his house. (E4 before the mod)
hoof (i was surprised by the temp gradient)
Also a surprise, i thought gassas do not radiate much.
You can see the bricks in the wall.  :o
Offline bap2703
  • Country: io
« Reply #6 on: July 06, 2019, 10:28:51 am »
When you visually see gas it's most probably not really a gas that you are seeing but an aerosol. Most commonly water droplets or soot.
Both radiate pretty well in infrared ;)
In addition some gases do radiate themselves but that would be weak next to the aerosols.
Offline ArsenioDev
    • DiscountMissiles: my portfolio and landing page
« Reply #7 on: July 06, 2019, 10:54:03 pm »
Raytheon BST core
Resolution: 320*240
First image is my main computer crunching some numbers and encoding video with the side panel off
second is my youngest brother holding one of the labcats
Image processing chain is CVBS-HDMI converter then capped in an Elgato cap card, no postprocessing.
Offline Mr. Scram
  • Display aficionado
« Reply #8 on: July 06, 2019, 11:24:43 pm »
TE-Q1
I always suspected cold-blooded animals wouldn't be visible, but it's nice to have it actually confirmed.
Offline Vipitis
  • aspiring thermal photography enthusiast
« Reply #9 on: July 23, 2019, 03:16:41 pm »
screenshot of a framegrab from the analog video signal of a MIRICLE 110K-35 which outputs AGC currently. The grab and capture takes away the phenomenal quality these 35µm pixels have. I can't wait to get it working digitally and to put the 32mm f/1 onto the bigger sensor.
working on it today.
*the sensor resolution is 384x288, the way I obtained the images isn't true 1:1 pixels
Offline Conure
« Reply #10 on: July 25, 2019, 07:51:10 pm »
TE-Q1
Boat
Offline Ultrapurple
« Reply #11 on: July 26, 2019, 12:11:58 pm »
Castelo de Santa Cruz, A Coruña, Spain.
Therm-App Pro, 35mm lens, ThermViewer, MS Image Composite Editor, Paintshop Pro. These images are one-third size; the thumbnail is the full size image.
« Last Edit: July 26, 2019, 12:19:57 pm by Ultrapurple »
Offline jumpy9734
« Reply #12 on: July 30, 2019, 08:37:15 pm »
Had some free time today so i was able to take the camera out for a "spin"  ;D
Sensor Resolution : 206 x 156
Car
Building
Trees, car and building
Air exhaust
Air exhaust 2
Building, car and trees 2
Tower
Buildings landscape
Building
Side of Building
Water Tap
« Last Edit: July 30, 2019, 09:10:29 pm by jumpy9734 »
Offline Ultrapurple
« Reply #13 on: August 02, 2019, 01:59:50 pm »
2.5mm DC connectors intermittently running about 3 to 4A, powering a 12V compressor fridge.
Therm-App Pro camera, 13mm f/1 lens, ThermViewer, overlay and cropping in PaintShop Pro (no image processing).
Offline jumpy9734
« Reply #14 on: August 13, 2019, 06:07:41 pm »
Camera : Seek Thermal Compact Standard (2017 Version)
A few angles with my old Sony Camcorder:
Offline pauledd
  • Riesige Gepanzerte Luftschiffe
« Reply #15 on: August 14, 2019, 07:21:48 pm »
Some ordinary Seek Compact Pro flicks...
A little great tit enjoying a nut from my leg. (Man, I have to go for a 30Hz device! Those birds are so fast  :-// )
And my 3D printed lantern interior with 130 WS2812B leds. Used a cheap chineese PSU where the power cables are so thin that they act as heater and gave me a massive voltage drop to my leds...
« Last Edit: August 14, 2019, 07:24:50 pm by pauledd »
human being - without Windows® - excuse my bad english
Offline Ultrapurple
« Reply #16 on: August 20, 2019, 03:01:02 pm »
A plane passing overhead as I was driving on the M25 motorway near London Heathrow:
815490-0
Image made using Therm-App Pro (640x480/25Hz), 35mm lens, ThermViewer software (with superresolution to 1280x960), still from a video.
« Last Edit: August 20, 2019, 03:03:56 pm by Ultrapurple »
Offline Ultrapurple
« Reply #17 on: August 20, 2019, 03:07:44 pm »
I was playing and noticed that the 'green' recycling bin was noticeably warmer than its 'general recycling' neighbour. Ten days ago I shredded a load of offcut branches and put them in the bin for recycling; it looks as though the chippings have started to compost and are generating low-level heat.
815496-0
Image made with with FLIR SC-660, no post-processing (other than cropping and resizing the visible images and making the mosaic).
Offline Ultrapurple
« Reply #18 on: August 22, 2019, 08:52:23 am »
Hi-res LWIR London skyline seen from 10th floor* observation platform at Tate Modern.
Therm-App Pro 640x480x25, 35mm f/1.1 lens, ThermViewer driver software with superresolution enhancement to 1280x960, about 12 images stitched in Microsoft Image Composite Editor, cropped & gently tweaked in Paint Shop Pro. Image is 2990 x 1817 (~5.5Mpix), uncropped original is slightly larger. You'll have to download the image to see it full size - the online view is only a small fraction of the full size image.
*For Americans, that's the 11th floor.
I try never to miss a chance to poke fun at people who feel the need to number floors logically.
« Last Edit: August 23, 2019, 03:21:07 pm by Ultrapurple »
The following users thanked this post: frenky, pauledd
Offline Ultrapurple
« Reply #19 on: August 22, 2019, 08:54:28 am »
St Paul's Cathedral, London.
Therm-App Pro 640x480x25, 35mm f/1.1 lens, ThermViewer driver software with superresolution enhancement to 1280x960. Gently tweaked in Paint Shop Pro.
Offline Exoc
« Reply #20 on: August 26, 2019, 05:36:57 pm »
This weekend, there was a car meetup close to where i live. I headed down there, knowing that people might do some burnouts.
I brought my Therm-App Hz to try to capture some, here is what i got.
[youtube][/youtube]
Offline meanie2
« Reply #21 on: August 31, 2019, 09:48:00 pm »
Hi! Need pics and info of the ZNSE lenses for Seek compact pro
Offline Ultrapurple
« Reply #22 on: September 01, 2019, 02:12:10 pm »
Please try to keep this on-topic: this thread is for showing your best or most interesting thermal images. There are plenty of other threads, or just start a new one if nothing seems to fit.
Cheers all
Ultrapurple
PS if a mod is watching could you make the previous couple of posts a new topic and delete this message? Thanks.
Offline pauledd
« Reply #23 on: September 01, 2019, 02:43:04 pm »
« Last Edit: September 01, 2019, 02:45:00 pm by pauledd »
Offline Conure
« Reply #24 on: September 03, 2019, 03:08:27 pm »
TE-Q1
Overcast dawn with thin fog
