Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
2 image files read
both subsamplings are valid for MJPEG // 4:2:2 (2x1 1x1 1x1) - CrH 50% - CbH 50% - CrV 100% - CbV 100%
cinfo.comp_info[0].h_samp_factor = 2; // Y
cinfo.comp_info[0].v_samp_factor = 1;
cinfo.comp_info[1].h_samp_factor = 1; // Cb
cinfo.comp_info[1].v_samp_factor = 1;
cinfo.comp_info[2].h_samp_factor = 1; // Cr
cinfo.comp_info[2].v_samp_factor = 1;
ExifTool Version Number : 10.02
File Name : #0000010-v2.jpg
File Size : 7.7 kB
Resource Fork Size : 286 bytes
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Image Width : 640
Image Height : 480
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Image Size : 640x480
Megapixels : 0.307
File Name : #0000010-v3.jpg
File Size : 11 kB
File Type : JPEG
JFIF Version : 1.01
Resolution Unit : None
X Resolution : 1
Y Resolution : 1
Image Width : 160
Image Height : 120
Bits Per Sample : 8
Image Size : 160x120
Megapixels : 0.019
2 image files read
00000000 ff d8 ff c0 00 11 08 01 e0 02 80 03 01 21 00 02 |.............!..|
00000010 11 01 03 11 01 ff dd 00 04 00 28 ff db 00 84 00 |..........(.....|
00000000 ff d8 ff e0 00 10 4a 46 49 46 00 01 01 00 00 01 |......JFIF......|
00000010 00 01 00 00 ff db 00 43 00 03 02 02 03 02 02 03 |.......C........|
$ v4l2-ctl --all -d /dev/video2
Driver Info (not using libv4l2):
Driver name : v4l2 loopback
Card type : Dummy video device (0x0002)
Bus info : platform:v4l2loopback-002
Driver version: 3.18.13
Capabilities : 0x85208001
Video Capture
Video Memory-to-Memory
Read/Write
Streaming
Device Capabilities
Device Caps : 0x05208001
Video Capture
Read/Write
Streaming
Video input : 0 (loopback: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'MJPG'
Field : None
Bytes per Line: 0
Size Image : 1228800
Colorspace : SRGB
Custom Info : feedcafe
Format Video Output:
Field : None
Bytes per Line: 0
Colorspace : SRGB
Streaming Parameters Video Capture:
Frames per second: 5.000 (5/1)
Read buffers : 8
Streaming Parameters Video Output:
Write buffers : 8
User Controls
keep_format (bool) : default=0 value=0
sustain_framerate (bool) : default=0 value=0
timeout (int) : min=0 max=100000 step=1 default=0 value=0
timeout_image_io (bool) : default=0 value=0
$ v4l2-ctl --all -d /dev/video3
Card type : Dummy video device (0x0003)
Bus info : platform:v4l2loopback-003
Video Capture
Read/Write
Streaming
Device Capabilities
Video Capture
Read/Write
Streaming
Width/Height : 160/120
Field : None
Bytes per Line: 0
Size Image : 76800
Colorspace : SRGB
Field : None
Bytes per Line: 0
Size Image : 76800
Colorspace : SRGB
Read buffers : 8
Write buffers : 8
User Controls
$ export LD_LIBRARY_PATH=/usr/local/lib
$ mjpg_streamer -i "input_uvc.so -d /dev/video3 -r 160x120" -o "output_http.so -w /usr/local/www"
MJPG Streamer Version: svn rev: Unversioned directory
i: Using V4L2 device.: /dev/video3
i: Desired Resolution: 160 x 120
i: Frames Per Second.: 5
i: Format............: MJPEG
o: www-folder-path...: /usr/local/www/
o: HTTP TCP port.....: 8080
o: username:password.: disabled
o: commands..........: enabled
*** glibc detected *** mjpg_streamer: free(): invalid next size (normal): 0x01258910 ***
Aborted
./mjpg_streamer -i "./input_uvc.so -d /dev/video3" -o "output_http.so -w /usr/local/www"
Open and edit the apporitate plugins (input_uvc) and the programs Makefile, and remove the hashmark befor the following row:
#CFLAGS += -DDEBUG
$ ./mjpg_streamer -i "./input_uvc.so -d /dev/video3" -o "output_http.so -w /usr/local/www"
MJPG Streamer Version: svn rev: 3:172M
DBG(input_uvc.c, input_init(), 107): argv[0]=UVC webcam grabber
DBG(input_uvc.c, input_init(), 107): argv[1]=-d
DBG(input_uvc.c, input_init(), 107): argv[2]=/dev/video3
DBG(input_uvc.c, input_init(), 162): case 2,3
DBG(input_uvc.c, input_init(), 245): input id: 0
i: Desired Resolution: 640 x 480
DBG(input_uvc.c, input_init(), 265): vdIn pn: 0
i: The format asked unavailable, so the width 160 height 120
DBG(v4l2uvc.c, init_videoIn(), 94): Current size: 160x120
DBG(v4l2uvc.c, init_videoIn(), 123): Supported format: [MJPG]
DBG(v4l2uvc.c, init_videoIn(), 153): Supported size with the current format: 160x120
DBG(v4l2uvc.c, init_videoIn(), 123): Supported format: RGB3
DBG(v4l2uvc.c, init_videoIn(), 155): Supported size: 160x120
DBG(v4l2uvc.c, init_videoIn(), 123): Supported format: BGR3
DBG(v4l2uvc.c, init_videoIn(), 123): Supported format: YU12
DBG(v4l2uvc.c, init_videoIn(), 123): Supported format: YV12
DBG(v4l2uvc.c, enumerateControls(), 801): V4L2 API's V4L2_CTRL_FLAG_NEXT_CTRL is supported
DBG(v4l2uvc.c, control_readed(), 705): V4L2 parameter found: User Controls value 2123345140 Class: USER
DBG(v4l2uvc.c, control_readed(), 710): Unable to get the value of User Controls retcode: -1 Permission denied
DBG(v4l2uvc.c, control_readed(), 705): V4L2 parameter found: keep_format value 0 Class: USER
DBG(v4l2uvc.c, control_readed(), 705): V4L2 parameter found: sustain_framerate value 0 Class: USER
DBG(v4l2uvc.c, control_readed(), 705): V4L2 parameter found: timeout value 0 Class: USER
DBG(v4l2uvc.c, control_readed(), 705): V4L2 parameter found: timeout_image_io value 0 Class: USER
DBG(v4l2uvc.c, enumerateControls(), 836): JPEG compression details:
DBG(v4l2uvc.c, enumerateControls(), 837): Quality: 0
DBG(v4l2uvc.c, enumerateControls(), 838): APPn: 0
DBG(v4l2uvc.c, enumerateControls(), 839): APP length: 0
DBG(v4l2uvc.c, enumerateControls(), 840): APP data:
DBG(v4l2uvc.c, enumerateControls(), 841): COM length: 0
DBG(v4l2uvc.c, enumerateControls(), 842): COM data:
DBG(input_uvc.c, input_run(), 310): launching camera thread #00
,sizeof(struct v4l2_buffer) DBG(v4l2uvc.c, uvcGrab(), 431): X3
DBG(input_uvc.c, cam_thread(), 382): received frame of size: 76800 from plugin: 0
DBG(input_uvc.c, cam_thread(), 411): copying frame from input: 0
DBG(input_uvc.c, cam_thread(), 436): waiting for next frame
*** glibc detected *** ./mjpg_streamer: free(): invalid next size (normal): 0x000ee9d8 ***
Aborted
/* grab a frame */
377: if(uvcGrab(pcontext->videoIn) < 0) {
int uvcGrab(struct vdIn *vd)
430: vd->buf.memory = V4L2_MEMORY_MMAP;
431: ret = xioctl(vd->fd, VIDIOC_DQBUF, &vd->buf);
static int xioctl(int fh, int request, void *arg)
int r;
do
r = ioctl(fh, request, arg);
} while (-1 == r && EINTR == errno);
return r;
... except the missing JFIF in /video2Code: [Select]$ hexdump -n32 -C #0000010-v2.jpg
Motion JPEG AVI files typically have an APP0 header (FF E0), with the tag 'AVI1' and not 'JFIF'.
cinfo.write_JFIF_header = FALSE;
jpeg_start_compress(&cinfo, TRUE);
$ find / -name v4l2loopback.ko 2>/dev/zero
/lib/modules/3.18.0-trunk-rpi2/extra/v4l2loopback.ko
/lib/modules/3.18.13-v7+/extra/v4l2loopback.ko
$ sudo mkdir /mnt/RAMDisk
$ sudo chmod 777 /mnt/RAMDisk
$ sudo mount -t tmpfs -o size=20m none /mnt/RAMDisk
$ df
Filesystem 1K-blocks Used Available Use% Mounted on
none 20480 20480 0 100% /mnt/RAMDisk
$ sudo apt-get install libusb-1.0-0
$ sudo apt-get install libusb-1.0-0-dev
$ sudo apt-get install libjpeg-dev
$ make
gcc -I/usr/include/libusb-1.0 -c -o flir8k.o flir8k.c
gcc -I/usr/include/libusb-1.0 -o flir8k Palettes.o flir8k.o -lusb-1.0 -ljpeg -lm -Wall
$ sudo ./flir8k
Successfully find the Flir One G2 device
Successfully set usb configuration 3
Successfully claimed interface 0,1,2
stop interface 2 FRAME
stop interface 1 FILEIO
start interface 1 FILEIO
:xx Sun Jan 10 16:30:27 2016
: Sun Jan 10 16:30:27 2016
bulk read EP 0x81, actual length 101
HEX:
cc 01 00 00 01 00 00 00 55 00 00 00 30 73 8c df 7b 22 74 79 70 65 22 3a 22 62 61 74 74 65 72 79 56 6f 6c 74 61 67 65 55 70 64 61 74 65 22 2c 22 64 61 74 61 22 3a 7b 22 76 6f 6c 74 61 67 65 22 3a 34 2e 31 37 30 30 30 30 30 37 36 32 39 33 39 35 2c 22 70 65 72 63 65 6e 74 61 67 65 22 3a 31 30 30 7d 7d 00
STRING:
?U0s??{"type":"batteryVoltageUpdate","data":{"voltage":4.17000007629395,"percentage":100}}
>>>>>>>>>>>>>>>>>bulk transfer (in) 0x83:-7 LIBUSB_ERROR_TIMEOUT
ask for CameraFiles.zip on EP 0x83:
: Sun Jan 10 16:30:28 2016
EP 0x02 to be sent Hexcode: 16 Bytes[ cc 01 00 00 01 00 00 00 41 00 00 00 f8 b3 f7 00 ]
Write successful!
EP 0x02 to be sent: {"type":"openFile","data":{"mode":"r","path":"CameraFiles.zip"}}
Write successful!
Sent 65 bytes with string: {"type":"openFile","data":{"mode":"r","path":"CameraFiles.zip"}}
EP 0x02 to be sent Hexcode: 16 Bytes[ cc 01 00 00 01 00 00 00 33 00 00 00 ef db c1 c1 ]
Write successful!
EP 0x02 to be sent 51 Bytes: {"type":"readFile","data":{"streamIdentifier":10}}
Write successful!
Sent 51 bytes with string: {"type":"readFile","data":{"streamIdentifier":10}}
Ask for video stream, start EP 0x85:
>>>>>>>>>>>>>>>>>bulk transfer (in) 0x81:-7 LIBUSB_ERROR_TIMEOUT
#000001 0/10 fps:{"shutterState":"ON","shutterTemperature":310.179992675781,"usbNotifiedTimestamp":1177004833.33163,"usbEnqueuedTimestamp":1177004833.33369,"ffcState":"FFC_VALID_RAD"}
#000002 0/10 fps:{"shutterState":"FFC","shutterTemperature":308.640014648438,"usbNotifiedTimestamp":1177004852.00896,"usbEnqueuedTimestamp":1177004852.01061,"ffcState":"FFC_RAD_APPROX"}
: Sun Jan 10 16:30:47 2016
bulk read EP 0x81, actual length 206
HEX:
cc 01 00 00 01 00 00 00 55 00 00 00 30 73 8c df 7b 22 74 79 70 65 22 3a 22 62 61 74 74 65 72 79 56 6f 6c 74 61 67 65 55 70 64 61 74 65 22 2c 22 64 61 74 61 22 3a 7b 22 76 6f 6c 74 61 67 65 22 3a 34 2e 31 37 30 30 30 30 30 37 36 32 39 33 39 35 2c 22 70 65 72 63 65 6e 74 61 67 65 22 3a 31 30 30 7d 7d 00 cc 01 00 00 01 00 00 00 59 00 00 00 88 cc 5a 95 7b 22 74 79 70 65 22 3a 22 62 61 74 74 65 72 79 43 68 61 72 67 69 6e 67 53 74 61 74 65 55 70 64 61 74 65 22 2c 22 64 61 74 61 22 3a 7b 22 63 68 61 72 67 69 6e 67 53 74 61 74 65 22 3a 22 73 74 61 74 65 43 68 61 72 67 69 6e 67 53 6d 61 72 74 50 68 6f
STRING:
?U0s??{"type":"batteryVoltageUpdate","data":{"voltage":4.17000007629395,"percentage":100}}?Y??Z?{"type":"batteryChargingStateUpdate","data":{"chargingState":"stateChargingSmartPho
#000003 0/10 fps:{"shutterState":"FFC","shutterTemperature":308.640014648438,"usbNotifiedTimestamp":1177004852.57983,"usbEnqueuedTimestamp":1177004852.58155,"ffcState":"FFC_RAD_APPROX"}
#000004 3/10 fps:{"shutterState":"FFC","shutterTemperature":308.640014648438,"usbNotifiedTimestamp":1177004852.69227,"usbEnqueuedTimestamp":1177004852.69411,"ffcState":"FFC_RAD_APPROX"}
#000005 8/10 fps:{"shutterState":"ON","shutterTemperature":308.640014648438,"usbNotifiedTimestamp":1177004852.80562,"usbEnqueuedTimestamp":1177004852.80794,"ffcState":"FFC_RAD_APPROX"}
#000006 11/10 fps:{"shutterState":"ON","shutterTemperature":308.640014648438,"usbNotifiedTimestamp":1177004852.91994,"usbEnqueuedTimestamp":1177004852.92159,"ffcState":"FFC_RAD_APPROX"}
#000007 14/10 fps:{"shutterState":"ON","shutterTemperature":308.640014648438,"usbNotifiedTimestamp":1177004853.03383,"usbEnqueuedTimestamp":1177004853.03595,"ffcState":"FFC_RAD_APPROX"}
#000008 18/10 fps:{"shutterState":"ON","shutterTemperature":308.640014648438,"usbNotifiedTimestamp":1177004853.14999,"usbEnqueuedTimestamp":1177004853.15202,"ffcState":"FFC_RAD_APPROX"}
#000009 20/10 fps:{"shutterState":"ON","shutterTemperature":308.75,"usbNotifiedTimestamp":1177004853.26203,"usbEnqueuedTimestamp":1177004853.26407,"ffcState":"FFC_RAD_APPROX"}
#000010 23/10 fps:{"shutterState":"ON","shutterTemperature":308.75,"usbNotifiedTimestamp":1177004853.37733,"usbEnqueuedTimestamp":1177004853.37923,"ffcState":"FFC_RAD_APPROX"}
#000011 26/10 fps:{"shutterState":"ON","shutterTemperature":308.75,"usbNotifiedTimestamp":1177004853.49003,"usbEnqueuedTimestamp":1177004853.49223,"ffcState":"FFC_RAD_APPROX"}
#000012 28/10 fps:{"shutterState":"ON","shutterTemperature":308.769989013672,"usbNotifiedTimestamp":1177004853.60389,"usbEnqueuedTimestamp":1177004853.60574,"ffcState":"FFC_RAD_APPROX"}
#003170 86/10 fps:{"shutterState":"ON","shutterTemperature":310.679992675781,"usbNotifiedTimestamp":1177004033.54082,"usbEnqueuedTimestamp":1177004033.542,"ffcState":"FFC_VALID_RAD"}
#003171 84/10 fps:{"shutterState":"ON","shutterTemperature":310.679992675781,"usbNotifiedTimestamp":1177004033.65724,"usbEnqueuedTimestamp":1177004033.6585,"ffcState":"FFC_VALID_RAD"}
#003172 83/10 fps:{"shutterState":"ON","shutterTemperature":310.679992675781,"usbNotifiedTimestamp":1177004033.76884,"usbEnqueuedTimestamp":1177004033.77,"ffcState":"FFC_VALID_RAD"}
#003173 83/10 fps:{"shutterState":"ON","shutterTemperature":310.679992675781,"usbNotifiedTimestamp":1177004033.88303,"usbEnqueuedTimestamp":1177004033.89359,"ffcState":"FFC_VALID_RAD"}
#003174 84/10 fps:{"shutterState":"ON","shutterTemperature":310.679992675781,"usbNotifiedTimestamp":1177004034.00084,"usbEnqueuedTimestamp":1177004034.00196,"ffcState":"FFC_VALID_RAD"}
#003175 84/10 fps:{"shutterState":"ON","shutterTemperature":310.679992675781,"usbNotifiedTimestamp":1177004034.11106,"usbEnqueuedTimestamp":1177004034.11261,"ffcState":"FFC_VALID_RAD"}
#003176 84/10 fps:{"shutterState":"ON","shutterTemperature":310.679992675781,"usbNotifiedTimestamp":1177004034.2256,"usbEnqueuedTimestamp":1177004034.22683,"ffcState":"FFC_VALID_RAD"}
$ sudo apt-get install apache2
$ sudo ln -s /mnt/RAMDisk/thermal.jpg /var/www/thermal.jpg
$ sudo ln -s /mnt/RAMDisk/real.jpg /var/www/real.jpg
// don't forget the "sudo chmod 777 /mnt/RAMDisk" from (1) http://192.168.1.70/real.jpg
http://192.168.1.70/thermal.jpg
my raspberry pi has the address 192.168.1.70Select the menu icon
Press Manage Cameras
Select Add Camera then Generic URL
Give your cam a name
For Type choose Generic Video URL
Enter your URL, e.g. http://192.168.0.1:80/thermal.jpg
Press Test
If it works, press Save
$ sudo apt-get install imagemagick
$ sudo apt-get install subversion
$ svn co svn://svn.code.sf.net/p/mjpg-streamer/code/ mjpg-streamer
Checked out revision 182.
$ cd mjpg-streamer/mjpg-streamer
$ make
gcc -D'SVN_REV="3:172"' -O2 -DLINUX -D_GNU_SOURCE -Wall -c -o mjpg_streamer.o mjpg_streamer.c
gcc -D'SVN_REV="3:172"' -O2 -DLINUX -D_GNU_SOURCE -Wall -c -o utils.o utils.c
gcc -D'SVN_REV="3:172"' -O2 -DLINUX -D_GNU_SOURCE -Wall mjpg_streamer.o utils.o -lpthread -ldl -o mjpg_streamer
chmod 755 mjpg_streamer
make -C plugins/input_uvc all
cp plugins/input_file/input_file.so
$ ls -al
total 412
drwxr-xr-x 5 pi pi 4096 Jan 10 17:24 .
drwxr-xr-x 10 pi pi 4096 Jan 10 17:22 ..
-rw-r--r-- 1 pi pi 102 Jan 10 17:22 CHANGELOG
-rwxr-xr-x 1 pi pi 14331 Jan 10 17:24 input_file.so
-rwxr-xr-x 1 pi pi 168606 Jan 10 17:24 input_testpicture.so
-rwxr-xr-x 1 pi pi 30905 Jan 10 17:24 input_uvc.so
-rw-r--r-- 1 pi pi 17987 Jan 10 17:22 LICENSE
-rw-r--r-- 1 pi pi 5107 Jan 10 17:22 Makefile
-rwxr-xr-x 1 pi pi 16104 Jan 10 17:24 mjpg_streamer
-rw-r--r-- 1 pi pi 15738 Jan 10 17:22 mjpg_streamer.c
-rw-r--r-- 1 pi pi 3617 Jan 10 17:22 mjpg_streamer.h
-rw-r--r-- 1 pi pi 9800 Jan 10 17:24 mjpg_streamer.o
-rwxr-xr-x 1 pi pi 20284 Jan 10 17:24 output_file.so
-rwxr-xr-x 1 pi pi 32436 Jan 10 17:24 output_http.so
-rwxr-xr-x 1 pi pi 14891 Jan 10 17:24 output_udp.so
drwxr-xr-x 13 pi pi 4096 Jan 10 17:22 plugins
-rw-r--r-- 1 pi pi 2631 Jan 10 17:22 README
drwxr-xr-x 2 pi pi 4096 Jan 10 17:22 scripts
-rwxr-xr-x 1 pi pi 4630 Jan 10 17:22 start.sh
-rw-r--r-- 1 pi pi 285 Jan 10 17:22 TODO
-rw-r--r-- 1 pi pi 2866 Jan 10 17:22 utils.c
-rw-r--r-- 1 pi pi 2399 Jan 10 17:22 utils.h
-rw-r--r-- 1 pi pi 1804 Jan 10 17:24 utils.o
drwxr-xr-x 2 pi pi 4096 Jan 10 17:22 www
$ LD_LIBRARY_PATH=./ ./mjpg_streamer -i "input_file.so -h"
Help for input plugin..: FILE input plugin
The following parameters can be passed to this plugin:
[-d | --delay ]........: delay to pause between frames
[-f | --folder ].......: folder to watch for new JPEG files
[-r | --remove ].......: remove/delete JPEG file after reading
[-n | --name ].........: ignore changes unless filename matches
$ LD_LIBRARY_PATH=./ ./mjpg_streamer -o "output_http.so -h"
Help for output plugin..: HTTP output plugin
[-w | --www ]...........: folder that contains webpages in
flat hierarchy (no subfolders)
[-p | --port ]..........: TCP port for this HTTP server
[-c | --credentials ]...: ask for "username:password" on connect
[-n | --nocommands ]....: disable execution of commands
$ cat ./start1.sh
export LD_LIBRARY_PATH=./
./mjpg_streamer -i "input_file.so -f /mnt/RAMDisk/ -n thermal.jpg" -o "output_http.so -p 8080 -w /usr/local/www" &
./mjpg_streamer -i "input_file.so -d 250 -f /mnt/RAMDisk/ -n real.jpg" -o "output_http.so -p 8081 -w /usr/local/www"
$ ./start1.sh
i: folder to watch...: /mnt/RAMDisk/
i: forced delay......: 250
i: delete file.......: no, do not delete
i: filename must be..: real.jpg
o: HTTP TCP port.....: 8081
i: forced delay......: 0
i: filename must be..: thermal.jpg
http://192.168.1.70:8080
http://192.168.1.70:8081
http://192.168.1.70:8080/?action=stream
http://192.168.1.70:8081/?action=stream
$ cat /var/www/index.html
<!DOCTYPE html>
<html>
<head>
<style type="text/css">
body {
text-align:center;
background-color:#000000;
.container {
width:100%;
.motion1 {
border: 0;
width: 40%;
height: auto;
.motion2 {
border: 0;
width: 40%;
height: auto;
.clear {
clear:both;
</style>
</head>
<body>
<a href="http://192.168.1.70:8080"><img class="motion1" src="http://192.168.1.70:8080/?action=stream" /></a>
<a href="http://192.168.1.70:8081"><img class="motion2" src="http://192.168.1.70:8081/?action=stream" /></a>
</body>
</html>
http://192.168.1.70
I'd much rather a userland solution.
// freeze thermal image if "shutterState"="FFC"
if (strncmp (&buf85[28+ThermalSize+JpgSize+17],"FFC",3)!=0)
$ sudo ./flir8k
: Sun Jan 10 14:57:54 2016
>>>>>>>>>>>>>>>>>bulk transfer (in) 0x81:-1 LIBUSB_ERROR_IO
EP 0x83 LIBUSB_ERROR_NO_DEVICE -> reset USB
Write successful!
Write successful!
Write successful!
flir8i2.c (see attachment) writes all jpg frames for /dev/video2 and /dev/video3 to file
But still mjpg_streamer has the same problem with the mjpeg stream 160x120.Code: [Select]$ export LD_LIBRARY_PATH=/usr/local/lib
Aborted
Is 160x120 to small for mjpg_streamer?
#define VIDEO_DEVICE2 "/dev/video3" // colorized thermal image
#define FRAME_WIDTH2 320
#define FRAME_HEIGHT2 240
// write frame as jpg to fdwr2
int image_width=160; /* Number of columns in image */
int image_height=120; /* Number of rows in image */
int quality=90;
./mjpg_streamer -i "./input_uvc.so -d /dev/video2" -o "./output_http.so -p 8080 -w /usr/local/www" &
./mjpg_streamer -i "./input_uvc.so -d /dev/video3" -o "./output_http.so -p 8081 -w /usr/local/www"
Trying to get a new kernel built for my pcduino, and having some toolchain problems.
I also have 2 RPi model B boards which I got in the early days of the RPi.
IMHO their USB core in the SOC stinks. Their USB power system on the board stinks.
This may have improved a bit in later versions RPi2.
I found a nice workaround for mjpg_streamer with the v4l2 input modul and 160x120 frame size.
only enlarge the initialisation frame size of the v4l2 device from 160x120 to:Code: [Select]#define VIDEO_DEVICE2 "/dev/video3" // colorized thermal image
$ make
gcc -I/usr/include/libusb-1.0 -c -o flir8l.o flir8l.c
gcc -I/usr/include/libusb-1.0 -o flir8l Palettes.o flir8l.o -lusb-1.0 -ljpeg -lm -Wall
$ sudo ./flir8l
using output device: /dev/video1
vid_format->type =2
vid_format->fmt.pix.width =160
vid_format->fmt.pix.height =120
vid_format->fmt.pix.pixelformat =1497715271
vid_format->fmt.pix.sizeimage =20480
vid_format->fmt.pix.field =1
vid_format->fmt.pix.bytesperline=160
vid_format->fmt.pix.colorspace =8
using output device: /dev/video2
vid_format->type =2
vid_format->fmt.pix.width =640
vid_format->fmt.pix.height =480
vid_format->fmt.pix.pixelformat =1196444237
vid_format->fmt.pix.sizeimage =1228800
vid_format->fmt.pix.bytesperline=0
using output device: /dev/video3
vid_format->type =2
vid_format->fmt.pix.width =320
vid_format->fmt.pix.height =240
vid_format->fmt.pix.sizeimage =307200
~/MJPG-Streamer/test/mjpg-streamer/mjpg-streamer $ cat ./start1.sh
./mjpg_streamer -i "./input_uvc.so -d /dev/video2" -o "./output_http.so -p 8080 -w /usr/local/www"&
~/MJPG-Streamer/test/mjpg-streamer/mjpg-streamer $ ls
CHANGELOG input_testpicture.so LICENSE mjpg_streamer mjpg_streamer.h output_file.so output_udp.so README start1.sh TODO utils.h www
input_file.so input_uvc.so Makefile mjpg_streamer.c mjpg_streamer.o output_http.so plugins scripts start.sh utils.c utils.o
~/MJPG-Streamer/test/mjpg-streamer/mjpg-streamer $ ./start1.sh
i: Using V4L2 device.: /dev/video2
i: The format asked unavailable, so the width 320 height 240
now we have two MJPEG live streams
see the two web front ends for informationsQuotehttp://192.168.1.70:8080
test it with VLC or mplayer etc.Code: [Select]http://192.168.1.70:8080/?action=stream
(7) a simple html web front end
create a index.html in your web folder /var/wwwCode: [Select]$ cat /var/www/index.html
<!DOCTYPE html>
<html>
<head>
body {
text-align:center;
.container {
width:100%;
.motion1 {
border: 0;
width: 40%;
height: auto;
.motion2 {
border: 0;
width: 40%;
height: auto;
.clear {
clear:both;
</style>
</head>
<body>
</body>
</html>
load the site:Code: [Select]http://192.168.1.70
Planck R1 : 16438.1
Planck B : 1416.5
Planck F : 1
Planck O : -1315
Planck R2 : 0.0123569
// -- define Flir calibration values ---------------
// exiftool -plan* FLIROne-2015-11-30-17-26-48+0100.jpg
#define PlanckR1 16438.1
#define PlanckB 1416.5
#define PlanckF 1.0
#define PlanckO -1315.0
#define PlanckR2 0.0123569
please note that I wrote always a decimal point, to avoid some unwanted integer castings in cdouble raw2temperature(unsigned short RAW)
// mystery correction factor
RAW *=4;
// calc amount of radiance of reflected objects ( Emissivity < 1 )
double RAWrefl=PlanckR1/(PlanckR2*(exp(PlanckB/(TempReflected+273.15))-PlanckF))-PlanckO;
// get displayed object temp max/min
double RAWobj=(RAW-(1-Emissivity)*RAWrefl)/Emissivity;
// calc object temperature
return PlanckB/log(PlanckR1/(PlanckR2*(RAWobj+PlanckO))+PlanckF)-273.15;
than you can write a smaller jpeg of 160x120 to VIDEO_DEVICE2
// unload
$ sudo modprobe -r v4l2loopback
// load
$ sudo modprobe v4l2loopback devices=5
#define FRAME_WIDTH2 160 //320
#define FRAME_HEIGHT2 128 //240
#00007305 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508916.42668,"usbEnqueuedTimestamp":1177508916.4285,"ffcState":"FFC_VALID_RAD"}
#00007306 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508916.5428,"usbEnqueuedTimestamp":1177508916.54466,"ffcState":"FFC_VALID_RAD"}
#00007307 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508916.65624,"usbEnqueuedTimestamp":1177508916.65782,"ffcState":"FFC_VALID_RAD"}
#00007308 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508916.76904,"usbEnqueuedTimestamp":1177508916.77088,"ffcState":"FFC_VALID_RAD"}
#00007309 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508916.88276,"usbEnqueuedTimestamp":1177508916.88477,"ffcState":"FFC_VALID_RAD"}
#00007310 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508916.99627,"usbEnqueuedTimestamp":1177508916.99783,"ffcState":"FFC_VALID_RAD"}
#00007311 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508917.11095,"usbEnqueuedTimestamp":1177508917.11306,"ffcState":"FFC_VALID_RAD"}
#00007312 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508917.22461,"usbEnqueuedTimestamp":1177508917.22623,"ffcState":"FFC_VALID_RAD"}
#00007313 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508917.34107,"usbEnqueuedTimestamp":1177508917.3429,"ffcState":"FFC_VALID_RAD"}
#00007314 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508917.4537,"usbEnqueuedTimestamp":1177508917.45972,"ffcState":"FFC_VALID_RAD"}
#00007315 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508917.56661,"usbEnqueuedTimestamp":1177508917.56837,"ffcState":"FFC_VALID_RAD"}
#00007316 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508917.68063,"usbEnqueuedTimestamp":1177508917.6869,"ffcState":"FFC_VALID_RAD"}
#00007317 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508917.79463,"usbEnqueuedTimestamp":1177508917.79671,"ffcState":"FFC_VALID_RAD"}
#00007318 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508917.91498,"usbEnqueuedTimestamp":1177508917.91678,"ffcState":"FFC_VALID_RAD"}
#00007319 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508918.0219,"usbEnqueuedTimestamp":1177508918.02369,"ffcState":"FFC_VALID_RAD"}
#00007320 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508918.13852,"usbEnqueuedTimestamp":1177508918.14039,"ffcState":"FFC_VALID_RAD"}
#00007321 81/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508918.25196,"usbEnqueuedTimestamp":1177508918.25356,"ffcState":"FFC_VALID_RAD"}
#00007322 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508918.36496,"usbEnqueuedTimestamp":1177508918.3667,"ffcState":"FFC_VALID_RAD"}
#00007323 81/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508918.4781,"usbEnqueuedTimestamp":1177508918.48,"ffcState":"FFC_VALID_RAD"}
#00007324 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508918.59206,"usbEnqueuedTimestamp":1177508918.59365,"ffcState":"FFC_VALID_RAD"}
#00007325 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508918.70655,"usbEnqueuedTimestamp":1177508918.70863,"ffcState":"FFC_VALID_RAD"}
#00007326 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508918.82,"usbEnqueuedTimestamp":1177508918.82159,"ffcState":"FFC_VALID_RAD"}
#00007327 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508918.93411,"usbEnqueuedTimestamp":1177508918.93615,"ffcState":"FFC_VALID_RAD"}
#00007328 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508919.04937,"usbEnqueuedTimestamp":1177508919.05093,"ffcState":"FFC_VALID_RAD"}
#00007329 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508919.16221,"usbEnqueuedTimestamp":1177508919.16431,"ffcState":"FFC_VALID_RAD"}
#00007330 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508919.27651,"usbEnqueuedTimestamp":1177508919.28135,"ffcState":"FFC_VALID_RAD"}
#00007331 81/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508919.38965,"usbEnqueuedTimestamp":1177508919.39117,"ffcState":"FFC_VALID_RAD"}
#00007332 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508919.50482,"usbEnqueuedTimestamp":1177508919.50864,"ffcState":"FFC_VALID_RAD"}
#00007333 81/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508919.61759,"usbEnqueuedTimestamp":1177508919.61911,"ffcState":"FFC_VALID_RAD"}
#00007334 81/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508919.73212,"usbEnqueuedTimestamp":1177508919.73392,"ffcState":"FFC_VALID_RAD"}
#00007335 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508919.8459,"usbEnqueuedTimestamp":1177508919.84773,"ffcState":"FFC_VALID_RAD"}
#00007336 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508919.96018,"usbEnqueuedTimestamp":1177508919.96197,"ffcState":"FFC_VALID_RAD"}
#00007337 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508920.07373,"usbEnqueuedTimestamp":1177508920.07574,"ffcState":"FFC_VALID_RAD"}
#00007338 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508920.18741,"usbEnqueuedTimestamp":1177508920.18898,"ffcState":"FFC_VALID_RAD"}
#00007339 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508920.30213,"usbEnqueuedTimestamp":1177508920.30423,"ffcState":"FFC_VALID_RAD"}
#00007340 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508920.41558,"usbEnqueuedTimestamp":1177508920.41705,"ffcState":"FFC_VALID_RAD"}
#00007341 80/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508920.52954,"usbEnqueuedTimestamp":1177508920.53154,"ffcState":"FFC_VALID_RAD"}
#00007342 79/10 fps:{"shutterState":"ON","shutterTemperature":310.799987792969,"usbNotifiedTimestamp":1177508920.64426,"usbEnqueuedTimestamp":1177508920.6458,"ffcState":"FFC_VALID_RAD"}
RAW *=4;
// convert sample frame 00051 from SDK
> convert -depth 16 -size 164x120 gray:00051-lep gray:- | convert -depth 16 -endian lsb -size 164x120 gray:- -chop 2x0+0+0 -chop 2x0+80+0 -rotate 90 00051-lep.png
// multiply with factor 4
// get channel statistics
Channel statistics:
Pixels: 19200
Gray:
min: 14220 (0.216983)
max: 20840 (0.317998)
mean: 15014.9 (0.229113)
standard deviation: 1218.95 (0.0186)
kurtosis: 5.54453
skewness: 2.30479
// extract RawThermalImage from a Flir radiometric image
> exiftool -b -RawThermalImage FLIROne-2016-01-18-10-33-07+0100.jpg > 00051exif.png
// image is postprocessed and resized to 320x240
Channel statistics:
Pixels: 19200
Gray:
min: 14266 (0.217685)
max: 20831 (0.317861)
mean: 15021.4 (0.229212)
standard deviation: 1221.27 (0.0186354)
kurtosis: 5.44004
skewness: 2.28451
here is a real live sample from Flir One G2 (shot after a small warm up time of about 2 minutes):
I saved with the SDK.app simultaneously a upscaled Flir Radiometric JPG and a real Lepton ThermalLinearFlux14BitImage.
Afterwards I rebuild with my old panorama script (see my footer) a real size 160x120 Lepton radiometric jpg (a Flir format).
You can load this sample jpg images in Flir Tools and compare the quality.
First a original image shot with the Flir App.
The App cropthe Lepton sensor to about 120x90 Pixel.
Please note the artefacts/patterns!
Flir makes a nice lens distortion correction of the Lepton sensor for best MSX overlaying
real Lepton sensor 160x120 (no image postprocessing and with noise/grain because the temperature spread is only 4 Kelvin)
