Hello my name is Dimitri and I’m in serious problem…
So as the title say I try to update the firmware on my uti260b and now it is stuck at 100%
If try to open the device and use the pins to uart, want to ask you if im able to root shell to the device with r/w and replace the UTI260B_THERMAL file firmware app that is cause the problem i think because boot goes ok, torch is open and close and device charge ok.
Waiting for reply’s like a kid his 🍭
Many thanks
