I have previously been asked if there is a cheap way to extend the thermal range of a thermal camera so that it can image very hot targets such as gas flames. The FLIR E4 does not have the range to cope with such a high temperature source so goes into over range mode.
Some cameras are limited to quite low maximum temperatures, such as the F1G2 and 'B' versions of FLIR cameras.
If you have a need to image a very high temperature target and only have a camera capable of say 100C or 250C, I have a crude solution that may assist you. The bad news is that calibration is totally lost, but the good news is that imaging is possible without over-ranging the camera.
What is my solution? ...... a simple filter that is placed in front of the cameras Objective.
Is the filter anything special for thermal imager use ? ...... no, its available on the high street
What is it ? ..... It is nothing more sophisticated than a Glass UV filter for a visble light camera.
No Way! I hear you say.... Glass blocks Long Wave thermal energy....... well yes and no. In the normal state of affairs, glass does indeed block LW thermal energy. However when looking at a very high energy thermal source, some energy does make it through to the camera lens. The filter behaves like an attenuator.
Take a look at the attached pictures taken with my E4, with and without a Tiffen Haze 1 filter fitted. Judge for yourself. As you will see, the camera reading on a hot spot drops from Over-Range, to around 30C to 40C, well within the cameras capabilities
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
You can experiment with different materials to see which work best in your application. I needed to image (but not measure) a gas jet so needed a lot of attenuation for my E4. My experiments proved that I could use a standard UV filter as an attenuator for my application. Note that adding another UV filter DOES NOT double the attenuation provided, it only increases the attenuation slightly as your are dealing with the passband of the filter glass and not the thickness per-se.
Go on, experiment and see what materials suit your requirements for high temperature imaging.
Fraser
