The 4 pin mini USB lead has arrived.
It certainly looks the same as what is required and the main dimensions match.
The normal 4 pin HIROSE type mini USB plug has three alignment 'keys', one wide one at the mid point and one at each edge. The 'keys' at the edges need to be removed in order to use the plug with the RazIR/M series cameras. The removal of the two thin 'keys' appears quite simple and I shall first try a scalpel. If that does not work, a very fine file should make short work of them
I then need to check for correct fit and pinout compatibility with the standard USB A plug at the other end of the lead.
I previously stated that this USB port is used for video output as well as USB comms. That was incorrect. I have the video cable and it plugs into another port on the side.
More on this when I get a chance to play with the USB lead
Fraser
