UPDATE: Thermal-Camera-Redux reported working on: Topdon TC001, InfiRay P2 Pro, MaAnt Super IR Cam
2024-01-25: Version 0.9.2 modifications have been pushed to github to optionally lock out camera's colormap auto-ranging.
2024-01-18: Version 0.9.1 modifications have been pushed to github for weak and single threaded/single core hardware.
https://github.com/92es/Thermal-Camera-ReduxThe ability to lock the camera's colormap auto ranging has been pushed to the github repository.The user can optionally enable / disable auto ranging.
The user can optionally cycle through temperature pixel to color pixel mapping methods.
These mapping methods are a WIP and may change over time with user feedback.
The 'l' key cycles between unlocked, static band pass and dynamic band pass.
Static band pass will clip temps outside of the band pass range established at the time the lock was set.
Dynamic band pass will dynamically grow, but not shrink from the time the lock was set.
The 'i' and 'k' keys will allow the user to cycle through mapping options. No mapping is also included in the cycle so one can view the default images as displayed in the first row below.
The left or top window ( normally the image window ) will display the range locked view while the right or bottom ( normally thermal window ) will display the live auto-ranging for side-by-side real time comparison.
The user can optionally display any of the single and double window layouts as before as well as change colormaps or any other configuration option.
Note 1: Colormap / Mapping permutations vary in utility.
Note 2: This feature utilizes more CPU cycles and will be optimized over time. Plan accordingly for entry level SBCs.
In offline mode, the right/bottom window will display the same mapping methods when locking is enabled for offline use of these maps.
Here are some example permutations:Image and Thermal windows with Auto Ranging Disabled ( or map option 0 ):Locked and Unlocked windows with the left window using mapping option 1Locked and Unlocked windows with the left window using mapping option 5Please post any feedback you may have. It will be greatly appreciated.
