Author Topic: Leupold tracker HD  (Read 1215 times)
Offline h33tTopic starter
Leupold tracker HD
« on: May 05, 2019, 04:48:08 pm »
Anyone have one of these?  Looks pretty neat, but I'm wondering if the screen will look too small since it doesn't go right up to the eye?  To add to that issue, I'm slightly farsighted, and it seems I can only focus on things that are about 12-13" from my eye.  So just wondering how well this will work if I need to hold it a foot away from my face.
Offline Vipitis
  • aspiring thermal photography enthusiast
Re: Leupold tracker HD
« Reply #1 on: May 05, 2019, 05:18:26 pm »
It's more of a look good product using the low end core from Raytheon that also Seek uses. Depending on your application - which I guess would be outdoor observation - you should look into other cheap monoculars, which have an eyepiece and do QVG at 30hz for a competitive price.
« Reply #2 on: May 05, 2019, 09:34:28 pm »
Thanks for the advice  8)
Offline yertle
« Reply #3 on: May 06, 2019, 10:48:26 pm »
I naturally hold the HD about a foot from my eye, so I don't think that will be an issue. The screen is a decent size and high resolution.
« Reply #4 on: May 12, 2019, 03:17:17 am »
Almost pulled the trigger on one of these, but then saw they use regular batteries.  Most of the other units just plug in and recharge.
