Author Topic: Seek Compact Pro python script?  (Read 9218 times)
Offline pauleddTopic starter
  • Riesige Gepanzerte Luftschiffe
« on: June 23, 2018, 07:48:36 am »
Hi there
Is there perhaps someone who has a ready to use python script for talking to the
Seek Compact Pro? I just want to output the raw frames, I dont care on palettes nor
other fancy after effects. There is already such a script for the normal Compact as I found here
but it seems its is alot different for the initialisation part and image dimension...
If not I will try to start step by step converting it here, maybe someone can help me with the stuff I dont understand..
« Last Edit: June 23, 2018, 07:59:25 am by pauledd »
human being - without Windows® - excuse my bad english
Re: Seek Compact Pro python script?
« Reply #1 on: June 24, 2018, 07:55:07 am »
Okay, I just start with the usb stuff and the initialisation routine.
for the send/receive order I follow the code used in libseek-thermal (SeekThermalPro.cpp):
import usb.core
import usb.util
#find Seek CompactPro device 289d:0011
dev = usb.core.find(idVendor=0x289d, idProduct=0x0011)
if not dev: raise ValueError('Device not found')
def send_msg(bmRequestType, bRequest, wValue=0, wIndex=0, data_or_wLength=None, timeout=None):
    assert (dev.ctrl_transfer(bmRequestType, bRequest, wValue, wIndex, data_or_wLength, timeout) == len(data$
# alias method to make code easier to read
receive_msg = dev.ctrl_transfer
def deinit():
    '''Deinit the device'''
    msg = '\x00\x00'
    for i in range(3):
        send_msg(0x41, 0x3C, 0, 0, msg)
# set the active configuration. With no arguments, the first configuration will be the active one
dev.set_configuration()
# get an endpoint instance
cfg = dev.get_active_configuration()
intf = cfg[(0,0)]
custom_match = lambda e: usb.util.endpoint_direction(e.bEndpointAddress) == usb.util.ENDPOINT_OUT
ep = usb.util.find_descriptor(intf, custom_match=custom_match)   # match the first OUT endpoint
assert ep is not None
# Setup device
try:
    msg = '\x01'
    send_msg(0x41, 0x54, 0, 0, msg)
    print "Setup try"
except Exception as e:
    deinit()
    msg = '\x01'
    print "Setup except"
# SET_OPERATION_MODE = 60; 0x41=send,0x3C=60
send_msg(0x41, 0x3C, 0, 0, '\x00\x00')
# GET_FIRMWARE_INFO = 78, 0x4E=78
ret1 = receive_msg(0xC1, 0x4E, 0, 0, 4)
print "GET_FIRMWARE_INFO=",ret1
# READ_CHIP_ID = 54, 0x36=54
ret2 = receive_msg(0xC1, 0x36, 0, 0, 12)
print "READ_CHIP_ID=",ret2
# SET_FACTORY_SETTINGS_FEATURES = 86 = 0x56
send_msg(0x41, 0x56, 0, 0, '\x06\x00\x08\x00\x00\x00')
# GET_FACTORY_SETTINGS = 88 = 0x58
ret3 = receive_msg(0xC1, 0x58, 0, 0, 12)
print "GET_FACTORY_SETTINGS=",ret3
# SET_FIRMWARE_INFO_FEATURES = 85 = 0x55
send_msg(0x41, 0x55, 0, 0, '\x17\x00')
# GET_FIRMWARE_INFO = 78 = 0x4E
ret4 = receive_msg(0xC1, 0x4E, 0, 0, 64)
print "GET_FIRMWARE_INFO=",ret4
send_msg(0x41, 0x56, 0, 0, '\x01\x00\x00\x06\x00\x00')
ret5 = receive_msg(0xC1, 0x58, 0, 0, 2)
print "GET_FACTORY_SETTINGS=",ret5
send_msg(0x41, 0x56, 0, 0, '\x01\x00\x01\x06\x00\x00')
ret6 = receive_msg(0xC1, 0x58, 0, 0, 2)
print "GET_FACTORY_SETTINGS=",ret6
This, so far outputs this and seems to work:
Setup try
GET_FIRMWARE_INFO= array('B', [1, 0, 3, 0])
READ_CHIP_ID= array('B', [6, 0, 16, 0, 141, 0, 211, 0, 93, 0, 209, 0])
GET_FACTORY_SETTINGS= array('B', [48, 54, 49, 48, 65, 49, 74, 85, 76, 68, 53, 52])
GET_FIRMWARE_INFO= array('B', [48, 120, 68, 49, 53, 68, 68, 51, 56, 68, 49, 48, 48, 54, 0, 0, 48, 54, 49, 48 65, 49, 74, 85, 76, 68, 53, 52, 0, 0, 0, 0, 121, 5, 0, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0])
GET_FACTORY_SETTINGS= array('B', [0, 0])
GET_FACTORY_SETTINGS= array('B', [1, 0])
Next part will be to Send read frame request...
In libseek-thermal this code comes next, which I dont fully understand yet:
uint16_t addr, addrle;
    uint8_t *addrle_p = reinterpret_cast<uint8_t*>(&addrle);
    for (addr=0; addr<2560; addr+=32) {
            addrle = htole16(addr); /* mind endianness */
            std::vector<uint8_t> data = { 0x20, 0x00, addrle_p[0], addrle_p[1], 0x00, 0x00 };
            if (!m_dev.request_set(DeviceCommand::SET_FACTORY_SETTINGS_FEATURES, data))
                return false;
            std::vector<uint8_t> data(64);
            if (!m_dev.request_get(DeviceCommand::GET_FACTORY_SETTINGS, data))
                return false;
            print_usb_data(data);
« Last Edit: June 24, 2018, 08:05:58 am by pauledd »
« Reply #2 on: June 24, 2018, 08:23:25 am »
obviously it loopes 2560 times in 32 step size, which should be 80 times, while
sending SET_FACTORY_SETTINGS_FEATURES requests with custom addrle_p[0], addrle_p[1] things that have to do with little endian...  ??? lets see if one can translate that somehow to python
« Reply #3 on: June 24, 2018, 09:41:34 am »
If my understanding is correct addr, addrle are unsigned int 0-65536. addrle is the little endian value
of addr, which is possibly can be made by this snipped of code:
addrle = '\\x' + '\\x'.join(x.encode('hex') for x in struct.pack('<I', addr))
Then addrle is c++ reinterpret-casted from uint16 to uint8?  ???
Currently dont know how to do that in python...
Offline tonykids
« Reply #4 on: June 24, 2018, 10:33:51 am »
Do not think that too much,it's simple :)
Just loop the "m_dev.request_set(DeviceCommand::SET_FACTORY_SETTINGS_FEATURES, data)" 80 times
and for each time the data byte array is
20 ,00 ,00 ,00 ,00 ,00<--the first time
20 ,00 ,20 ,00 ,00 ,00<--the second time
20 ,00 ,40 ,00 ,00 ,00
20 ,00 ,e0 ,00 ,00 ,00
20 ,00 ,00 ,01 ,00 ,00
20 ,00 ,20 ,01 ,00 ,00
20 ,00 ,c0 ,09 ,00 ,00
20 ,00 ,e0 ,09 ,00 ,00
<--the last time
Seehttps://www.eevblog.com/forum/thermal-imaging/windows-software-for-seek-pro-and-initial-commands/for more information
« Last Edit: June 24, 2018, 10:38:08 am by tonykids »
« Reply #5 on: June 24, 2018, 01:49:22 pm »
thanks a lot,I always tend to think to much :-DD  I put it in a dilettante loop...
import numpy as np
import struct
addrle = np.uint16(0)
t= '\\20\\x00'
for x in xrange(0,2560,32):
 addrle = '\\x' + '\\x'.join(x.encode('hex') for x in struct.pack('<I', x))
 a = t + addrle
 print a
gives me
\20\x00\x00\x00\x00\x00
\20\x00\x20\x00\x00\x00
\20\x00\x40\x00\x00\x00
\20\x00\x60\x00\x00\x00
\20\x00\x80\x00\x00\x00
\20\x00\xa0\x00\x00\x00
\20\x00\xc0\x00\x00\x00
\20\x00\xe0\x00\x00\x00
\20\x00\x00\x01\x00\x00
\20\x00\xe0\x09\x00\x00
now lets see if I can put it all together...
« Reply #6 on: June 24, 2018, 02:05:07 pm »
I tried this loop:
t= '\\20\\x00'
 a = t + addrle
 send_msg(0x41, 0x56, 0, 0, a)
 ret7 = receive_msg(0xC1, 0x58, 0, 0, 64)
 print "receive ok at x", x, " =", a
But I get a pipe error:
File "seek3.py", line 91, in <module>
  File "seek3.py", line 11, in send_msg
    assert (dev.ctrl_transfer(bmRequestType, bRequest, wValue, wIndex, data_or_wLength, timeout) == len(data_or_wLength))
  File "/usr/lib64/python2.7/site-packages/usb/core.py", line 1043, in ctrl_transfer
    self.__get_timeout(timeout))
  File "/usr/lib64/python2.7/site-packages/usb/backend/libusb1.py", line 883, in ctrl_transfer
    timeout))
  File "/usr/lib64/python2.7/site-packages/usb/backend/libusb1.py", line 595, in _check
    raise USBError(_strerror(ret), ret, _libusb_errno[ret])
usb.core.USBError: [Errno 32] Pipe error
I suspect I cannot simply add "a" to the end of the send_msg function?  ???
EDIT.. forgot one x in "t= '\\20\\x00'", but still get this error
EDIT2.. okay, sending only one "send_msg(0x41, 0x56, 0, 0, '\x20\x00\x00\x00\x00\x00')" succeeded without error...
« Last Edit: June 24, 2018, 03:38:25 pm by pauledd »
« Reply #7 on: June 24, 2018, 04:47:23 pm »
I dont get it, I first thought the double backslash would make trouble so I formated those parts as "raw" with that r"\x", then before I do send_msg I print the string and it looks fine again in the output but send_msg then failed... do I miss any timing parameter  ??? Because it says "self.__get_timeout(timeout))"...
 addrle = r"\x" + r"\x".join(x.encode('hex') for x in struct.pack('<I', x))
 print str(r'\x20\x00') + addrle
 send_msg(0x41, 0x56, 0, 0, str(r'\x20\x00') + addrle)
Traceback (most recent call last):
  File "seek3.py", line 92, in <module>
  File "seek3.py", line 12, in send_msg
    timeout))
« Reply #8 on: June 24, 2018, 05:51:48 pm »
hmm, seems to be  a timing issue?  :-//
If I send
send_msg(0x41, 0x56, 0, 0,' \x20\x00\x00\x00\x00\x00 ')
send_msg(0x41, 0x56, 0, 0,' \x20\x00\x20\x00\x00\x00 ')
send_msg(0x41, 0x56, 0, 0,' \x20\x00\x40\x00\x00\x00 ')
without looping I get no error, BUT just one more send_msg produces the error...
So I can send only 3 of those requests
« Reply #9 on: June 24, 2018, 06:12:18 pm »
next progress... I removed the whitespaces between the data:
send_msg(0x41, 0x56, 0, 0,'\x20\x00\x00\x00\x00\x00')
send_msg(0x41, 0x56, 0, 0,'\x20\x00\x20\x00\x00\x00')
send_msg(0x41, 0x56, 0, 0,'\x20\x00\x40\x00\x00\x00')
Now I get no more errors, but without loop, I manually filled the 80 sends... seems to be indeed a formatting problem in the loop...
« Reply #10 on: June 25, 2018, 06:59:24 am »
I leave that weired loop and use the 80x send_msg/receive_msg, after that I now continue
with the four remaining commands:
send_msg(0x41, 0x55, 0, 0,'\x15\x00')
ret7 = receive_msg(0xC1, 0x4E, 0, 0, 64)
# SET_IMAGE_PROCESSING_MODE = 62 = 0x3E
send_msg(0x41, 0x3E, 0, 0,'\x08\x00')
# SET_OPERATION_MODE = 60 = 0x3C
send_msg(0x41, 0x3C, 0, 0,'\x01\x00')
then the first frame should be taken...
« Reply #11 on: June 25, 2018, 08:12:00 am »
Just a little bit offtopic, there seems to be a new Seek Thermal App Version 2.1.2, looks like there is new Firmware in it?
« Reply #12 on: June 25, 2018, 02:35:46 pm »
After the last command "SET_OPERATION_MODE" I send this to start image transfer:
# START_GET_IMAGE_TRANSFER = 83 = 0x53
send_msg(0x41, 0x53, 0, 0,'\x58\x5B\x01\x00')
so far so good...
now for receiving the first frame I need to send a bulk transfer command, and thats where my knowlege stops...
in the python script for the "Compact" they use this command:
ret9  = dev.read(0x81, 0x3F60, 1000)
ret9 += dev.read(0x81, 0x3F60, 1000)
I am going to think to much again  ;D :
I am not yet sure how to translate that to the "CompactPro", because the second parameter (size?) of cause differs for the Compact Pro, and it looks like they assemble the frame by appending 4 readings ??? ?  0x3F60 is 16224... 4 times is 64896... the raw size of the "Compact" is 208x156=32448 and that's half of 64896... so 4 readings are two raw frames?
Given that the "CompactPro" has 342x260=88920 raw size, half of that would be 44460 (0xADAC). So sending 4x 0xADAC...  :-//
Offline tonykids
« Reply #13 on: June 26, 2018, 02:42:44 am »
Hey, it's me again ;D
0x3F60 is just because the usb bulktransfer can only transfer a maximum of 16384(0x4000) bytes data every time.
So if your data is more than 16384 bytes,you should read in 16384 bytes(or less)  several times until you get all your data.
« Reply #14 on: June 26, 2018, 06:36:56 am »
hhmmokaay  ;D, thanks. So I will do again some calculations, just to make it clear in my little head:
A full raw frame is 342x260=88920 pixels. Each pixel can have a value of 0-65536, 16bit. That is 88920*16=1422720bit or /8 = 177840 bytes per frame. Given your 16384 bytes max packet size I would assume I have to read 177840/16384=10,8 (11) times to get a full frame ??? Okay I will try that and report back...
Offline IwuzBornanerd
« Reply #15 on: June 26, 2018, 07:25:06 am »
I think the "correct" way, or  maybe the generic way is to do the transfers in a loop wherein you start by asking for the full frame & then after each transfer subtract the number of bytes transferred from the number remaining prior to that transfer and ask for the new remainder each time.  I saw this in someone else's code and implemented it in my own C code.  This works for both the pro & non-pro cameras, but for some reason on the Raspberry Pi the non-pro works better if I ask for a quarter frame each time--otherwise I can get timeout errors  on the first request.  I get timeouts with the pro regardless (on any request), particularly with the timeout set at less than 1sec (1sec seems ridiculous when expecting 8fps or more).  I have not found a "happy" number of bytes to request.
The non-pro ALWAYS sends a frame in 4 chunks regardless of how many bytes I ask for .  The pro does not seem to care how many bytes are requested either.  What I see with my oscilloscope is that with my software the pro sends a frame in 13 or sometimes 14 chunks, but with the Seek apk running [poorly] under Lineage OS on my Raspberry Pi 3B the pro sends a frame in 9 or 10 chunks.
I am not opposed to exercise, unless it is an exercise in futility.
« Reply #16 on: June 26, 2018, 07:44:52 am »
hm, okay. I just watched the Seek App (Android) in my emulator with wireshark, I get 13 chunks everytime...
« Reply #17 on: June 26, 2018, 07:54:33 am »
Okay, that makes sense, it receives 13x13744bytes data, but I gess thats with headers...
The URB length is 13680 and that is *13 = 177840 = full frame.
Offline tonykids
« Reply #18 on: June 26, 2018, 08:23:28 am »
You are right, that's my fault, I mixed 16384 with 13680 :palm:
And  @IwuzBornanerd's suggestion is  :-+
« Reply #19 on: June 26, 2018, 08:48:24 am »
No problem  ;),
So I looped until my frame list (just leaned that python uses lists  ;D) fills to 177840:
frame = []
while (len(frame) <= 163648):
frame += dev.read(0x81, 0x3570, 1000)
print "frame len=", len(frame)
outputs:
frame len= 13168
frame len= 26848
frame len= 40528
frame len= 54208
frame len= 67888
frame len= 81568
frame len= 95248
frame len= 108928
frame len= 122608
frame len= 136288
frame len= 149968
frame len= 163648
frame len= 177328
but what next? I printed the first frame just for fun and noticed that all values in it are 0-255. It starts like that:
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 00, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 2, 0,  0, 0, 0, 0, 0, 0, 0, 0, 212, 55, 133, 5, 0, 0, 0, 0, 0, 0, 0, 1, 164, 1, 102, 3, 88, 17, 190, 00, 0, 0, 0, 0, 0, 108, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 00, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0........
Now the next thing would be to start looking for the frame_counter/frame_id... for that "CompactPro" that should be in byte 1 and 2. But in the list I only see zero's  ???
« Reply #20 on: June 26, 2018, 09:46:22 am »
I also noticed that I miss 12 512 bytes from the first bulk return  ???
« Last Edit: June 26, 2018, 09:53:34 am by pauledd »
« Reply #21 on: June 26, 2018, 10:32:00 am »
just digging further  ;D. I observed the usb capture while running the libseek-thermal application. It sometimes also receives 512 bytes less in the first package. Then it repeates the initialisation sequence and in the next run it seems to get the full size... I will try to consider that in my code...
« Reply #22 on: June 26, 2018, 11:56:11 am »
I possibly found the source of the missing 512 bytes. I guess this comes from not releasing the usb device claim that has been done at top of the script. So I added the following at the end of my script where I beleave the dispose command is the important one:
send_msg(0x41, 0x3C, 0, 0,'\x00\x00')
usb.util.dispose_resources(dev)
With that almost all bulk transfers start with the full size, now I can continue to find the frame id/counter position
« Reply #23 on: June 26, 2018, 01:28:39 pm »
some progress. I just tried a loop to read a full frame and then print the values at frame[2] and frame[4].
while True:
frame = []
frame = dev.read(0x81, 0x3570, 0x3E8)
frame += dev.read(0x81, 0x3570, 0x3E8)
print frame[2], frame[4]
Thats the first time I hear the shutter clicking  ;D and I get output with an increasing number that is hopefully indeed the frame counter
and another number that first goes stupid but then settles at value 3 and everytime the shutter clicks it changes ..3/6/5/1/3...
3 9
5 14
7 8
9 7
11 5
26 6
28 5
30 1
33 3
35 3
37 3
39 3
41 3
43 3
45 3
47 3
49 3
51 3
53 3
55 3
57 3
59 3
61 3
63 3
65 3
67 3
69 3
72 6
74 5
76 1
79 3
81 3
83 3
85 3
« Reply #24 on: June 26, 2018, 08:39:26 pm »
But your camera is a non-fast frame unit, correct?  OR does the Seek app identify it as Seek Compact PRO FF (like it does with my camera)?
The first 5 frames, status numbers 4, 9, 14, 8 & 7 seem to be related to calibration.  I (and maybe only I) believe that the status 9 frame is the thermistor curve for the sensor; basically a lookup table for determining the temperature of a pixel and that is how I use it in my code.
