Hi All,
We've release new CA Series thermal imaging analyzer camera DytSpectrumOWL 2.0 software, it is compatible with new type cameras CA-20 (260x200), CA-30 (384x288), CA-60 (640x480), it can support more new features,
• The new designed hardware with resolution of 640x480, 384x288 and 260x200 resolution, it is very suitable for PCBA R&D analysis, heating material test and heat conduction test etc.;
• Support one click to find the defect PCBA components;
• 16 color palettes, 40 points and 20 ROIs (line, rectangle and polygon) measurement at same time and without record time limitation;
• Electronical zoom for small objects measurement;
• Isotherm for fixed palette, it will fix the color vs. temperature, even there are some high or low temperature objects into the screen, the color will not be changed;
• Record and display measurement frequency up to 20Hz;
• Measurement temperature to 550°C (1022°F) (260x200 supports to 450°C (842°F) );
• The temperature data will be saved as CSV file for future analysis.
• It will support Android phone for simple view in coming soon.
Here is the url of the introduction,
https://youtu.be/xbQt13tXJUUHope you will like it, if you are interested with it, please contact me: adel@dianytech.com
