Author Topic: Thermal Imaging Gallery II  (Read 60493 times)
Offline RBsonic
Re: Thermal Imaging Gallery II
« Reply #50 on: December 04, 2019, 06:12:56 am »
Subject: Fritzbox 3390
Camera: HT-301
Lens: 13mm
[ Specified attachment is not available ]
Offline RBsonic
« Reply #51 on: December 04, 2019, 06:15:28 am »
Subject: boiling water
Camera: HT-301
Lens: 13mm
https://youtu.be/F9461Vfi_hA
« Last Edit: October 13, 2021, 07:17:56 am by RBsonic »
Offline RBsonic
« Reply #52 on: December 04, 2019, 06:19:02 am »
Subject: building
Camera: HT-301
Lens: 13mm
884212-0
Offline Conure
« Reply #53 on: December 04, 2019, 11:32:18 am »
Subject: building
Camera: HT-301
Lens: 13mm
(Attachment Link)
Holy crap that's a good camera for only 600£!  :o Similar price to Thermal Expert but better performance.
« Last Edit: December 04, 2019, 11:43:45 am by Conure »
Offline RBsonic
« Reply #54 on: December 04, 2019, 03:40:21 pm »
Subject: Auto
Camera: HT-301
Lens: 13mm
884386-0
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
« Reply #55 on: December 06, 2019, 10:58:34 am »
My dishwasher sprang a leak...
So I ran it on a regular cycle, waited until it started heating the water and looked for the tell-tale hot bit in the leak. That told me where to look for the defect and I was able to cure it pretty quickly. It would have been much more difficult without a thermal camera to guide me.
Camera: ThermApp Pro 640x480
Lens: 19mm f/1.2
Driver: ThermViewer with superresolution to 1280x960
Processing: Registax (275 frames from MP4 video converted to AVI - almost no noise left!)
« Last Edit: December 06, 2019, 11:54:44 am by Ultrapurple »
Rubber bands bridge the gap between WD40 and duct tape.
The following users thanked this post: frenky
Offline RBsonic
« Reply #56 on: December 22, 2019, 02:33:17 pm »
Subject: Finger
Camera: HT-301
Lens: 13mm
894646-0
Offline alex871
« Reply #57 on: December 22, 2019, 10:56:51 pm »
Flir E6
Offline jumpy9734
« Reply #58 on: December 23, 2019, 01:38:05 pm »
Seek Thermal Compact (2017 manual focus version)
Sensor Resolution : 206x156
< 9 Hz Frame Rate
1,000 ft. Detection Distance
-40F° to 626°F Detection
People and cars on the street
People and cars on the street 2
Radiator
Radiator pipes
Old cast iron radiator
Bad peripheral blood circulation
Opened window
Offline Conure
« Reply #59 on: December 23, 2019, 07:35:12 pm »
TE-Q1
House under various time and weather conditions.
Offline Ultrapurple
« Reply #60 on: December 23, 2019, 10:01:33 pm »
Seasonal greetings
Office Christmas tree half-way up the stairs. Some lights, mix of LED and filament (the latter mainly in the bottom third). Presents beneath tree. Quickly snatched shots with no camera warm-up time, finesse or significant post processing.
ThermApp Pro, 640x480, superresolution in ThermViewer to 1280×960.
« Last Edit: December 23, 2019, 10:06:48 pm by Ultrapurple »
Offline Vipitis
  • aspiring thermal photography enthusiast
« Reply #61 on: December 27, 2019, 09:32:32 pm »
felt like posting again. I repaired my prototype so it is version 1c now. However the shutter is still not moving completely out of the way. I started to remove the lens from the VGA sized core, but that was unsuccessful so far, the lens seems to be in some kind of housing and now there final two accessible screws are stripped.
This was an idea completely out of the blue. I remembered to have shot about the same angle on my phone a year back. that was with my DIY lens attachment of the new broken lens. I had to manually adjust the levels and the shutter shadow is  very present. getting the VGA core will only fix half of the issues. full digital access and RAW output is my long time goal for the next year. tomorrow my brother has a lot of people over and I will gather some shots of people and play with color. doubt I will get the shutter fixed or the core freed in time.-
stiched from video in ICE, paint.NET color adjustments, Palette Generator with FLIR iron palette. resolution is incorrect both times.
old post(reference): https://www.eevblog.com/forum/thermal-imaging/thermal-imaging-gallery/msg1887413/#msg1887413
Offline RBsonic
« Reply #62 on: January 01, 2020, 01:55:45 am »
Subject: Fireworks Mix.  Happy new year 2020!
Camera: HT-301
Lens: 13mm
https://youtu.be/-m7RYPIIRXc
Offline Ultrapurple
« Reply #63 on: January 09, 2020, 04:20:14 pm »
Over the Christmas and New Year break the place I work was kept on 'care & maintenance' heating but my boss' office was not. When I came in over the holidays I noticed his door was significantly colder than all the others - so I set up my Therm-App Pro and then opened the door to see what it would look like.
It wasn't actually arctic cold, but the thermal image suggests otherwise! The temperature span was, I guess, three or four centigrade.
« Last Edit: January 10, 2020, 08:20:36 am by Ultrapurple »
Offline jumpy9734
« Reply #64 on: January 11, 2020, 03:14:43 pm »
A longer distance field test with someone walking in a yard, at about 70m distance
Offline Conure
« Reply #65 on: January 20, 2020, 10:24:45 am »
TE-Q1
Cold shoes and jacket after a walk.
Ducks on a cloudy day
Concrete pier on a day of clear sky
Offline frenky
  • Country: si
    • Frenki.net
« Reply #66 on: January 20, 2020, 12:44:17 pm »
Just a friendly suggestion to get better images. Change aspect ratio in ThermalExpert app to 4:3.  :-+
Offline Ultrapurple
« Reply #67 on: January 20, 2020, 01:02:06 pm »
+1
No point in having all those nice pixels and then cutting off a good third of them! I get irritated enough by the little "FLIR" logo in the bottom left of my SC660, let alone needlessly losing any more...
(and, though I am aware my opinion isn't worth a bean, I'm one of those people vehemently opposed to vertical video ... probably because I have a 'widescreen' monitor, not a 'tallscreen' one!)
« Last Edit: January 20, 2020, 01:03:58 pm by Ultrapurple »
Offline Conure
« Reply #68 on: January 20, 2020, 02:54:34 pm »
You mean like this? I changed the settings and all I notice is some black bars at top and bottom. Less pixels.
Offline Ultrapurple
« Reply #69 on: January 20, 2020, 03:24:33 pm »
Fewer screen pixels but many more thermal pixels.
The following users thanked this post: Conure
Offline Conure
« Reply #70 on: January 21, 2020, 04:57:00 pm »
TE-Q1 conrete pier on cloudy day
Notice the sun in the middle pic.
Offline Bud
« Reply #71 on: January 21, 2020, 05:20:41 pm »
A classic UFO pic in mid bottom one  :-+
Offline bostwickenator
« Reply #72 on: January 29, 2020, 02:38:12 am »
A composite of 6 frames from a Seek Compact Pro. Austin's skyline is on the horizon believe it or not.
Offline guazan
« Reply #73 on: January 29, 2020, 12:22:37 pm »
TE-M1.
Offline Ultrapurple
« Reply #74 on: January 31, 2020, 09:05:11 pm »
@bostwickenator - lovely! What did you use to stitch the images?
