does anyone have experience what can be used as a FIR-window to seal the housing of a contactless thermometer?
Following project: A friend asked me if I can build him a thermometer that displays the surface temperature of the tires of his race car. A GY-906 BCC from Melexis seems to be the perfect choice, it´s small enough for the wheel housing, it has an appropriate detection angle and black rubber should usually be very well suited for pyrometry.
The main issue is: Even if the sensor does not need to function if it´s wet, it should survive the conditions next to the wheel. I definitely need some window to protect it.
I had the following ideas:
- Thin PE window: Cheap and easy to replace, but not very transmissive and very prone to dirt.
- ZnSe-window: Highly transmissive, but more expensive and very easy to scratch
- Ge-window: Much to expensive, also easy to scratch
- "Periscope" of two gold coated glasses: No hermetic seal, but easy to replace
Do you know any other promising material or setup?
