Author Topic: RPi/SBC/Topdon TC001/clone Tester request (Thermal Camera Redux v0.9.3) Github  (Read 61775 times)
Offline G28Topic starter
    • Thermal Camera Redux
Great job, It compiled easily on my MacBook Pro running Linux Mint, and displays a great image from my P2 Pro.
Thanks
(Attachment Link)
Great.  Please post or PM any issues that you may encounter so I can try to address them.
« Last Edit: January 10, 2024, 03:15:21 pm by G28 »
For those running Linux, you might be interested in the tuned-adm package.
It controls your PC's scheduling and thread frequency SpeedStep controls providing a lot of profile options.
I usually switch between "desktop" and "latency-performance".
When regression testing with a long duration redirected stdin command script, "latency-performance" and unrestricted offline FPS (-fps 900), the "latency-performance" setting finishes the script [3-5]X faster.
It may also be useful for your general purpose Linux use and performance targeted projects.
Available profiles:
- accelerator-performance     - Throughput performance based tuning with disabled higher latency STOP states
- atomic-guest                - Optimize virtual guests based on the Atomic variant
- atomic-host                 - Optimize bare metal systems running the Atomic variant
- balanced                    - General non-specialized tuned profile
- cpu-partitioning            - Optimize for CPU partitioning
- default                     - Legacy default tuned profile
- desktop                     - Optimize for the desktop use-case
- desktop-powersave           - Optmize for the desktop use-case with power saving
- enterprise-storage          - Legacy profile for RHEL6, for RHEL7, please use throughput-performance profile
- hpc-compute                 - Optimize for HPC compute workloads
- intel-sst                   - Configure for Intel Speed Select Base Frequency
- laptop-ac-powersave         - Optimize for laptop with power savings
- laptop-battery-powersave    - Optimize laptop profile with more aggressive power saving
- latency-performance         - Optimize for deterministic performance at the cost of increased power consumption
- mssql                       - Optimize for MS SQL Server
- network-latency             - Optimize for deterministic performance at the cost of increased power consumption, focused on low latency network performance
- network-throughput          - Optimize for streaming network throughput, generally only necessary on older CPUs or 40G+ networks
- optimize-serial-console     - Optimize for serial console use.
- oracle                      - Optimize for Oracle RDBMS
- postgresql                  - Optimize for PostgreSQL server
- powersave                   - Optimize for low power consumption
- realtime                    - Optimize for realtime workloads
- realtime-virtual-guest      - Optimize for realtime workloads running within a KVM guest
- realtime-virtual-host       - Optimize for KVM guests running realtime workloads
- sap-hana                    - Optimize for SAP HANA
- sap-netweaver               - Optimize for SAP NetWeaver
- server-powersave            - Optimize for server power savings
- spectrumscale-ece           - Optimized for Spectrum Scale Erasure Code Edition Servers
- spindown-disk               - Optimize for power saving by spinning-down rotational disks
- throughput-performance      - Broadly applicable tuning that provides excellent performance across a variety of common server workloads
- virtual-guest               - Optimize for running inside a virtual guest
- virtual-host                - Optimize for running KVM guests
Current active profile: desktop
« Last Edit: January 10, 2024, 10:57:36 pm by G28 »
The following users thanked this post: cynfab, Amish Technician
Offline RO
So far I have Thermal Camera Redux working on the following Pis with the 2023-12-05 release of Raspberry Pi OS desktop 64-bit (Debian 12 bookworm):
 :) RPi 2 Model B v1.2       BCM2837      ARMv8-A     (64/32-bit)   4× Cortex-A53 900 MHz   CFLAGS='-mcpu=cortex-a53 -pipe -fomit-frame-pointer'
 :) RPi 3 Model B v1.2       BCM2837B0  ARMv8-A     (64/32-bit)   4× Cortex-A53 1.4 GHz    CFLAGS='-mcpu=cortex-a53 -pipe -fomit-frame-pointer'
 :) RPi Zero 2 W                BCM2710A1  ARMv8-A     (64/32-bit)   4× Cortex-A53 1 GHz       CFLAGS='-mcpu=cortex-a53 -pipe -fomit-frame-pointer'
 :D RPi 4                             BCM2711       ARMv8-A    (64/32-bit)   4× Cortex-A72 1.8 GHz    CFLAGS='-mcpu=cortex-a72 -pipe -fomit-frame-pointer'
 ;D RPi 5                             BCM2712      ARMv8.2-A  (64/32-bit)   4× Cortex-A76 2.4 GHz    CFLAGS='-mcpu=cortex-a76 -pipe -fomit-frame-pointer'
Performance is very good on the pi4 at x4 scale, x5 slightly reduces the frame rate. It's especially good on pi5 up to x5, and still keeps the responsiveness and frame rate usable up to x7. It's very responsive on the others as well so long as you stay at 3x scale or lower, x4 is still usable with a frame rate ~20.
Well done  :-+
I am trying to achieve the same on the RPi Zero 2 W
I have installed Raspberry Pi OS desktop 64-bit without trouble but keep running into errors when installing OpenCV
Do you have any advice on the install?
- Compiling the source on the Pi (cmake)
- Memory increased to plentifull with swapfile
- Have added the contrib modules
- Cmake on all 4 cores -j4
Would also be interested in your -D flags
Thanks!
Offline Amish Technician
The initial github release has noticeably improved performance on the RPi Zero v1.3 compared to the last version I tried on it, I saw FPS up to 16.9 with no HUD, 13.8 with the default HUD.
The early pre multi threading version does indeed perform much worse. I wonder if a single threaded version of the current release with the numerous performance tweaks and improvements would run better on the single core single thread CPU of the Pi Zero.
The optional flags are a very useful addition.  :-+
Arrow keys aren't doing anything for me, I tried with two different keyboard, both were laptop style without a num-pad however. I will try again with a full size keyboard.
RPi Zero v1.3
Launch times consistently repeatable within 0.1 seconds (repeated at least 3 times)
- Offline 11.6s to display key bindings in stdout, 13.7s to display image
- Online 12.3s to display key bindings in stdout, 16.0s to display image, or 15.0s with flag -scale 1
- FPS noticably improved at 1x, including with duel window layouts and rulers enabled, though dragging rulers reduces to ~1fps
- No image artifacts
main:thrm:img (0.05 : 0.41 : 0.54) scale 1 fps 13.9 read 3.25 rot 4.89 : [5.17 | 38.93 | 51.02] + 3.83 67.35 12.50 OFF ON
main:thrm:img (0.06 : 0.42 : 0.52) scale 1 fps 13.9 read 1.69 rot 4.40 : [5.08 | 35.54 | 43.41] + 3.30 58.31 11.61 OFF ON
main:thrm:img (0.06 : 0.43 : 0.51) scale 1 fps 13.8 read 1.67 rot 4.39 : [5.11 | 35.78 | 43.24] + 3.27 58.55 12.04 OFF ON
main:thrm:img (0.06 : 0.42 : 0.52) scale 1 fps 13.8 read 1.66 rot 4.42 : [4.78 | 35.58 | 43.40] + 3.29 58.58 11.89 OFF ON
main:thrm:img (0.06 : 0.43 : 0.51) scale 1 fps 13.8 read 1.69 rot 4.42 : [5.22 | 36.08 | 43.13] + 3.27 58.57 12.16 OFF ON
main:thrm:img (0.06 : 0.42 : 0.52) scale 1 fps 13.8 read 1.63 rot 4.43 : [4.66 | 34.81 | 42.98] + 3.28 57.85 11.58 OFF OFF
main:thrm:img (0.05 : 0.40 : 0.55) scale 1 fps 13.9 read 1.70 rot 4.24 : [3.49 | 30.29 | 41.10] + 3.32 53.89 9.47 OFF OFF
main:thrm:img (0.05 : 0.41 : 0.55) scale 1 fps 14.0 read 1.71 rot 4.28 : [3.46 | 30.39 | 40.62] + 3.32 53.62 9.68 OFF OFF
main:thrm:img (0.05 : 0.40 : 0.55) scale 1 fps 14.1 read 1.66 rot 4.20 : [3.44 | 30.15 | 40.97] + 3.32 53.97 9.68 OFF OFF
main:thrm:img (0.05 : 0.41 : 0.55) scale 1 fps 14.2 read 1.72 rot 4.21 : [3.47 | 30.24 | 40.82] + 3.34 53.62 9.46 OFF OFF
main:thrm:img (0.05 : 0.40 : 0.55) scale 1 fps 14.2 read 1.69 rot 4.19 : [3.47 | 30.09 | 40.83] + 3.36 53.84 9.65 OFF OFF
main:thrm:img (0.05 : 0.40 : 0.55) scale 1 fps 14.2 read 1.66 rot 4.24 : [3.44 | 30.14 | 40.86] + 3.32 53.89 9.71 OFF OFF
main:thrm:img (0.05 : 0.41 : 0.55) scale 1 fps 14.3 read 1.65 rot 4.24 : [3.47 | 30.22 | 40.92] + 3.30 53.76 9.54 OFF OFF
main:thrm:img (0.05 : 0.41 : 0.55) scale 1 fps 14.3 read 1.64 rot 4.26 : [3.36 | 30.20 | 40.77] + 3.33 53.98 9.88 OFF OFF
main:thrm:img (0.05 : 0.41 : 0.55) scale 1 fps 14.3 read 1.65 rot 4.27 : [3.38 | 30.20 | 40.80] + 3.31 53.83 9.73 OFF OFF
main:thrm:img (0.04 : 0.41 : 0.55) scale 1 fps 14.4 read 1.64 rot 4.30 : [3.19 | 30.20 | 40.91] + 3.31 54.06 9.83 OFF OFF
main:thrm:img (0.05 : 0.41 : 0.54) scale 1 fps 14.8 read 2.37 rot 6.12 : [4.93 | 44.59 | 59.25] + 4.76 78.19 14.18 OFF OFF
main:thrm:img (0.05 : 0.41 : 0.55) scale 1 fps 14.8 read 1.68 rot 4.24 : [3.39 | 30.16 | 40.64] + 3.29 53.63 9.69 OFF OFF
main:thrm:img (0.05 : 0.41 : 0.55) scale 1 fps 14.7 read 1.69 rot 4.29 : [3.46 | 30.54 | 41.22] + 3.35 54.13 9.55 OFF OFF
main:thrm:img (0.05 : 0.41 : 0.55) scale 1 fps 14.7 read 1.72 rot 4.24 : [3.36 | 30.05 | 40.66] + 3.30 53.43 9.46 OFF OFF
main:thrm:img (0.04 : 0.41 : 0.55) scale 1 fps 14.7 read 1.65 rot 4.27 : [3.21 | 30.27 | 40.75] + 3.35 53.92 9.82 OFF OFF
main:thrm:img (0.04 : 0.40 : 0.55) scale 1 fps 14.7 read 1.65 rot 4.21 : [3.35 | 30.19 | 41.03] + 3.30 53.90 9.57 OFF OFF
main:thrm:img (0.02 : 0.41 : 0.58) scale 1 fps 17.0 read 2.27 rot 5.79 : [1.28 | 33.17 | 46.69] + 4.47 63.29 12.13 OFF NO_DRAWINGS
main:thrm:img (0.00 : 0.41 : 0.59) scale 1 fps 16.9 read 1.68 rot 4.36 : [0.03 | 22.37 | 32.67] + 3.41 45.28 9.20 OFF NO_DRAWINGS
main:thrm:img (0.00 : 0.41 : 0.59) scale 1 fps 16.9 read 1.65 rot 4.46 : [0.02 | 22.35 | 32.73] + 3.40 45.00 8.87 OFF NO_DRAWINGS
main:thrm:img (0.00 : 0.41 : 0.59) scale 1 fps 16.9 read 1.68 rot 4.44 : [0.03 | 22.72 | 32.99] + 3.38 45.24 8.86 OFF NO_DRAWINGS
main:thrm:img (0.00 : 0.41 : 0.59) scale 1 fps 16.9 read 1.64 rot 4.44 : [0.02 | 22.54 | 32.68] + 3.40 44.98 8.90 OFF NO_DRAWINGS
main:thrm:img (0.00 : 0.41 : 0.59) scale 1 fps 16.9 read 1.66 rot 4.41 : [0.03 | 22.57 | 32.87] + 3.42 45.39 9.10 OFF NO_DRAWINGS
main:thrm:img (0.00 : 0.41 : 0.59) scale 1 fps 16.9 read 1.72 rot 4.39 : [0.03 | 22.43 | 32.75] + 3.41 45.04 8.88 OFF NO_DRAWINGS
RPi 2 v1.1
- Online 3.6s to display key bindings in stdout, 5.2s to display image.
For comparison 3.7s and 5.9 with release 16.
- At 2x scale shimmering horizontal bands, similar to a poorly tracking VHS tape
- At 1x perfect 25 FPS, bands still present but far less noticeable, shimmering much less.
I will try to work out the best way to send a recording of this, creating a gif to post here lost too much detail to be of any use and I suspect video hosting sites like youtube would do something similar when they trans-code it.
main:thrm:img (0.03 : 0.25 : 0.71) scale 2 fps 15.6 read 2.43 rot 2.53 : [2.15 | 16.93 | 47.82] + 2.05 52.91 3.04 OFF ON
main:thrm:img (0.03 : 0.26 : 0.71) scale 2 fps 15.7 read 1.01 rot 2.54 : [2.19 | 17.59 | 48.60] + 2.27 54.42 3.56 OFF ON
main:thrm:img (0.03 : 0.25 : 0.72) scale 2 fps 16.0 read 0.99 rot 2.53 : [2.06 | 16.76 | 47.45] + 1.99 52.51 3.07 OFF ON
main:thrm:img (0.03 : 0.25 : 0.72) scale 2 fps 16.1 read 0.99 rot 2.53 : [1.97 | 16.69 | 47.79] + 1.93 52.57 2.85 OFF ON
main:thrm:img (0.03 : 0.25 : 0.71) scale 2 fps 16.1 read 1.00 rot 2.54 : [2.15 | 17.18 | 48.20] + 2.00 53.21 3.01 OFF ON
main:thrm:img (0.03 : 0.25 : 0.72) scale 2 fps 16.2 read 0.98 rot 2.47 : [2.07 | 16.54 | 47.24] + 1.96 52.50 3.30 OFF ON
main:thrm:img (0.06 : 0.27 : 0.68) scale 2 fps 15.8 read 1.98 rot 4.92 : [7.77 | 37.31 | 95.40] + 3.86 106.14 6.88 BOTH ON
main:thrm:img (0.07 : 0.28 : 0.65) scale 2 fps 15.7 read 1.02 rot 2.57 : [5.45 | 21.20 | 49.90] + 1.94 55.98 4.15 BOTH ON
main:thrm:img (0.07 : 0.27 : 0.66) scale 2 fps 15.7 read 0.99 rot 2.51 : [5.35 | 20.41 | 49.19] + 2.02 55.26 4.05 BOTH ON
main:thrm:img (0.07 : 0.27 : 0.66) scale 2 fps 15.7 read 0.99 rot 2.48 : [5.24 | 20.57 | 49.31] + 1.99 55.09 3.80 BOTH ON
main:thrm:img (0.07 : 0.27 : 0.66) scale 2 fps 15.7 read 0.99 rot 2.58 : [5.32 | 20.55 | 49.67] + 1.96 55.77 4.13 BOTH ON
main:thrm:img (0.07 : 0.27 : 0.66) scale 2 fps 15.7 read 0.98 rot 2.54 : [5.34 | 20.70 | 50.25] + 1.95 56.16 3.97 BOTH ON
main:thrm:img (0.07 : 0.27 : 0.65) scale 1 fps 15.7 read 1.43 rot 2.50 : [5.32 | 20.10 | 47.98] + 1.95 53.81 3.89 BOTH ON
main:thrm:img (0.12 : 0.39 : 0.48) scale 1 fps 25.0 read 17.72 rot 2.39 : [4.50 | 14.59 | 17.89] + 1.20 21.53 2.44 BOTH ON
main:thrm:img (0.12 : 0.39 : 0.48) scale 1 fps 25.0 read 16.00 rot 2.34 : [4.45 | 14.10 | 17.25] + 1.07 20.76 2.44 BOTH ON
main:thrm:img (0.13 : 0.39 : 0.48) scale 1 fps 25.0 read 15.88 rot 2.28 : [4.74 | 14.52 | 17.61] + 1.06 20.99 2.32 BOTH ON
main:thrm:img (0.13 : 0.40 : 0.47) scale 1 fps 25.0 read 15.70 rot 2.25 : [4.79 | 14.65 | 17.30] + 1.09 20.89 2.51 BOTH ON
main:thrm:img (0.13 : 0.39 : 0.48) scale 1 fps 25.0 read 15.53 rot 2.30 : [4.83 | 14.49 | 17.52] + 1.13 21.22 2.57 BOTH ON
main:thrm:img (0.13 : 0.40 : 0.48) scale 1 fps 25.0 read 15.10 rot 2.36 : [4.67 | 14.76 | 17.74] + 1.12 21.35 2.50 BOTH ON
main:thrm:img (0.12 : 0.39 : 0.49) scale 1 fps 25.0 read 15.93 rot 2.31 : [4.41 | 14.06 | 17.46] + 1.07 20.75 2.21 BOTH ON
main:thrm:img (0.13 : 0.40 : 0.47) scale 1 fps 25.0 read 16.13 rot 2.24 : [4.72 | 14.61 | 17.26] + 1.09 20.72 2.37 BOTH ON
main:thrm:img (0.13 : 0.39 : 0.48) scale 1 fps 25.0 read 15.85 rot 2.27 : [4.56 | 14.25 | 17.52] + 1.08 20.88 2.28 BOTH ON
main:thrm:img (0.12 : 0.40 : 0.47) scale 1 fps 25.0 read 15.71 rot 2.30 : [4.61 | 14.86 | 17.42] + 1.07 21.08 2.59 BOTH ON
Well done  :-+
Thanks!
I installed the "libopencv-dev" package from the Debian stable repo
sudo apt install libopencv-dev
Here is my build script:
#!/bin/bash
# Build Thermal Camera Redux
echo "Building redux and test_driver ..."
rm ./redux
# RPi Zero 2 W
DEFAULT_FLAGS='-DDEFAULT_FONT=0 -DDEFAULT_COLORMAP=4 -DROTATION=0 -DDISPLAY_WIDTH=1920 -DDISPLAY_HEIGHT=1080 -DUSE_CELSIUS=1 -DHUD_ALPHA=0.4'
# Compile and link Redux Thermal Camera code
g++ -Wall -Wextra -O3 -ffast-math ${DEFAULT_FLAGS} ${CFLAGS} -DUSE_ASSERT=0 -I/usr/include/opencv4 tc001.cpp thread.cpp -o redux -lpthread `pkg-config --cflags --libs opencv4`
gcc -Wall test_driver.c -o test_driver
Hope this helps.
Sincerely,
Amish Tech.
The following users thanked this post: RO
Amish Tech,
Thanks for the detailed update.
RPi Zero v1.3:
- The 11.6s and 12.3s to printKeyBindings() is disturbing.  The only thing that is going on is argv parsing, a few variable declarations and opening either the camera or file.  I would guess the lag is opening the disk/device since neither invokes a data read until after printing the key bindings.  The initial GUI window creation is done next.  Loading from disk could also be an issue.  I assume you are starting the program from a SD card ?
I can add some startup timing stats to zero in on the worst offenders including the load from disk.
A single threaded -D flag is possible with some rework.  From the logs, the processing of the image sub-frame and thermal sub-frame are taking the lion's share of the time.  The 3rd thread is waiting idle most of the time.  On the PC, all 3 are pretty evenly loaded.  The 3rd column from the end shows that there is a significant amount of time waiting for threads to sync where a single thread would eliminate those waits.
The latest github release logs gives a more accurate picture of how long the camera reads actually take.  The "read n.nn" column looks fairly well.  Before, the read timing also included the waits on the camera's FPS rates.
RPi 2 v1.1:
Horizontal banding.  Have you tried using the "r" key to see if the banding shows up in the recorded .avi file ?  It might help isolate the problem if it shows up in the composited video/graphic image, or OpenCV's display.
If it doesn't show up in the .avi file, you might be able to use the Linux "peek" command to record a GIF file if peek is available on the Pi.
The 3rd last column waits appear more reasonable compared to the Zero 1.3, but it appears there is still some uneven thread loading with the image thread taking the longest.  I could swap some of the work loads between the thermal and image threads if the lag is in the rendering stages or dump some into the main thread.
I added some function pointers in the last release and was thinking about doing realtime smart thread loading by monitoring the thread stats and then swapping loads in realtime to balance the aggregate load based on hardware capabilities.
Also, the Zero 1.3 appear to take twice as long for OpenCV to show the prepared 1X frames vs the 2X frames on the Pi 2 v1.1, a factor of 4X slower considering the frame size delta.
How were the font and ruler displays at 1X and 2X ?
Were they more or less legible than the December release ?
Was there any temp text-flickers ?
Thanks much.
Another idea for the RPi Zero v1.3.
I could reduce the resolution of the ruler drag.  Right now it is plotting 256 landscape points and 192 portrait points.  During drag, I could half or quarter that resolution and then return to full resolution at the end of the drag.
What is the frame rate of dragging just 1 text temp and just the cross hair of text temps without the line plots ?  If they are reasonable, decreasing the resolution of the line plots during drag will help.
« Last Edit: January 12, 2024, 03:45:55 am by G28 »
The following users thanked this post: Amish Technician
Offline RO
Ah yes, I have been compiling opencv from the github as the repository is quite outdated and I read using apt might induce future problems when updating. (or if updating)
But thanks! that should get me started.
RPi Zero v1.3:
Yes the whole system runs from a micro sd card, I have two that I've been using for testing. The legacy 32bit Pi OS is on a slower class 4 16GB kingston card which I've used for the Zero v1.3 and 2 v1.1 while the rest of the 64bit models have been tested with a nearly new Samsung pro endurance 256GB U3 card. I'm going to have to borrow another one of those from another project and test again to eliminate the sd card differences. I have about a dozen cards for the RPIs now but still never have any spare  ::)
RPi2 v1.1
Recorded .avi file attached
« Last Edit: January 12, 2024, 04:39:12 pm by Amish Technician »
RPi Zero v1.3:
RPi2 v1.1
Thanks for the feedback and .avi file.
PM's and test mods sent.
The test mods also includes startup timing logs to see where the startup time is spent.
Note: I've just received the 'FAST_DRAG DRAW_SINGLE_THREAD' as I was about to post this message, thank you  :-+ Will provide feedback on it probably tomorrow.
I've cloned the slower SD card onto a faster card identical to the one I've used for 64bit models (purchased at the same time late last year so they shouldn't slow down due to wear). I overlooked the impact this could have as I'd incorrectly assumed the difference would be negligible for an app that's ~140KB compiled, but it appears to have improved things a bit, for RPi2 v1.1 especially.
RPi Zero v1.3
- Offline 11.8s to display key bindings in stdout, 13.9s to display image
- Online 12.1s to display key bindings in stdout, 15.8s to display image, or 15.0s with flag -scale 1
Online -scale 1
FPS taken after reset from at least 3 readings in stdout .
x1 double 10.9fps dragging single temperature point around with status hud disabled
x1 13.9fps dragging single temperature point around with status hud enabled
x1 double 10.3fps dragging both rulers around with status hud disabled
x1 double 9.7fps dragging both rulers around with status hud enabled
x1 14.6fps dragging both rulers around with status hud disabled
x1 13.7fps dragging both rulers around with status hud enabled
These fps figures for online are all far better than I had expected as they feel like ~2fps because all the frames come at once and then it freezes for ~0.5s, unless you drag slowely and then it's a relativly consistent stuttery update rate. Perhaps the best option for weaker CPUs is to disable dragging things and have it click to position only?
main:thrm:img (0.05 : 0.43 : 0.52) scale 1 fps 13.1 read 3.33 rot 4.62 : [5.28 | 41.61 | 50.19] + 3.45 64.33 10.68 ONE_TEMP ON
main:thrm:img (0.05 : 0.42 : 0.52) scale 1 fps 13.7 read 1.84 rot 4.64 : [4.79 | 40.38 | 49.89] + 3.44 63.13 9.80 ONE_TEMP ON
main:thrm:img (0.05 : 0.43 : 0.52) scale 1 fps 13.9 read 1.83 rot 4.70 : [4.56 | 40.57 | 49.78] + 3.47 63.18 9.93 ONE_TEMP ON
main:thrm:img (0.05 : 0.43 : 0.52) scale 1 fps 14.0 read 1.84 rot 4.70 : [5.08 | 41.38 | 50.12] + 3.53 63.91 10.26 ONE_TEMP ON
main:thrm:img (0.06 : 0.44 : 0.51) scale 1 fps 13.9 read 1.68 rot 4.35 : [5.02 | 39.31 | 45.38] + 3.32 60.68 11.98 ONE_TEMP ON
main:thrm:img (0.05 : 0.43 : 0.52) scale 1 fps 13.9 read 1.81 rot 4.60 : [4.95 | 40.03 | 48.16] + 3.41 62.18 10.61 ONE_TEMP ON
main:thrm:img (0.06 : 0.43 : 0.52) scale 1 fps 13.9 read 1.80 rot 4.61 : [5.43 | 40.83 | 49.13] + 3.42 63.03 10.47 CROSS_HAIR ON
main:thrm:img (0.06 : 0.43 : 0.51) scale 1 fps 14.0 read 1.76 rot 4.55 : [5.84 | 41.32 | 48.87] + 3.47 63.30 10.96 CROSS_HAIR ON
main:thrm:img (0.09 : 0.44 : 0.48) scale 1 fps 13.8 read 1.67 rot 4.28 : [8.55 | 42.88 | 46.98] + 3.35 64.33 14.00 CROSS_HAIR ON
main:thrm:img (0.09 : 0.44 : 0.46) scale 1 fps 13.7 read 1.67 rot 4.17 : [9.31 | 44.42 | 46.31] + 3.30 65.09 15.48 CROSS_HAIR ON
main:thrm:img (0.09 : 0.44 : 0.47) scale 1 fps 13.6 read 1.66 rot 4.20 : [9.23 | 43.75 | 46.95] + 3.32 64.76 14.49 CROSS_HAIR ON
main:thrm:img (0.09 : 0.44 : 0.47) scale 1 fps 13.5 read 1.70 rot 4.28 : [9.52 | 44.21 | 47.68] + 3.31 65.33 14.34 CROSS_HAIR ON
main:thrm:img (0.07 : 0.42 : 0.50) scale 1 fps 14.5 read 4.52 rot 11.03 : [18.08 | 103.35 | 122.09] + 8.76 160.16 29.30 BOTH OFF
main:thrm:img (0.06 : 0.41 : 0.53) scale 1 fps 14.6 read 1.85 rot 4.28 : [5.50 | 38.18 | 48.59] + 3.46 61.41 9.36 BOTH OFF
main:thrm:img (0.06 : 0.41 : 0.53) scale 1 fps 14.6 read 1.87 rot 4.35 : [5.59 | 38.12 | 48.81] + 3.55 61.37 9.02 BOTH OFF
main:thrm:img (0.09 : 0.42 : 0.49) scale 1 fps 14.3 read 1.71 rot 4.31 : [8.68 | 40.65 | 47.95] + 3.35 61.72 10.42 BOTH OFF
main:thrm:img (0.09 : 0.42 : 0.49) scale 1 fps 14.1 read 1.67 rot 4.30 : [8.96 | 40.30 | 47.53] + 3.32 61.36 10.50 BOTH OFF
main:thrm:img (0.09 : 0.42 : 0.49) scale 1 fps 13.9 read 1.64 rot 4.21 : [9.27 | 41.17 | 47.96] + 3.31 62.14 10.86 BOTH OFF
main:thrm:img (0.09 : 0.42 : 0.49) scale 1 fps 13.8 read 1.68 rot 4.30 : [9.30 | 41.16 | 48.57] + 3.31 62.14 10.26 BOTH OFF
main:thrm:img (0.10 : 0.42 : 0.49) scale 1 fps 13.7 read 1.68 rot 4.32 : [9.42 | 41.23 | 48.42] + 3.31 62.20 10.47 BOTH OFF
main:thrm:img (0.08 : 0.42 : 0.50) scale 1 fps 13.7 read 3.32 rot 8.41 : [15.62 | 81.51 | 96.40] + 6.34 122.57 19.82 BOTH ON
main:thrm:img (0.07 : 0.42 : 0.50) scale 1 fps 13.7 read 1.83 rot 4.62 : [7.71 | 44.56 | 52.72] + 3.39 66.32 10.21 BOTH ON
main:thrm:img (0.11 : 0.43 : 0.46) scale 1 fps 13.2 read 1.71 rot 4.18 : [11.41 | 46.35 | 49.19] + 3.30 67.33 14.85 BOTH ON
main:thrm:img (0.11 : 0.43 : 0.46) scale 1 fps 13.0 read 1.69 rot 4.22 : [11.35 | 46.59 | 49.52] + 3.29 67.61 14.80 BOTH ON
main:thrm:img (0.11 : 0.43 : 0.46) scale 1 fps 12.8 read 1.71 rot 4.17 : [12.02 | 46.76 | 49.12] + 3.32 67.66 15.23 BOTH ON
main:thrm:img (0.11 : 0.43 : 0.46) scale 1 fps 12.7 read 1.71 rot 4.21 : [11.78 | 46.52 | 49.90] + 3.29 67.66 14.47 BOTH ON
main:thrm:img (0.10 : 0.43 : 0.47) scale 1 fps 12.6 read 1.71 rot 4.36 : [11.45 | 46.94 | 50.85] + 3.29 68.30 14.15 BOTH ON
main:thrm:img (0.11 : 0.43 : 0.46) scale 1 fps 12.6 read 1.64 rot 4.15 : [11.50 | 46.91 | 49.80] + 3.28 67.89 14.81 BOTH ON
main:thrm:img (0.08 : 0.40 : 0.52) scale 1 fps 9.8 read 3.06 rot 9.34 : [18.04 | 89.49 | 118.02] + 9.33 148.03 20.67 BOTH ON
main:thrm:img (0.06 : 0.37 : 0.57) scale 1 fps 9.8 read 1.79 rot 5.68 : [7.95 | 51.21 | 77.99] + 6.53 92.41 7.89 BOTH ON
main:thrm:img (0.06 : 0.37 : 0.57) scale 1 fps 9.7 read 1.78 rot 5.89 : [7.85 | 50.80 | 76.93] + 6.40 91.53 8.20 BOTH ON
main:thrm:img (0.08 : 0.38 : 0.54) scale 1 fps 9.6 read 1.78 rot 5.79 : [11.33 | 54.31 | 78.60] + 6.48 94.96 9.87 BOTH ON
main:thrm:img (0.08 : 0.38 : 0.54) scale 1 fps 10.3 read 3.55 rot 10.56 : [23.73 | 105.71 | 150.38] + 12.62 183.92 20.92 BOTH OFF
main:thrm:img (0.05 : 0.37 : 0.58) scale 1 fps 10.3 read 1.75 rot 4.90 : [7.07 | 47.66 | 74.49] + 6.49 88.05 7.07 BOTH OFF
main:thrm:img (0.06 : 0.37 : 0.58) scale 1 fps 10.3 read 1.77 rot 4.98 : [7.11 | 46.90 | 73.32] + 6.49 87.57 7.75 BOTH OFF
main:thrm:img (0.06 : 0.37 : 0.57) scale 1 fps 10.9 read 3.41 rot 9.72 : [15.80 | 93.58 | 143.67] + 12.66 173.46 17.13 ONE_TEMP OFF
main:thrm:img (0.02 : 0.37 : 0.60) scale 1 fps 10.9 read 1.81 rot 4.79 : [2.63 | 43.04 | 69.94] + 6.49 83.31 6.88 ONE_TEMP OFF
main:thrm:img (0.02 : 0.37 : 0.61) scale 1 fps 10.9 read 1.76 rot 4.75 : [2.68 | 43.07 | 70.23] + 6.57 83.62 6.82 ONE_TEMP OFF
main:thrm:img (0.03 : 0.37 : 0.60) scale 1 fps 10.7 read 1.70 rot 4.88 : [3.48 | 42.75 | 67.94] + 6.39 82.84 8.51 ONE_TEMP OFF
main:thrm:img (0.04 : 0.37 : 0.59) scale 1 fps 10.5 read 1.74 rot 4.86 : [4.10 | 42.34 | 67.24] + 6.26 82.60 9.09 ONE_TEMP OFF
main:thrm:img (0.04 : 0.37 : 0.59) scale 1 fps 10.4 read 1.70 rot 4.69 : [4.11 | 41.92 | 67.28] + 6.28 83.00 9.43 ONE_TEMP OFF
main:thrm:img (0.04 : 0.38 : 0.59) scale 1 fps 10.3 read 1.87 rot 5.12 : [4.10 | 42.92 | 67.27] + 6.32 82.89 9.30 ONE_TEMP OFF
Offline -scale 1
FPS taken after reset from at least 3 readings in stdout.
x1 double 23.3fps dragging single temperature point around with status hud disabled
x1 24.9fps dragging single temperature point around with status hud disabled
x1 double 22.2fps dragging both rulers around with status hud disabled
x1 24.9fps dragging both rulers around with status hud disabled
x1 24.8fps dragging both rulers around with status hud enabled
Felt slightly less smooth at any given frame rate than I'd expect.
main:thrm:img (0.13 : 0.36 : 0.51) scale 2 fps 13.6 read 0.03 rot 3.71 : [7.07 | 19.23 | 27.78] + 11.62 47.35 7.95 OFF ON
main:thrm:img (0.14 : 0.35 : 0.51) scale 1 fps 25.0 read 0.01 rot 6.65 : [9.91 | 24.46 | 35.53] + 10.71 53.62 7.38 OFF ON
main:thrm:img (0.17 : 0.34 : 0.48) scale 1 fps 24.8 read 0.01 rot 3.88 : [5.88 | 11.53 | 16.30] + 2.99 21.64 2.35 ONE_TEMP ON
main:thrm:img (0.12 : 0.35 : 0.54) scale 1 fps 24.8 read 0.01 rot 4.00 : [3.40 | 10.17 | 15.63] + 3.03 20.43 1.76 ONE_TEMP OFF
main:thrm:img (0.14 : 0.31 : 0.56) scale 1 fps 24.9 read 0.01 rot 4.55 : [3.80 | 8.42 | 15.29] + 3.78 20.96 1.89 ONE_TEMP OFF
main:thrm:img (0.13 : 0.30 : 0.57) scale 1 fps 24.9 read 0.01 rot 3.86 : [2.96 | 6.71 | 12.57] + 3.16 17.46 1.72 ONE_TEMP OFF
main:thrm:img (0.13 : 0.30 : 0.56) scale 1 fps 24.9 read 0.01 rot 3.82 : [2.95 | 6.73 | 12.55] + 3.17 17.33 1.61 ONE_TEMP OFF
main:thrm:img (0.14 : 0.30 : 0.55) scale 1 fps 24.9 read 0.01 rot 3.76 : [3.22 | 6.85 | 12.48] + 3.03 16.96 1.46 ONE_TEMP OFF
main:thrm:img (0.15 : 0.31 : 0.54) scale 1 fps 24.9 read 0.01 rot 3.64 : [3.58 | 7.12 | 12.53] + 2.98 17.09 1.58 ONE_TEMP OFF
main:thrm:img (0.15 : 0.30 : 0.54) scale 1 fps 24.9 read 0.01 rot 3.62 : [3.51 | 7.00 | 12.48] + 2.97 16.87 1.41 ONE_TEMP OFF
main:thrm:img (0.15 : 0.30 : 0.54) scale 1 fps 24.9 read 0.01 rot 3.65 : [3.52 | 6.96 | 12.45] + 2.99 16.88 1.44 ONE_TEMP OFF
main:thrm:img (0.15 : 0.30 : 0.54) scale 1 fps 24.9 read 0.01 rot 3.65 : [3.58 | 7.08 | 12.58] + 2.99 17.04 1.47 ONE_TEMP OFF
main:thrm:img (0.11 : 0.40 : 0.49) scale 1 fps 22.5 read 0.02 rot 10.47 : [11.32 | 39.54 | 47.96] + 18.25 83.89 17.68 ONE_TEMP OFF
main:thrm:img (0.06 : 0.44 : 0.50) scale 1 fps 22.9 read 0.01 rot 6.03 : [1.91 | 14.90 | 16.89] + 6.00 29.37 6.48 ONE_TEMP OFF
main:thrm:img (0.06 : 0.44 : 0.50) scale 1 fps 23.1 read 0.01 rot 5.84 : [1.91 | 14.84 | 16.74] + 6.09 29.30 6.47 ONE_TEMP OFF
main:thrm:img (0.06 : 0.44 : 0.50) scale 1 fps 23.2 read 0.01 rot 5.91 : [1.94 | 14.84 | 16.78] + 6.04 29.26 6.44 ONE_TEMP OFF
main:thrm:img (0.06 : 0.45 : 0.50) scale 1 fps 23.2 read 0.01 rot 5.76 : [1.92 | 14.80 | 16.53] + 6.05 29.25 6.67 ONE_TEMP OFF
main:thrm:img (0.06 : 0.44 : 0.50) scale 1 fps 23.3 read 0.01 rot 5.90 : [1.94 | 14.71 | 16.61] + 6.11 29.28 6.56 ONE_TEMP OFF
main:thrm:img (0.06 : 0.44 : 0.50) scale 1 fps 23.3 read 0.01 rot 5.99 : [1.99 | 14.89 | 16.98] + 6.06 29.56 6.52 ONE_TEMP OFF
main:thrm:img (0.06 : 0.45 : 0.49) scale 1 fps 23.3 read 0.01 rot 5.98 : [1.96 | 15.25 | 16.77] + 6.13 29.75 6.84 ONE_TEMP OFF
main:thrm:img (0.06 : 0.44 : 0.50) scale 1 fps 23.3 read 0.01 rot 6.02 : [2.04 | 15.17 | 16.95] + 6.13 29.46 6.38 ONE_TEMP OFF
main:thrm:img (0.10 : 0.48 : 0.43) scale 1 fps 23.2 read 0.01 rot 4.55 : [3.28 | 16.16 | 14.45] + 5.96 29.70 7.59 ONE_TEMP OFF
main:thrm:img (0.10 : 0.48 : 0.42) scale 1 fps 23.0 read 0.01 rot 4.46 : [3.48 | 16.18 | 14.30] + 5.85 29.49 7.46 ONE_TEMP OFF
main:thrm:img (0.10 : 0.48 : 0.42) scale 1 fps 22.9 read 0.01 rot 4.49 : [3.46 | 16.18 | 14.28] + 5.87 29.62 7.56 ONE_TEMP OFF
main:thrm:img (0.10 : 0.48 : 0.42) scale 1 fps 22.8 read 0.01 rot 4.41 : [3.47 | 16.30 | 14.21] + 5.88 29.64 7.46 ONE_TEMP OFF
main:thrm:img (0.16 : 0.43 : 0.41) scale 1 fps 21.8 read 0.01 rot 12.01 : [19.20 | 51.34 | 48.92] + 14.81 86.32 20.18 BOTH OFF
main:thrm:img (0.14 : 0.42 : 0.44) scale 1 fps 22.1 read 0.01 rot 5.81 : [5.98 | 18.74 | 19.43] + 6.33 33.21 7.45 BOTH OFF
main:thrm:img (0.13 : 0.43 : 0.44) scale 1 fps 22.1 read 0.01 rot 5.62 : [5.92 | 18.87 | 19.31] + 6.27 33.11 7.54 BOTH OFF
main:thrm:img (0.13 : 0.43 : 0.44) scale 1 fps 22.2 read 0.01 rot 5.83 : [6.01 | 19.25 | 19.57] + 6.34 33.53 7.63 BOTH OFF
main:thrm:img (0.14 : 0.43 : 0.44) scale 1 fps 22.2 read 0.01 rot 5.61 : [5.98 | 19.00 | 19.24] + 6.32 33.27 7.71 BOTH OFF
main:thrm:img (0.13 : 0.43 : 0.44) scale 1 fps 22.2 read 0.01 rot 5.84 : [5.99 | 19.12 | 19.63] + 6.37 33.57 7.57 BOTH OFF
main:thrm:img (0.12 : 0.37 : 0.52) scale 1 fps 15.6 read 0.01 rot 3.80 : [5.03 | 15.92 | 22.45] + 8.74 39.00 7.81 BOTH ON
main:thrm:img (0.17 : 0.34 : 0.49) scale 1 fps 24.9 read 0.01 rot 4.95 : [7.30 | 14.22 | 20.35] + 4.04 27.33 2.94 BOTH OFF
main:thrm:img (0.16 : 0.33 : 0.52) scale 1 fps 24.9 read 0.01 rot 3.81 : [4.22 | 8.83 | 14.10] + 3.16 19.13 1.87 BOTH OFF
main:thrm:img (0.15 : 0.33 : 0.52) scale 1 fps 24.9 read 0.01 rot 3.92 : [4.15 | 8.99 | 14.40] + 3.22 19.46 1.85 BOTH OFF
main:thrm:img (0.15 : 0.33 : 0.52) scale 1 fps 24.9 read 0.01 rot 3.93 : [4.20 | 8.98 | 14.33] + 3.20 19.48 1.95 BOTH OFF
main:thrm:img (0.14 : 0.36 : 0.50) scale 1 fps 24.9 read 0.02 rot 7.59 : [9.46 | 24.14 | 33.35] + 6.45 44.45 4.65 BOTH ON
main:thrm:img (0.13 : 0.37 : 0.50) scale 1 fps 24.9 read 0.01 rot 4.10 : [4.49 | 12.77 | 17.38] + 3.11 22.71 2.22 BOTH ON
main:thrm:img (0.13 : 0.37 : 0.50) scale 1 fps 24.8 read 0.01 rot 4.12 : [4.48 | 12.88 | 17.47] + 3.10 22.85 2.28 BOTH ON
main:thrm:img (0.13 : 0.36 : 0.50) scale 1 fps 24.8 read 0.01 rot 4.10 : [4.56 | 12.61 | 17.38] + 3.11 22.59 2.10 BOTH ON
main:thrm:img (0.13 : 0.37 : 0.50) scale 1 fps 24.8 read 0.01 rot 4.02 : [4.57 | 12.78 | 17.29] + 3.10 22.65 2.25 BOTH ON
RPi 2 v1.1
- Online 2.9s to display key bindings in stdout, 4.1s to display image.
With only 0.6 fps delta between 1 temp and both rulers, FAST_DRAG probably isn't going to make much difference.  Still like to see the results of the 2 new compile flags.
Yep, will add -DNO_DRAG=1 to optionally disable drag scrolling, but even without it, it doesn't stop the user from using the click jump-scroll method.
... as they feel like ~2fps because all the frames come at once and then it freezes for ~0.5s, unless you drag slowly and then it's a relatively consistent stuttery update rate.
That is odd because waitKeyEx( 1ms ) is only supposed to block for a max of 1 millisecond and then get blocked waiting for the next frame read to finish.  It appears as if imshow()'s are being stacked/buffered inside the OpenCV library (like printing buffered instead flushing buffers after each print statement).
I am doing mouse debouncing to minimize unnecessary processing because there is only 1 composited render per frame, but OpenCV allows multiple mouse events per frame.  I only act on the last mouse move because there are no "tween" frames at fixed rates.
FAST_DRAG may speed up that stuttery update behavior.
On my i7-9700 PC in offline mode and FPS set to "-fps 60" or higher, drag scrolling feels smoother than at 25 FPS.
Part of what you are experiencing is 25 FPS.
Question, did it feel smoother in older versions ?
The newer versions uses nano-sleep to stabilize FPS instead of using waitKeyEx() which was very unpredictable/inconsistent (too much jitter) allowing FPS to wander and take a long time to reach steady state.
Update:  Just rechecked the code.  Nano-sleep is only used during Freeze Frame and Offline modes, not live camera modes.
« Last Edit: January 12, 2024, 10:17:48 pm by G28 »
-DNO_DRAG=1 added as an option to replace drag scrolling with jump scrolling for "CPU challenged" hardware.
FWIW, I had installed Pi Desktop into a VirtualBox guest to test with the PiOS without the actual hardware.
I passed the Topdon TC001 through to the guest.  I could never get the camera to work in the proper pixel format.
The issue is that the VM is passing the camera through as Motion JPEG instead of its native 'YUYV' (YUYV 4:2:2) pixel format.  Motion JPEG is a lossy format, thus is useless to mine the thermal data.
Replacing drag scrolling with jump scrolling provides a better user experience on "CPU challenged hardware" while the camera is online  :-+ but isn't necessary in freeze frame or offline: The benefit of it is that it prevents the live image stuttering.
Seeing some improvement in fps from the single thread version, and the "CPU challenged" single core RPi zero and RPi1 need all the help they can get  ;D
RPi Zero v1.3 - No Drag
Online -scale 1
x1 double 9.7fps both rulers with status hud enabled
x1 double 11.8fps no hud
x1 17.1fps no hud
x1 14.0fps default hud
x1 14.9fps single temperature point with status hud disabled
x1 14.0fps both rulers with status hud disabled
Offline 2x
Startup timings: m 0.026, var 0.665, suo 0.357, pa 1.268, pkb 7.985, nw 1421.364, run 1.431, total 1433.096
Startup timings: m 0.025, var 0.797, suo 0.236, pa 1.211, pkb 7.455, nw 1412.152, run 1.495, total 1423.371 stdout keybindings 11.8s image 13.9s
Startup timings: m 0.023, var 0.852, suo 0.237, pa 1.353, pkb 8.662, nw 1426.547, run 1.357, total 1439.031 stdout keybindings 12.1s image 13.9s
Startup timings: m 0.028, var 0.654, suo 0.398, pa 1.318, pkb 8.508, nw 1393.718, run 1.364, total 1405.988 stdout keybindings 12.0s image 14.2s
Online -scale 1
Startup timings: m 0.029, var 0.655, suo 6.975, pa 368.359, pkb 0.804, nw 1818.635, run 1.530, total 2196.987
Startup timings: m 0.053, var 0.519, suo 0.322, pa 273.784, pkb 4.473, nw 1613.696, run 1.682, total 1894.529 stdout keybindings 12.4s
Startup timings: m 0.027, var 0.910, suo 0.329, pa 269.718, pkb 4.385, nw 1557.246, run 1.573, total 1834.188 stdout keybindings 12.0s image 14.9s
Startup timings: m 0.027, var 0.639, suo 0.365, pa 274.704, pkb 4.769, nw 1675.175, run 1.538, total 1957.217 stdout keybindings 12.0s image 14.9s
main:thrm:img (0.04 : 0.34 : 0.62) scale 1 fps 12.7 read 3.10 rot 4.22 : [2.54 | 24.31 | 44.11] + 3.31 58.98 11.56 OFF HUD : h 0.00 v 12.01
main:thrm:img (0.02 : 0.34 : 0.64) scale 1 fps 13.3 read 1.72 rot 4.25 : [1.68 | 24.27 | 46.36] + 3.39 60.32 10.57 HORIZ HUD : h 0.00 v 13.20
main:thrm:img (0.01 : 0.30 : 0.69) scale 1 fps 9.6 read 4.87 rot 12.08 : [3.06 | 75.43 | 174.40] + 13.71 214.56 26.45 BOTH OFF : h 0.01 v 53.86
main:thrm:img (0.00 : 0.28 : 0.72) scale 1 fps 9.6 read 1.66 rot 4.18 : [0.16 | 27.51 | 71.51] + 6.32 85.94 8.10 BOTH OFF : h 0.00 v 20.20
main:thrm:img (0.00 : 0.32 : 0.68) scale 1 fps 11.8 read 3.02 rot 8.22 : [0.19 | 49.77 | 107.67] + 11.59 133.07 13.81 ONE_TEMP NO_DRAWINGS : h 0.01 v 15.45
main:thrm:img (0.00 : 0.35 : 0.65) scale 1 fps 11.8 read 1.71 rot 4.54 : [0.03 | 27.66 | 51.39] + 6.52 65.53 7.61 ONE_TEMP NO_DRAWINGS : h 0.00 v 0.00
main:thrm:img (0.00 : 0.35 : 0.65) scale 1 fps 11.8 read 1.69 rot 4.55 : [0.03 | 27.60 | 51.35] + 6.54 65.59 7.69 ONE_TEMP NO_DRAWINGS : h 0.00 v 0.00
main:thrm:img (0.00 : 0.35 : 0.65) scale 1 fps 11.6 read 1.70 rot 4.36 : [0.03 | 29.54 | 54.39] + 6.76 70.23 9.08 ONE_TEMP NO_DRAWINGS : h 0.00 v 0.00
main:thrm:img (0.00 : 0.41 : 0.59) scale 1 fps 17.1 read 1.74 rot 4.66 : [0.11 | 24.27 | 34.74] + 3.65 47.65 9.26 ONE_TEMP NO_DRAWINGS : h 0.00 v 0.69
main:thrm:img (0.00 : 0.42 : 0.58) scale 1 fps 17.1 read 1.64 rot 4.45 : [0.04 | 23.04 | 32.18] + 3.49 44.46 8.79 ONE_TEMP NO_DRAWINGS : h 0.00 v 0.00
main:thrm:img (0.02 : 0.38 : 0.60) scale 1 fps 14.0 read 3.25 rot 8.55 : [2.14 | 47.28 | 74.53] + 6.73 101.24 19.97 ONE_TEMP HUD : h 0.01 v 11.82
main:thrm:img (0.03 : 0.35 : 0.62) scale 1 fps 14.0 read 1.65 rot 4.09 : [2.10 | 24.26 | 43.18] + 3.29 57.32 10.86 ONE_TEMP HUD : h 0.00 v 12.12
main:thrm:img (0.02 : 0.35 : 0.63) scale 1 fps 14.0 read 1.60 rot 4.17 : [1.59 | 24.10 | 43.13] + 3.32 57.30 10.85 ONE_TEMP HUD : h 0.00 v 11.95
main:thrm:img (0.01 : 0.36 : 0.64) scale 1 fps 15.1 read 2.23 rot 5.87 : [0.60 | 31.67 | 56.18] + 4.56 73.64 12.90 ONE_TEMP OFF : h 0.00 v 13.10
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.67 rot 4.24 : [0.04 | 22.81 | 40.35] + 3.36 53.35 9.64 ONE_TEMP OFF : h 0.00 v 9.52
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 15.0 read 1.64 rot 4.25 : [0.04 | 22.79 | 39.80] + 3.37 52.51 9.34 ONE_TEMP OFF : h 0.00 v 8.48
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.64 rot 4.23 : [0.03 | 22.74 | 40.53] + 3.36 53.11 9.22 ONE_TEMP OFF : h 0.00 v 9.33
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.66 rot 4.26 : [0.03 | 22.97 | 40.67] + 3.33 53.66 9.66 ONE_TEMP OFF : h 0.00 v 9.58
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.69 rot 4.21 : [0.04 | 22.05 | 39.93] + 3.38 53.18 9.87 ONE_TEMP OFF : h 0.00 v 9.26
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.62 rot 4.24 : [0.03 | 22.65 | 40.79] + 3.40 53.39 9.20 ONE_TEMP OFF : h 0.00 v 9.63
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.66 rot 4.31 : [0.03 | 22.53 | 40.05] + 3.36 53.18 9.77 ONE_TEMP OFF : h 0.00 v 9.13
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.66 rot 4.24 : [0.03 | 22.53 | 40.43] + 3.36 53.33 9.54 ONE_TEMP OFF : h 0.00 v 9.40
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.66 rot 4.31 : [0.03 | 22.64 | 40.01] + 3.35 52.69 9.33 ONE_TEMP OFF : h 0.00 v 8.58
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.63 rot 4.24 : [0.04 | 22.62 | 39.82] + 3.35 52.58 9.40 ONE_TEMP OFF : h 0.00 v 8.87
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.62 rot 4.30 : [0.04 | 22.73 | 39.71] + 3.38 52.65 9.55 ONE_TEMP OFF : h 0.00 v 8.42
main:thrm:img (0.00 : 0.36 : 0.64) scale 1 fps 14.9 read 1.59 rot 4.27 : [0.03 | 22.56 | 40.00] + 3.36 52.71 9.35 ONE_TEMP OFF : h 0.00 v 8.80
main:thrm:img (0.00 : 0.35 : 0.65) scale 1 fps 14.1 read 2.43 rot 6.20 : [0.29 | 34.64 | 65.38] + 5.01 84.29 13.90 BOTH OFF : h 0.00 v 18.60
main:thrm:img (0.00 : 0.34 : 0.66) scale 1 fps 14.0 read 1.65 rot 4.18 : [0.14 | 23.25 | 44.75] + 3.34 57.53 9.44 BOTH OFF : h 0.00 v 13.36
main:thrm:img (0.00 : 0.34 : 0.66) scale 1 fps 14.0 read 1.65 rot 4.14 : [0.14 | 23.26 | 44.72] + 3.32 57.53 9.49 BOTH OFF : h 0.00 v 13.29
main:thrm:img (0.00 : 0.34 : 0.65) scale 1 fps 14.0 read 1.62 rot 4.18 : [0.17 | 23.33 | 44.37] + 3.35 57.23 9.51 BOTH OFF : h 0.00 v 13.15
RPi Zero v1.3 - Fast drag draw single thread
Online -scale 1
x1 14.3fps dragging single temperature point around with status hud enabled (was 13.9)
x1 double 11.5fps dragging single temperature point around with status hud disabled (was 10.9)
Offline
x2 19.5fps dragging both rulers around with status hud disabled
x1 double 24.0fps dragging single temperature point around with status hud disabled (was 23.3)
x1 double 23.2fps dragging both rulers around with status hud disabled (was 22.2)
Offline 2x
Startup timings: m 0.029, var 0.753, suo 0.233, pa 1.179, pkb 17.813, nw 1426.867, run 1.407, total 1448.281 stdout keybindings 11.5s image 13.7s
Startup timings: m 0.110, var 0.619, suo 0.262, pa 1.135, pkb 9.373, nw 1411.900, run 1.241, total 1424.640  stdout keybindings 11.7s image 13.9s
Startup timings: m 0.027, var 0.682, suo 0.359, pa 1.199, pkb 8.709, nw 1422.815, run 1.308, total 1435.099  stdout keybindings 11.5s image 13.7s
Offline -scale 1
Startup timings: m 0.027, var 0.811, suo 0.326, pa 1.148, pkb 8.411, nw 1400.667, run 1.287, total 1412.677  stdout keybindings 11.5s image 13.7s
Startup timings: m 0.027, var 0.667, suo 0.405, pa 1.342, pkb 8.201, nw 1422.054, run 1.381, total 1434.077  stdout keybindings 11.7s image 13.7s
Startup timings: m 0.028, var 1.116, suo 0.342, pa 1.188, pkb 8.818, nw 1517.689, run 1.247, total 1530.428  stdout keybindings 11.5s image 13.6s
main:thrm:img (0.01 : 0.10 : 0.88) scale 1 fps 23.4 read 0.01 rot 4.54 : [0.34 | 2.30 | 20.21] + 4.57 29.16 4.38 BOTH HUD : h 0.00 v 13.68
main:thrm:img (0.01 : 0.21 : 0.78) scale 1 fps 21.4 read 0.01 rot 6.10 : [0.36 | 9.34 | 34.07] + 9.57 55.42 11.78 BOTH OFF : h 0.01 v 25.88
main:thrm:img (0.01 : 0.30 : 0.69) scale 1 fps 22.4 read 0.01 rot 4.14 : [0.16 | 6.66 | 15.48] + 6.23 28.62 6.91 BOTH OFF : h 0.00 v 10.23
main:thrm:img (0.01 : 0.31 : 0.68) scale 1 fps 22.8 read 0.01 rot 4.14 : [0.15 | 7.02 | 15.46] + 6.17 28.74 7.10 BOTH OFF : h 0.00 v 10.20
main:thrm:img (0.01 : 0.30 : 0.69) scale 1 fps 23.0 read 0.01 rot 4.05 : [0.15 | 6.72 | 15.47] + 6.20 28.74 7.07 BOTH OFF : h 0.00 v 10.28
main:thrm:img (0.01 : 0.31 : 0.69) scale 1 fps 23.1 read 0.01 rot 4.19 : [0.15 | 7.00 | 15.70] + 6.16 28.92 7.05 BOTH OFF : h 0.00 v 10.39
main:thrm:img (0.01 : 0.31 : 0.69) scale 1 fps 23.2 read 0.01 rot 4.12 : [0.15 | 6.87 | 15.50] + 6.26 28.73 6.97 BOTH OFF : h 0.00 v 10.24
main:thrm:img (0.01 : 0.31 : 0.68) scale 1 fps 23.2 read 0.01 rot 4.11 : [0.16 | 7.00 | 15.49] + 6.29 29.02 7.24 BOTH OFF : h 0.00 v 10.26
main:thrm:img (0.01 : 0.30 : 0.70) scale 1 fps 23.2 read 0.01 rot 4.13 : [0.16 | 6.54 | 15.31] + 6.16 28.57 7.11 BOTH OFF : h 0.00 v 10.07
main:thrm:img (0.01 : 0.20 : 0.80) scale 1 fps 22.9 read 0.01 rot 3.68 : [0.14 | 5.11 | 20.58] + 6.01 33.67 7.08 BOTH OFF : h 0.00 v 15.78
main:thrm:img (0.01 : 0.19 : 0.81) scale 1 fps 22.5 read 0.01 rot 3.65 : [0.15 | 5.09 | 21.69] + 5.96 34.84 7.19 BOTH OFF : h 0.00 v 16.96
main:thrm:img (0.01 : 0.19 : 0.81) scale 1 fps 22.2 read 0.01 rot 3.65 : [0.14 | 5.04 | 21.57] + 5.94 34.72 7.21 BOTH OFF : h 0.00 v 16.83
main:thrm:img (0.01 : 0.19 : 0.81) scale 1 fps 21.9 read 0.01 rot 3.63 : [0.15 | 5.06 | 21.66] + 5.91 35.01 7.44 BOTH OFF : h 0.00 v 16.95
main:thrm:img (0.00 : 0.26 : 0.74) scale 1 fps 21.9 read 0.01 rot 3.65 : [0.04 | 5.46 | 15.78] + 5.92 28.64 6.93 ONE_TEMP OFF : h 0.00 v 10.55
main:thrm:img (0.00 : 0.30 : 0.70) scale 1 fps 23.5 read 0.01 rot 4.42 : [0.09 | 7.06 | 16.68] + 7.06 31.63 7.90 ONE_TEMP OFF : h 0.00 v 10.71
main:thrm:img (0.00 : 0.33 : 0.67) scale 1 fps 23.8 read 0.01 rot 4.02 : [0.03 | 6.72 | 13.80] + 6.33 27.32 7.19 ONE_TEMP OFF : h 0.00 v 8.60
main:thrm:img (0.00 : 0.32 : 0.68) scale 1 fps 23.9 read 0.01 rot 4.07 : [0.02 | 6.44 | 13.74] + 6.30 27.18 7.14 ONE_TEMP OFF : h 0.00 v 8.50
main:thrm:img (0.00 : 0.31 : 0.69) scale 1 fps 24.0 read 0.01 rot 3.98 : [0.02 | 6.23 | 13.62] + 6.25 27.10 7.23 ONE_TEMP OFF : h 0.00 v 8.48
main:thrm:img (0.00 : 0.32 : 0.67) scale 1 fps 24.0 read 0.01 rot 4.05 : [0.02 | 6.64 | 13.82] + 6.43 27.37 7.13 ONE_TEMP OFF : h 0.00 v 8.57
main:thrm:img (0.00 : 0.28 : 0.72) scale 1 fps 23.8 read 0.01 rot 3.70 : [0.02 | 5.59 | 14.63] + 5.96 27.56 6.97 ONE_TEMP OFF : h 0.00 v 9.83
main:thrm:img (0.00 : 0.26 : 0.74) scale 1 fps 23.6 read 0.01 rot 3.66 : [0.02 | 5.17 | 14.92] + 5.95 27.79 6.92 ONE_TEMP OFF : h 0.00 v 10.18
main:thrm:img (0.00 : 0.26 : 0.74) scale 1 fps 23.4 read 0.01 rot 3.65 : [0.02 | 5.18 | 14.89] + 5.91 27.71 6.90 ONE_TEMP OFF : h 0.00 v 10.17
Online -scale 1
Startup timings: m 0.065, var 0.568, suo 7.085, pa 367.689, pkb 9.064, nw 1539.779, run 1.384, total 1925.634
Startup timings: m 0.027, var 0.842, suo 0.274, pa 277.592, pkb 4.654, nw 1654.386, run 1.602, total 1939.377  stdout keybindings 12.0s image 14.9s
Startup timings: m 0.028, var 0.836, suo 0.335, pa 269.684, pkb 12.028, nw 1573.312, run 1.387, total 1857.610 stdout keybindings 12.3s image 15.1s
Startup timings: m 0.026, var 0.617, suo 0.294, pa 276.846, pkb 4.553, nw 1580.950, run 1.593, total 1864.879  stdout keybindings 12.1s image 14.8s
main:thrm:img (0.01 : 0.37 : 0.62) scale 1 fps 16.6 read 4.34 rot 7.44 : [1.33 | 38.15 | 64.96] + 5.77 87.38 16.65 OFF NO_DRAWINGS : h 0.00 v 7.66
main:thrm:img (0.00 : 0.40 : 0.60) scale 1 fps 15.3 read 2.05 rot 4.75 : [0.03 | 26.32 | 39.40] + 3.68 54.84 11.76 OFF NO_DRAWINGS : h 0.00 v 0.00
main:thrm:img (0.00 : 0.40 : 0.60) scale 1 fps 14.8 read 2.22 rot 4.58 : [0.03 | 27.25 | 40.45] + 3.59 56.61 12.58 OFF NO_DRAWINGS : h 0.00 v 0.00
main:thrm:img (0.01 : 0.36 : 0.63) scale 1 fps 14.4 read 3.57 rot 8.37 : [1.78 | 46.01 | 81.64] + 6.57 107.97 19.75 CROSS_HAIR HUD : h 0.00 v 12.85
main:thrm:img (0.03 : 0.33 : 0.64) scale 1 fps 14.3 read 1.72 rot 4.24 : [2.29 | 24.50 | 48.57] + 3.39 62.17 10.21 BOTH HUD : h 0.00 v 13.19
main:thrm:img (0.00 : 0.33 : 0.66) scale 1 fps 14.5 read 1.74 rot 4.32 : [0.20 | 22.58 | 44.91] + 3.37 57.53 9.25 CROSS_HAIR OFF : h 0.00 v 10.62
main:thrm:img (0.00 : 0.37 : 0.63) scale 1 fps 16.8 read 2.50 rot 6.67 : [0.22 | 33.14 | 57.36] + 5.22 76.73 14.15 ONE_TEMP NO_DRAWINGS : h 0.00 v 6.43
main:thrm:img (0.00 : 0.39 : 0.61) scale 1 fps 16.8 read 1.64 rot 4.40 : [0.03 | 21.56 | 33.21] + 3.40 45.55 8.94 ONE_TEMP NO_DRAWINGS : h 0.00 v 0.00
thermalDataThread(4363) - exiting
imageDataThread(3942) - exiting
main:thrm:img (0.02 : 0.36 : 0.62) scale 1 fps 13.1 read 3.23 rot 4.30 : [1.66 | 27.27 | 47.63] + 3.43 61.38 10.33 ONE_TEMP HUD : h 0.00 v 12.54
main:thrm:img (0.02 : 0.36 : 0.62) scale 1 fps 13.9 read 1.82 rot 4.35 : [1.73 | 27.61 | 48.39] + 3.46 61.57 9.72 ONE_TEMP HUD : h 0.00 v 12.44
main:thrm:img (0.02 : 0.35 : 0.63) scale 1 fps 14.2 read 1.81 rot 4.27 : [1.59 | 27.24 | 48.18] + 3.43 61.20 9.58 ONE_TEMP HUD : h 0.00 v 12.60
main:thrm:img (0.02 : 0.35 : 0.63) scale 1 fps 14.3 read 1.79 rot 4.33 : [1.35 | 27.22 | 48.84] + 3.44 61.85 9.56 ONE_TEMP HUD : h 0.00 v 12.86
main:thrm:img (0.02 : 0.35 : 0.62) scale 1 fps 14.3 read 1.81 rot 4.30 : [1.81 | 27.14 | 48.14] + 3.41 61.28 9.73 ONE_TEMP HUD : h 0.00 v 12.70
main:thrm:img (0.02 : 0.35 : 0.63) scale 1 fps 14.3 read 1.71 rot 4.19 : [1.55 | 26.12 | 46.19] + 3.32 59.76 10.25 ONE_TEMP HUD : h 0.01 v 12.66
main:thrm:img (0.02 : 0.36 : 0.62) scale 1 fps 14.2 read 1.65 rot 4.12 : [1.46 | 25.54 | 44.65] + 3.26 58.62 10.71 ONE_TEMP HUD : h 0.00 v 12.28
main:thrm:img (0.00 : 0.34 : 0.66) scale 1 fps 11.4 read 3.66 rot 9.48 : [0.52 | 60.56 | 117.14] + 10.73 145.05 17.18 ONE_TEMP OFF : h 0.01 v 22.20
main:thrm:img (0.00 : 0.33 : 0.67) scale 1 fps 11.5 read 1.78 rot 4.94 : [0.03 | 32.77 | 68.02] + 6.77 81.57 6.77 ONE_TEMP OFF : h 0.00 v 11.72
main:thrm:img (0.00 : 0.32 : 0.68) scale 1 fps 11.5 read 1.73 rot 4.80 : [0.04 | 32.03 | 67.87] + 6.86 81.74 7.01 ONE_TEMP OFF : h 0.00 v 11.67
main:thrm:img (0.00 : 0.31 : 0.69) scale 1 fps 11.1 read 1.63 rot 5.18 : [0.03 | 30.02 | 65.95] + 6.37 81.38 9.06 ONE_TEMP OFF : h 0.00 v 12.01
main:thrm:img (0.00 : 0.30 : 0.70) scale 1 fps 10.8 read 1.67 rot 5.30 : [0.03 | 28.70 | 66.34] + 6.40 81.73 8.98 ONE_TEMP OFF : h 0.00 v 12.41
« Last Edit: January 16, 2024, 04:21:15 pm by Amish Technician »
The following users thanked this post: G28
This is true and a fair point, I was more thinking of a users first impression of the user experience because it causes the live image to stutter.
I haven't noted any reduction in performance compared to older versions no. I was drawing a comparison to other Pi models with better CPUs, they felt smoother while reporting similar fps, eg RPi zero offline 1x double dragging rulers at ~22fps vs doing the same on RPi 2/3 at a higher scale with the same or even slightly lower fps. I wonder if this is due to them having 4 CPU cores instead of 1.
The FAST_DRAG mods only apply to ruler plots.  The improvements in the single thread rendering of single temps warrant refactoring the other parts of the code for the single threaded hardware.
I can make a conditionally compiled hybrid jump/drag scroll version, but don't know if it will confuse users why drag works in one mode and not the other.  Guess that is what documentation is for.  :)
The startup stats are in milliseconds.  Getting to PKB is taking less than [10-20] milliseconds, so I have to attribute the majority of the 11-12 seconds to loading off the SD card and the app initializing global variables (e.g. additional colormaps) before calling main().  I can add a flush to stdout after the prints to see if they appear sooner, but I don't think I can do anything about the SD load speeds.  Maybe the Pi needs a ramdisk to load apps from.
« Last Edit: January 15, 2024, 03:25:28 am by G28 »
Offline 5U4GB
Finally got a bit of time to play with it on an ODroid.  Some notes, and I'll provide longish dumps so others can see the expected output...
You need both the OpenCV dev tools and the V4L utilities to run it, and for the build CFLAGS using -march=native would be a lot easier than having to set device-specific options, so "CFLAGS='-march=native -pipe -fomit-frame-pointer'" is a one-size-fits-all entry:
# This will install ~500MB of gunk
sudo apt-get install libopencv-dev
./build_redux
sudo apt-get install v4l-utils
When you plug in the camera it'll turn up as a generic USB camera:
> lsusb
Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. USB3.1 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
-> Bus 001 Device 004: ID 0bda:5830 Realtek Semiconductor Corp. USB Camera
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
On the ODroid it required a reboot to set up the drivers, with just hotplug I got:
[3873017.213567] usb 1-1.1: new high-speed USB device number 4 using xhci-hcd
[3873017.485976] usb 1-1.1: New USB device found, idVendor=0bda, idProduct=5830
[3873017.485980] usb 1-1.1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[3873017.485982] usb 1-1.1: Product: USB Camera
[3873017.485984] usb 1-1.1: Manufacturer: Generic
[3873017.485986] usb 1-1.1: SerialNumber: 200901010001
[3873017.522882] usb 1-1.1: Unsupported device
[3873017.522983] usb 1-1.1: Unsupported device
With a reboot I got:
[    7.366970] usb 1-1.1: new high-speed USB device number 3 using xhci-hcd
[    7.639681] usb 1-1.1: New USB device found, idVendor=0bda, idProduct=5830
[    7.641078] usb 1-1.1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    7.648574] usb 1-1.1: Product: USB Camera
[    7.652796] usb 1-1.1: Manufacturer: Generic
[    7.657213] usb 1-1.1: SerialNumber: 200901010001
[    7.706387] usb 1-1.1: Unsupported device
[    7.706478] usb 1-1.1: Unsupported device
[   10.330514] uvcvideo: Found UVC 1.00 device USB Camera (0bda:5830)
[   10.345930] uvcvideo 1-1.1:1.0: Entity type for entity Extension 4 was not initialized!
[   10.345938] uvcvideo 1-1.1:1.0: Entity type for entity Processing 2 was not initialized!
[   10.345941] uvcvideo 1-1.1:1.0: Entity type for entity Camera 1 was not initialized!
[   10.346181] input: USB Camera as /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/input/input1
[   10.350606] usbcore: registered new interface driver uvcvideo
[   10.350612] USB Video Class driver (1.1.1)
Be aware of the fact that the ODroid firmware image installs a bunch of default loopback video devices so if you see:
0 video10
0 video13
0 video14
0 video15
0 video16
0 video17
0 video18
0 video19
0 video20
0 video21
0 video23
then the camera isn't being picked up, it should be video device 0.
> udevadm info --a --name /dev/video0
  looking at device '/devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/video4linux/video0':
    KERNEL=="video0"
    SUBSYSTEM=="video4linux"
    DRIVER==""
    ATTR{dev_debug}=="0"
    ATTR{index}=="0"
    ATTR{name}=="USB Camera"
    ATTR{power/control}=="auto"
    ATTR{power/runtime_active_time}=="0"
    ATTR{power/runtime_status}=="unsupported"
    ATTR{power/runtime_suspended_time}=="0"
  looking at parent device '/devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.1':
    KERNELS=="1-1.1"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{authorized}=="1"
    ATTRS{avoid_reset_quirk}=="0"
    ATTRS{bConfigurationValue}=="1"
    ATTRS{bDeviceClass}=="ef"
    ATTRS{bDeviceProtocol}=="01"
    ATTRS{bDeviceSubClass}=="02"
    ATTRS{bMaxPacketSize0}=="64"
    ATTRS{bMaxPower}=="500mA"
    ATTRS{bNumConfigurations}=="1"
    ATTRS{bNumInterfaces}==" 2"
    ATTRS{bcdDevice}=="1101"
    ATTRS{bmAttributes}=="80"
    ATTRS{busnum}=="1"
    ATTRS{configuration}=="USB Camera"
    ATTRS{devnum}=="3"
    ATTRS{devpath}=="1.1"
    ATTRS{idProduct}=="5830"
    ATTRS{idVendor}=="0bda"
    ATTRS{ltm_capable}=="no"
    ATTRS{manufacturer}=="Generic"
    ATTRS{maxchild}=="0"
    ATTRS{power/active_duration}=="287456"
    ATTRS{power/autosuspend}=="2"
    ATTRS{power/autosuspend_delay_ms}=="2000"
    ATTRS{power/connected_duration}=="287456"
    ATTRS{power/control}=="auto"
    ATTRS{power/level}=="auto"
    ATTRS{power/persist}=="1"
    ATTRS{power/runtime_active_time}=="287212"
    ATTRS{power/runtime_status}=="active"
    ATTRS{power/runtime_suspended_time}=="0"
    ATTRS{product}=="USB Camera"
    ATTRS{quirks}=="0x0"
    ATTRS{removable}=="unknown"
    ATTRS{serial}=="200901010001"
    ATTRS{speed}=="480"
    ATTRS{urbnum}=="70"
    ATTRS{version}==" 2.00"
I assume that serial number will be the same across all cameras, is anyone seeing a different value there?
For the video details:
> sudo v4l2-ctl --all --device /dev/video0
Driver Info:
        Driver name      : uvcvideo
        Card type        : USB Camera
        Bus info         : usb-xhci-hcd.0.auto-1.1
        Driver version   : 4.9.255
        Capabilities     : 0x84200001
                Video Capture
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps      : 0x04200001
                Video Capture
                Streaming
                Extended Pix Format
Media Driver Info:
        Model            : USB Camera
        Serial           : 200901010001
        Media version    : 0.1.0
        Hardware revision: 0x00001101 (4353)
Interface Info:
        Type             : V4L Video
Entity Info:
        Function         : V4L2 I/O
        Pad 0x01000004   : Sink
          Link 0x0200000d: from remote pad 0x1000007 of entity 'Extension 4' (Unknown V4L2 Sub-Device): Data, Enabled, Immutable
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
        Width/Height      : 256/192
        Pixel Format      : 'YUYV' (YUYV 4:2:2)
        Field             : None
        Bytes per Line    : 512
        Size Image        : 98304
        Colorspace        : sRGB
        Transfer Function : Default (maps to sRGB)
        YCbCr/HSV Encoding: Default (maps to ITU-R 601)
        Quantization      : Default (maps to Limited Range)
        Flags             :
Crop Capability Video Capture:
        Bounds      : Left 0, Top 0, Width 256, Height 192
        Default     : Left 0, Top 0, Width 256, Height 192
        Pixel Aspect: 1/1
Selection Video Capture: crop_default, Left 0, Top 0, Width 256, Height 192, Flags:
Selection Video Capture: crop_bounds, Left 0, Top 0, Width 256, Height 192, Flags:
Streaming Parameters Video Capture:
        Capabilities     : timeperframe
        Frames per second: 25.000 (25/1)
        Read buffers     : 0
                     brightness 0x00980900 (int)    : min=-64 max=64 step=1 default=0 value=0
                       contrast 0x00980901 (int)    : min=0 max=100 step=1 default=50 value=50
                     saturation 0x00980902 (int)    : min=0 max=100 step=1 default=64 value=64
                            hue 0x00980903 (int)    : min=-180 max=180 step=1 default=0 value=0
 white_balance_temperature_auto 0x0098090c (bool)   : default=1 value=1
                          gamma 0x00980910 (int)    : min=100 max=500 step=1 default=300 value=300
           power_line_frequency 0x00980918 (menu)   : min=0 max=2 default=1 value=1 (50 Hz)
                                0: Disabled
                                1: 50 Hz
                                2: 60 Hz
      white_balance_temperature 0x0098091a (int)    : min=2800 max=6500 step=10 default=4600 value=4600 flags=inactive
                      sharpness 0x0098091b (int)    : min=0 max=100 step=1 default=50 value=50
         backlight_compensation 0x0098091c (int)    : min=0 max=1 step=1 default=0 value=0
                  exposure_auto 0x009a0901 (menu)   : min=0 max=3 default=3 value=3 (Aperture Priority Mode)
                                1: Manual Mode
                                3: Aperture Priority Mode
              exposure_absolute 0x009a0902 (int)    : min=50 max=10000 step=1 default=166 value=166 flags=inactive
         exposure_auto_priority 0x009a0903 (bool)   : default=0 value=1
Now I'm stuck in a maze of X11 plumbing to try and get it to display output via SSH-forwarded X11... would it be possible to add a -b batch-mode flag to just grab a frame of video and dump it to disk?
Another bit of feedback, it's annoyingly chatty which means I keep having to scroll back through all the output to find the bit I want, it'd be good to have the credits and usage only displayed in response to '--help' so you can see the useful output at a glance.
The following users thanked this post: G28, Amish Technician
Agreed. I used device specific options so I could cross compile code optimised for slower RPis on a faster RPi, however for the purposes of sharing on github I think your suggestion makes a lot more sense as most people will compile on the device it will run on.  :-+
Good idea, how about verbose mode option '-v  --verbose'
and a help option '-?  -h  --help'
Thanks for the update.
My TC001's serial number is the same as yours.
Added a "-quiet" flag to quiet STDOUT prints and stat logging prints.
Added a "-help" flag to print and exit.
Will add "-snapshot prefix" and "-record prefix" 'batch' features to the TODO list.
Will investigate the camera open error.  I disabled it via the "-quiet" flag during the interim.
« Last Edit: January 15, 2024, 04:24:04 pm by G28 »
I will move stat logging over to "-verbose" or "-stat" once we get the single threaded platform optimizations finalized.
Review update.
« Reply #71 on: January 15, 2024, 06:10:23 pm »
Requested feature:
"-snapshot [prefix]" and exit has been added to the pre-release.
If the optional prefix isn't added, it uses the default timestamp naming convention for the .png and .raw files.
[prefix] can consist of alpha-numeric characters, underscores and hyphens as long as it does NOT start with a hyphen to differentiate it from a command line -flag.
« Last Edit: January 15, 2024, 06:12:18 pm by G28 »
The banding/shimmering issue isn't caused by redux, I've checked with all my RPi's opening the TC001 as a capture device in VLC:
RPi Zero   Good
RPi Zero2 Minimal
RPi2v1.1   Bad
RPi2v1.2   Minimal
RPi3v1.2   Bad
RPi4          Good
RPi5          Good
I'll look into this further to try and understand what causes it/how to mitigate it.
The test version DRAW_SINGLE_THREAD has yeild a further improvment in FPS for the single threaded RPi zero. Props G28 for the significant improvements since I first tested on the RPi zero and it struggled to get above single digit FPS.  :-+
Online -scale 1
x1 18.9fps no hud (was 17.1)
x1 15.3fps default hud (was 14.0)
x1 16.4fps single temperature point with status hud disabled (was 14.9 )
x1 15.1fps both rulers with status hud disabled (was 14.0 )
x1 double 9.7fps both rulers with status hud enabled (was 9.7 )
x1 double 12.9fps no hud (was 11.8 )
-DNO_DRAG=1 -DFAST_DRAG=1 -DDRAW_SINGLE_THREAD=1
Startup timings: s 14.712, var 0.523, suo 7.021, pa 273.823, pkb 8.210, nw 1393.966, run 0.516, total 1698.771
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 15.6 read 4.32 rot 8.03 : [90.09 | 22.04 | 67.69] + 5.87 96.07 0.10 ONE_TEMP HUD : h 0.00 v 21.33
main:thrm:img (1.00 : 0.25 : 0.75) scale 1 fps 15.6 read 1.58 rot 4.28 : [47.32 | 11.66 | 35.47] + 3.15 50.51 0.05 ONE_TEMP HUD : h 0.00 v 10.76
main:thrm:img (1.00 : 0.25 : 0.75) scale 1 fps 15.6 read 1.57 rot 4.26 : [47.90 | 11.78 | 35.94] + 3.15 51.10 0.04 ONE_TEMP HUD : h 0.00 v 11.10
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 15.6 read 1.58 rot 4.25 : [47.68 | 11.67 | 35.82] + 3.17 50.90 0.04 ONE_TEMP HUD : h 0.00 v 11.09
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 15.6 read 1.52 rot 4.27 : [48.06 | 11.71 | 36.15] + 3.21 51.31 0.04 ONE_TEMP HUD : h 0.00 v 11.40
main:thrm:img (1.00 : 0.25 : 0.75) scale 1 fps 15.5 read 1.53 rot 4.23 : [48.22 | 11.82 | 36.19] + 3.19 51.45 0.04 ONE_TEMP HUD : h 0.00 v 11.41
main:thrm:img (1.00 : 0.25 : 0.75) scale 1 fps 15.5 read 1.55 rot 4.30 : [47.76 | 11.73 | 35.84] + 3.22 51.03 0.05 ONE_TEMP HUD : h 0.00 v 11.09
Startup timings: s 1.845, var 0.526, suo 0.312, pa 271.071, pkb 4.054, nw 1496.493, run 0.524, total 1774.825
main:thrm:img (1.00 : 0.25 : 0.75) scale 1 fps 15.5 read 4.69 rot 8.75 : [104.83 | 26.23 | 78.16] + 7.04 111.96 0.10 OFF HUD : h 0.00 v 24.54
main:thrm:img (1.00 : 0.25 : 0.75) scale 1 fps 15.4 read 1.56 rot 4.24 : [49.07 | 12.17 | 36.71] + 3.21 52.33 0.04 OFF HUD : h 0.00 v 11.62
main:thrm:img (1.00 : 0.25 : 0.75) scale 1 fps 15.3 read 1.56 rot 4.22 : [49.13 | 12.08 | 36.86] + 3.17 52.34 0.04 OFF HUD : h 0.00 v 11.82
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 15.3 read 1.54 rot 4.31 : [49.32 | 12.07 | 37.07] + 3.18 52.57 0.07 OFF HUD : h 0.00 v 11.93
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 15.3 read 1.56 rot 4.29 : [49.57 | 12.05 | 37.33] + 3.15 52.77 0.05 OFF HUD : h 0.00 v 12.24
Startup timings: s 1.793, var 0.685, suo 0.326, pa 273.368, pkb 4.283, nw 1496.998, run 0.521, total 1777.974
main:thrm:img (1.00 : 0.31 : 0.69) scale 1 fps 18.9 read 3.42 rot 5.77 : [49.47 | 15.35 | 33.99] + 4.17 53.70 0.06 OFF ONLY_VIDEO : h 0.00 v 3.21
main:thrm:img (1.00 : 0.34 : 0.66) scale 1 fps 18.9 read 1.57 rot 4.69 : [36.29 | 12.16 | 24.08] + 3.26 39.59 0.04 OFF ONLY_VIDEO : h 0.00 v 0.00
main:thrm:img (1.00 : 0.33 : 0.67) scale 1 fps 18.9 read 1.56 rot 4.69 : [36.47 | 12.16 | 24.26] + 3.26 39.78 0.05 OFF ONLY_VIDEO : h 0.00 v 0.00
main:thrm:img (1.00 : 0.33 : 0.67) scale 1 fps 18.9 read 1.61 rot 4.57 : [35.78 | 11.88 | 23.85] + 3.26 39.08 0.04 OFF ONLY_VIDEO : h 0.00 v 0.00
main:thrm:img (1.00 : 0.28 : 0.72) scale 1 fps 16.5 read 2.49 rot 6.92 : [67.44 | 18.93 | 48.38] + 5.15 72.66 0.07 OFF OFF : h 0.00 v 10.19
main:thrm:img (1.00 : 0.27 : 0.73) scale 1 fps 16.4 read 1.53 rot 4.28 : [44.54 | 11.82 | 32.67] + 3.22 47.81 0.04 OFF OFF : h 0.00 v 8.57
main:thrm:img (1.00 : 0.27 : 0.73) scale 1 fps 16.4 read 1.50 rot 4.40 : [44.67 | 11.93 | 32.69] + 3.26 47.98 0.05 OFF OFF : h 0.00 v 8.32
main:thrm:img (1.00 : 0.27 : 0.73) scale 1 fps 16.4 read 1.53 rot 4.35 : [44.64 | 11.90 | 32.69] + 3.26 47.94 0.04 OFF OFF : h 0.00 v 8.49
main:thrm:img (1.00 : 0.27 : 0.73) scale 1 fps 16.4 read 1.60 rot 4.32 : [44.75 | 11.95 | 32.75] + 3.25 48.05 0.05 OFF OFF : h 0.00 v 8.48
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 15.1 read 2.01 rot 5.66 : [65.52 | 15.95 | 49.35] + 4.30 69.89 0.06 BOTH OFF : h 0.00 v 17.21
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 15.1 read 1.51 rot 4.19 : [49.69 | 12.04 | 37.47] + 3.17 52.95 0.09 BOTH OFF : h 0.00 v 13.49
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 15.1 read 1.54 rot 4.26 : [50.18 | 12.12 | 37.88] + 3.24 53.47 0.04 BOTH OFF : h 0.00 v 13.69
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 15.1 read 1.54 rot 4.17 : [49.70 | 12.04 | 37.47] + 3.19 52.93 0.04 BOTH OFF : h 0.00 v 13.51
main:thrm:img (1.00 : 0.22 : 0.77) scale 1 fps 9.8 read 2.16 rot 6.29 : [100.82 | 21.81 | 78.08] + 7.39 108.28 0.06 BOTH HUD : h 0.00 v 30.83
main:thrm:img (1.00 : 0.21 : 0.78) scale 1 fps 9.7 read 1.54 rot 4.49 : [79.32 | 16.89 | 61.75] + 6.00 85.36 0.04 BOTH HUD : h 0.00 v 25.15
main:thrm:img (1.00 : 0.22 : 0.77) scale 1 fps 9.7 read 1.62 rot 4.23 : [79.50 | 17.14 | 61.57] + 6.02 85.57 0.04 BOTH HUD : h 0.00 v 25.26
main:thrm:img (1.00 : 0.29 : 0.70) scale 1 fps 12.9 read 1.80 rot 5.67 : [69.75 | 19.94 | 48.95] + 7.49 77.30 0.07 BOTH ONLY_VIDEO : h 0.00 v 5.84
main:thrm:img (1.00 : 0.32 : 0.67) scale 1 fps 12.9 read 1.52 rot 4.43 : [52.95 | 16.80 | 35.48] + 6.30 59.30 0.06 BOTH ONLY_VIDEO : h 0.00 v 0.00
main:thrm:img (1.00 : 0.32 : 0.67) scale 1 fps 12.9 read 1.54 rot 4.76 : [53.01 | 16.79 | 35.69] + 6.26 59.32 0.05 BOTH ONLY_VIDEO : h 0.00 v 0.00
main:thrm:img (1.00 : 0.33 : 0.66) scale 1 fps 12.9 read 1.53 rot 4.22 : [53.15 | 17.35 | 35.22] + 6.23 59.42 0.04 BOTH ONLY_VIDEO : h 0.00 v 0.00
main:thrm:img (1.00 : 0.29 : 0.71) scale 1 fps 15.9 read 2.83 rot 7.95 : [90.41 | 26.07 | 63.84] + 8.23 98.73 0.09 ONE_TEMP OFF : h 0.00 v 9.87
main:thrm:img (1.00 : 0.26 : 0.74) scale 1 fps 16.0 read 1.53 rot 4.34 : [45.67 | 11.87 | 33.75] + 3.20 48.92 0.04 ONE_TEMP OFF : h 0.00 v 8.92
main:thrm:img (1.00 : 0.26 : 0.74) scale 1 fps 16.0 read 1.52 rot 4.36 : [45.89 | 11.89 | 33.95] + 3.27 49.20 0.05 ONE_TEMP OFF : h 0.00 v 8.99
main:thrm:img (1.00 : 0.26 : 0.74) scale 1 fps 16.0 read 1.56 rot 4.44 : [45.85 | 11.94 | 33.85] + 3.24 49.13 0.04 ONE_TEMP OFF : h 0.00 v 8.98
main:thrm:img (1.00 : 0.26 : 0.74) scale 1 fps 16.0 read 1.55 rot 4.37 : [45.76 | 11.88 | 33.82] + 3.22 49.02 0.04 ONE_TEMP OFF : h 0.00 v 8.84
Offline
x2 21.0fps dragging both rulers around with status hud disabled (was 19.5 )
x1 double 24.3fps dragging single temperature point around with status hud disabled (was 24.0, 23.3 )
x1 double 23.8fps dragging both rulers around with status hud disabled (was 23.2, 22.2 )
Online -scale 1
x1 16.0fps dragging single temperature point around with status hud enabled (was 14.3, 13.9 )
x1 double 11.7fps dragging single temperature point around with status hud disabled (was 11.5, 10.9 )
x1 16.9fps dragging single temperature point around with status hud disabled
-DNO_DRAG=0 -DFAST_DRAG=1 -DDRAW_SINGLE_THREAD=1
Startup timings: s 15.435, var 0.518, suo 7.039, pa 1.257, pkb 8.521, nw 1395.784, run 0.512, total 1429.066
main:thrm:img (1.00 : 0.10 : 0.89) scale 2 fps 12.3 read 0.01 rot 5.38 : [65.15 | 6.64 | 57.95] + 35.28 100.52 0.09 BOTH OFF : h 0.00 v 31.92
main:thrm:img (1.00 : 0.12 : 0.87) scale 2 fps 12.6 read 0.00 rot 4.32 : [37.41 | 4.58 | 32.55] + 26.84 64.30 0.04 BOTH OFF : h 0.00 v 17.00
main:thrm:img (1.00 : 0.12 : 0.87) scale 2 fps 12.5 read 0.00 rot 4.06 : [38.33 | 4.67 | 33.41] + 26.79 65.16 0.03 BOTH OFF : h 0.00 v 17.83
main:thrm:img (1.00 : 0.11 : 0.89) scale 2 fps 12.1 read 0.00 rot 3.97 : [41.24 | 4.42 | 36.62] + 28.45 69.72 0.03 BOTH OFF : h 0.00 v 18.94
main:thrm:img (1.00 : 0.12 : 0.88) scale 2 fps 12.1 read 0.00 rot 4.28 : [38.47 | 4.45 | 33.82] + 27.19 65.71 0.06 BOTH OFF : h 0.00 v 17.68
main:thrm:img (1.00 : 0.11 : 0.88) scale 2 fps 12.1 read 0.00 rot 3.92 : [39.23 | 4.50 | 34.48] + 27.45 66.72 0.03 BOTH OFF : h 0.00 v 18.06
main:thrm:img (1.00 : 0.06 : 0.94) scale 2 fps 11.3 read 0.00 rot 3.55 : [71.34 | 4.21 | 66.94] + 21.98 93.36 0.03 BOTH OFF : h 0.00 v 46.18
main:thrm:img (1.00 : 0.06 : 0.94) scale 2 fps 10.7 read 0.00 rot 3.54 : [72.34 | 4.23 | 67.91] + 21.93 94.32 0.05 BOTH OFF : h 0.00 v 46.83
main:thrm:img (1.00 : 0.06 : 0.94) scale 2 fps 10.3 read 0.01 rot 3.56 : [72.80 | 4.07 | 68.54] + 21.78 94.61 0.03 BOTH OFF : h 0.00 v 47.62
main:thrm:img (1.00 : 0.06 : 0.94) scale 2 fps 10.0 read 0.01 rot 3.59 : [73.97 | 4.17 | 69.59] + 21.50 95.50 0.03 BOTH OFF : h 0.00 v 48.56
main:thrm:img (1.00 : 0.06 : 0.94) scale 1 fps 9.7 read 0.00 rot 3.58 : [73.75 | 4.09 | 69.47] + 21.43 95.21 0.03 BOTH OFF : h 0.00 v 48.40
main:thrm:img (1.00 : 0.06 : 0.93) scale 2 fps 20.8 read 0.01 rot 5.42 : [38.58 | 2.19 | 36.07] + 15.72 54.35 0.05 BOTH OFF : h 0.00 v 22.75
main:thrm:img (1.00 : 0.02 : 0.97) scale 2 fps 21.1 read 0.01 rot 3.98 : [21.51 | 0.47 | 20.81] + 12.14 33.69 0.04 BOTH OFF : h 0.00 v 11.89
main:thrm:img (1.00 : 0.02 : 0.97) scale 2 fps 20.8 read 0.00 rot 3.82 : [21.93 | 0.47 | 21.25] + 12.26 34.22 0.04 BOTH OFF : h 0.00 v 12.63
main:thrm:img (1.00 : 0.02 : 0.97) scale 2 fps 21.0 read 0.00 rot 3.97 : [21.50 | 0.47 | 20.84] + 12.18 33.71 0.04 BOTH OFF : h 0.00 v 12.17
main:thrm:img (1.00 : 0.02 : 0.97) scale 2 fps 21.1 read 0.01 rot 4.02 : [21.45 | 0.49 | 20.76] + 12.09 33.57 0.03 BOTH OFF : h 0.00 v 11.91
main:thrm:img (1.00 : 0.07 : 0.93) scale 1 fps 20.6 read 0.00 rot 3.72 : [27.90 | 1.86 | 25.83] + 9.22 37.15 0.03 BOTH OFF : h 0.00 v 18.48
main:thrm:img (1.00 : 0.21 : 0.79) scale 1 fps 24.3 read 0.01 rot 4.77 : [26.54 | 5.59 | 20.87] + 7.28 33.86 0.05 ONE_TEMP OFF : h 0.00 v 13.09
main:thrm:img (1.00 : 0.22 : 0.78) scale 1 fps 24.3 read 0.01 rot 4.09 : [20.82 | 4.52 | 16.22] + 6.03 26.89 0.04 ONE_TEMP OFF : h 0.00 v 9.90
main:thrm:img (1.00 : 0.23 : 0.77) scale 1 fps 24.3 read 0.01 rot 3.86 : [20.57 | 4.66 | 15.86] + 5.91 26.52 0.04 ONE_TEMP OFF : h 0.00 v 9.74
main:thrm:img (1.00 : 0.19 : 0.80) scale 1 fps 23.5 read 0.01 rot 6.67 : [40.96 | 7.85 | 32.88] + 10.30 51.32 0.06 BOTH OFF : h 0.00 v 21.74
main:thrm:img (1.00 : 0.20 : 0.79) scale 1 fps 23.7 read 0.01 rot 4.02 : [22.24 | 4.56 | 17.52] + 6.04 28.32 0.04 BOTH OFF : h 0.00 v 11.28
main:thrm:img (1.00 : 0.20 : 0.79) scale 1 fps 23.8 read 0.01 rot 4.06 : [22.19 | 4.44 | 17.58] + 5.98 28.21 0.04 BOTH OFF : h 0.00 v 11.36
main:thrm:img (1.00 : 0.20 : 0.80) scale 1 fps 23.8 read 0.01 rot 4.02 : [22.49 | 4.43 | 17.90] + 5.99 28.51 0.04 BOTH OFF : h 0.00 v 11.57
main:thrm:img (1.00 : 0.20 : 0.79) scale 1 fps 23.8 read 0.01 rot 4.08 : [22.13 | 4.46 | 17.48] + 5.95 28.12 0.04 BOTH OFF : h 0.00 v 11.33
Startup timings: s 1.774, var 0.600, suo 0.366, pa 369.657, pkb 0.673, nw 1433.173, run 0.551, total 1806.794
main:thrm:img (1.00 : 0.25 : 0.74) scale 1 fps 16.1 read 4.09 rot 6.85 : [81.10 | 20.52 | 60.22] + 5.20 86.38 0.08 ONE_TEMP HUD : h 0.00 v 18.15
main:thrm:img (1.00 : 0.25 : 0.74) scale 1 fps 16.0 read 1.74 rot 4.38 : [51.74 | 13.11 | 38.40] + 3.25 55.03 0.05 ONE_TEMP HUD : h 0.00 v 11.58
main:thrm:img (1.00 : 0.25 : 0.74) scale 1 fps 15.9 read 1.72 rot 4.36 : [52.31 | 13.22 | 38.87] + 3.32 55.69 0.05 ONE_TEMP HUD : h 0.00 v 11.85
main:thrm:img (1.00 : 0.25 : 0.74) scale 1 fps 15.9 read 1.73 rot 4.33 : [52.20 | 13.11 | 38.88] + 3.25 55.50 0.05 ONE_TEMP HUD : h 0.00 v 11.93
main:thrm:img (1.00 : 0.25 : 0.75) scale 1 fps 11.7 read 3.01 rot 7.75 : [114.38 | 28.42 | 85.68] + 9.19 123.65 0.09 ONE_TEMP OFF : h 0.00 v 21.42
main:thrm:img (1.00 : 0.24 : 0.75) scale 1 fps 11.7 read 1.65 rot 4.44 : [71.39 | 17.47 | 53.86] + 6.37 77.81 0.05 ONE_TEMP OFF : h 0.00 v 11.57
main:thrm:img (1.00 : 0.25 : 0.75) scale 1 fps 11.7 read 1.65 rot 4.38 : [71.81 | 17.84 | 53.90] + 6.43 78.29 0.05 ONE_TEMP OFF : h 0.00 v 11.48
main:thrm:img (1.00 : 0.26 : 0.74) scale 1 fps 16.9 read 2.55 rot 7.18 : [86.33 | 22.28 | 63.90] + 6.62 93.04 0.09 ONE_TEMP OFF : h 0.00 v 15.34
main:thrm:img (1.00 : 0.27 : 0.73) scale 1 fps 16.9 read 1.72 rot 4.45 : [47.86 | 13.02 | 34.78] + 3.32 51.23 0.05 ONE_TEMP OFF : h 0.00 v 8.22
main:thrm:img (1.00 : 0.27 : 0.73) scale 1 fps 16.9 read 1.74 rot 4.43 : [48.04 | 12.96 | 35.01] + 3.30 51.39 0.05 ONE_TEMP OFF : h 0.00 v 8.35
« Last Edit: January 16, 2024, 12:37:20 am by Amish Technician »
Offline 5U4GB
Yup, sounds good.
Offline aerdoc
Re: Portrait and Landscape Rotations in 90 degree increments
« Reply #74 on: January 16, 2024, 04:46:23 pm »
Just setup my Topdon on my RPi 4 this weekend and wow this is awesome! I've been messing a round with the FLIR Lepton the last few months but have been kind of disappointed by the lack of community development and wanting a higher resolution. I made a 3D model of the Topdon and I'm gonna adapt the bootleg zoom lens I made for the Lepton. If anyone's interested I can share the design.
I've got a question about the images below. What is that gradient affect happening to the right image? I was able to enable the 8-bit AGC Histogram Equalization on the Lepton and that's what it looked like.
