Fired up a ratheon camera from the 90's and after getting the chopper wheel freed up and spinning, it makes a nice image! Issue is there is a large gray block in the display, and I am pretty inexperienced to know if this is something on the detector side or the display side of this device, I have attached some images of the boards, I suspect there could be damage in any number of the ribbon cables, but not sure how to know without probing each line of each ribbon. First post, very long time lurker! Thanks for any input
