This IIT is from the Millard/Philips XX1500 range. Commonly found in medical imaging systems.
Thank you, Fraser!
I managed to heat up the fibreoptic bundle and free it from the CCD. It's only held on with epoxy on the edge and oil on the optical surface.
If i get to the point of attaching this to another CCD, any tips on what kind of oil that is suitable - will standard mineral oil do?
If the new CCD ends up being smaller size, i wonder if i can machine the fibreoptic piece smaller on my CNC milling machine. I guess i need some diamond tools and patience
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
// Per.
