I have a FLIR i5 at work that we bought sometime in 2014 or 2015. It works ok but the lack of a tripod thread mount is an issue, as well as minimum focus distance and a couple of other things.
I would like to buy a newer unit that:
- is at least 160x120 resolution
- covers the 0 C - 200 C range
- has good accuracy (+/- 2 C in the 50-150C range preferred, but I'll take what I can get)
- has a camera thread mount
- has minimum focus distance of 50cm or less
- has flexible image triggering options -- just a manual trigger is not very appealing. I'd like to either trigger a new image via USB/Bluetooth from a PC (example: Python script that runs and asks for an image every second for 10 seconds and then every 2 seconds for 20 seconds) or stream images to a PC where I can somehow pick off the ones I need and save them
- costs less than US$1200 (goal of less than US$800)
I like the way FLIR embeds the temperature data in the JPEG itself.
I'm looking at the FLIR TG267 which looks good except for what appears to be a lack of flexible triggering.
