Hi friends.
I recently got a Flir FC-T camera, which have TAU 324 inside. I noticed several abnormal things compare to another TAU I have:
a. The screen will quickly flash white after each NUC.
b. There's slowly changing random noise all over the picture, regardless of the scene. It changes much slower than frame rate, and migrate softly when changing. I don't think it's too high gain because it doesn't show more contrast on flat scenes, compare to the other TAU. And it look like artificially added, does Flir even do this on TAUs?
Both are not the case on my other TAU. I may have more clues after repair my broken TTL cable...
Anyone have experienced such things? Welcome to discuss.
