Author Topic: Seek reveal Pro review & teardown  (Read 7903 times)
    • Mike's Electric Stuff
« on: November 18, 2016, 11:30:00 pm »
Day Job: Mostly LEDs
The following users thanked this post: SeanB, SmartInfrared
Offline amyk
Re: Seek reveal Pro review & teardown
« Reply #1 on: November 19, 2016, 05:38:31 am »
I found it a bit funny that the high-FPS version's framerate is mentioned as ">15Hz" in their datasheet, and indeed 16 > 15. It still looks rather slow for good video though, and I wonder why, if they were going to be export-restricted anyway, they didn't go for the full 30Hz --- maybe due to processing to remove noise? It'd be interesting to see what raw signal the sensor outputs.
« Reply #2 on: November 19, 2016, 09:27:15 am »
Output rate from sensor appears to be 16Hz. The lag suggests they may be doing a moving avarage of a few frames
Offline encryptededdy
« Reply #3 on: November 20, 2016, 04:12:18 am »
As mentioned in the video comments, it looks like the frame rate increases significantly when you switch from full frame to normal mode.
Offline Fraser
« Reply #4 on: November 24, 2016, 07:19:06 pm »
Another interesting video Mike  :-+
Fraser
Offline SmartInfrared
« Reply #5 on: November 24, 2016, 11:59:24 pm »
Mike, the teardown process is very neat. thanks.  :)
Welcome to join in the Infrared Camera group in Facebook.
https://www.facebook.com/groups/InfraredCamera/
Offline Koen
« Reply #6 on: November 25, 2016, 12:03:31 am »
Thank you Mike but what would you then recommend for electronic debugging ? Thank you.
« Reply #7 on: November 25, 2016, 09:05:29 am »
Cheapest : Seek Compact pro - phone add-on, framerate very phone dependent
Most useful : Hacked FLIR E4 with lens adjust tool
