Hi guys!
Firs I would like to congratulate everyone that helped on this post. That's an amazing initiative and you are awesome!
I'm would like to know if someone could get the Flir One Pro LT version working with Linux.
I'm trying to use the Pro LT with an raspberry Pi 4 but i'm having some issues. Here is some comments about:
1 - The Pro LT didnt work with the V4L on RPI4 but I could workaround using the MJPEG Streamer as suggested by @thomas123 before
2 - The normal camera (real.jpg) is working fine, but I cant get the image from the thermal camera (thermal.jpg). I get the same issues that some guys replied here before, an image with some colored glitches:
![Question about FLIR One for Android 1003793-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=56224.0;attach=1007778;image)
(obs. I've covered the thermal camera with my fingers and noticed some changes on the glitches patterns, so probably the image is being received but need to be correctly decoded)
3 - I've tried to change the the references for resolution on the source code from 160x120 to 80x60 but still getting the same issue.
I've saw that @aund could put the Pro LT version to work, but I cant do the same here.
Is there any other changes that I should do beyond the resolution?
Please, someone could help me?
Thank you in advance!
