I was fortunate enough to come across a FLIR Pathfinder (V1) thermal imaging system for vehicles the other day. The unit is "as new" with all parts and with no signs of ever having been deployed on a vehicle. Sometimes I get lucky and come across these gems at a price that I can afford. This was such an occasion and I consider myself very fortunate.
For those unaware, the FLIR Pathfinder series of thermal imaging cameras are weather hardened units designed to be deployed in the grille of a vehicle. As such the unit is equipped with a Germanium lens protection window and heater to keep the unit operational in cold climates. The casing is made from aluminium alloy and is very robust. Such ruggedness is essential if a thermal camera is to survive the rigours of being located at the front of a vehicle that travels along all manner of road conditions and weathers. The original Pathfinder (V1) even found itself installed on the USA's M1 Abrams tank !
There are a few versions of the "Pathfinder" in the wild. The Version 1 unit, such as I have, was intended to be easily deployed on vehicles from new, or retro fitted to such with only a power supply and monitor required to complete the system. The camera unit receives approx 12V from the host vehicles electrical system and sends a composite NTSC or PAL video signal to a standard monitor that is mounted in the vehicles cockpit area. This was a very simple system to retro fit into most vehicles and there were different kits sold to meet the differing needs of end users. The "commercial kit" that I have did not come with an LCD monitor but the Law Enforcement (LE) kit included a 7" LCD monitor. A universal camera mounting bracket was included in both kits. The versions of the Pathfinder system that followed the Version 1 were different in that they employed firmware based measures to make the camera inoperative unless it was still connected to its specific (original) host controller. The host controller could also be married to a vehicles systems to make transfer to another vehicle very challenging. Many of the later versions of Pathfinder camera are labelled as "Autoliv" as they were part of the Autoliv night vision system deployed on luxury brand vehicles such as BMW and AUDI. At this point I advise readers thinking of buying a "bargain" Ex BMW or AUDI Pathfinder camera to do their research as getting the camera to work in your application could be very challenging. There are other threads on this forum discussing the BMW and AUDI Autoliv cameras.
I already own an Autoliv NV2 version of the Pathfinder and it does have enhancements over the Pathfinder Version 1, such as a user replaceable Germanium window (if you can afford it !) Sadly it is a paperweight due to the measures taken by FLIR to prevent its use on another vehicle. I did not expect to find a Pathfinder V1 for sale in the uk and certainly not one that looks new ! The unit I stumbled upon is mint with not a single mark on its casing or Germanium lens protector. I suspect that this camera was purchased for some form of evaluation in a safe environment and then boxed up for many years awaiting rediscovery and sale. My unit was built in 2011 so is a late build for a V1 camera.
So why am I starting this thread ? Well I researched my new purchase on the internet and realised that there is not a great deal of useful information out there, beyond copies of the user manual etc. Whilst my camera came with the original flir umbilical cable, others are often missing this when sold and the connector looks unusual at first glance. I tracked down a source of the connector and thought it would be good to provide any useful information in a thread on this forum for those who may need it in the future. Note that I do not intend to dismantle my Pathfinder as the casing is hermetically sealed and filled with gas to prevent condensation issues. I may well rehome the unit and want its mint condition to be retained.
The Pathfinder provides a data path for configuration by OEM's. This uses the LIN automotive communications protocol. There are also LVDS digital outputs for monitors and hosts that can make use of a digital video stream. The LIN command set is sadly not provided in the user manual and was only provided by FLIR after an NDA was completed
I do not have that document but the unit, as supplied, is pre-configured for use and FLIR provided the configuration capability for OEM's who required changes to the standard (general use) configuration.
I will attach pictures of my pathfinder V1 and also details of where I sourced additional connectors for less than £5 each. If anyone has additional information that they believe may be useful to others, please do add that information to this thread.
Fraser
