It's very sad that there is not a universal naming convention, but it really comes about because of the multiple fields that utilize the EO/IR spectrum. CIE recomends a FAR UV, UV-C, UV-B, UV-A, VIS, IR-A, IR-B, and IR-C; Astrophysics has Extreme UV, Lya, FarUV, MidUV, NearUV, VIS, NIR, Mid-IR and Far Infrared (FIR); Atmospheric Science has UV-C, UV-B, UV-A, VIS, NIR, IR, Thermal Infrared, and Far Infrared; Military is Vacuum UV, UV-C, UV-B, Solar Blind UV, UV-A, VIS, NIR, SWIR, MWIR, LWIR, and FIR That's just the four groups I can remember off the top of my head.
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
My Avatar picture makes sense now
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
As you can imagine, almost none of them define the spectral bands the same way ... even when the name is identical.
From what I can tell, most IR camera vendors lean toward the military convention at least MW and LW.
Side note: Inframetrics did something similar to Agema. Their 760's were name SW, LW, and BB for their cameras. However the SW was nominal 3-5um, LW was nominal 8-12um, and the BB was a nominal 3-12um
