Author Topic: Firmware issue on UNI-T UTi260B  (Read 2864 times)
Offline Mike1983Topic starter
« on: September 13, 2023, 08:58:38 am »
Hello everyone,
yesterday I installed a firmware update on my UNI-T UTi260B.
Unfortunately, it now gets stuck at 100% during startup.
In the console, I receive the following message about every second:
imageListUpdate()
Cannot find the director
Regrettably, I don't have a backup of the original firmware.
That's why I'm reaching out to ask if you could send me your backups or firmware.
I would try them out in the hope that one of them works. Thank you in advance.
Best regards from Germany
Mike
Offline Veteran68
Re: Firmware issue on UNI-T UTi260B
« Reply #1 on: September 13, 2023, 06:00:57 pm »
One of several threads here in the forum with this issue:
https://www.eevblog.com/forum/thermal-imaging/uti260b-uti690b-firmware-backup-script
Several people have uploaded their firmware. You want to be sure you match the major version of your original firmware. This is usually a soft "bricking" caused by installing the wrong firmware version. For example, installing v2.x firmware on a v.1x device. This isn't officially documented and even Banggood provided an incorrect version that bricked my UTi690B (same as the 260B). Since you already have console access you just need to copy over the main firmware file back to your unit as described in those threads. Also the original splash screen image if you want it back.
The following users thanked this post: MHTSOS
« Reply #2 on: September 14, 2023, 03:00:44 pm »
Thanks!
I've found the needed version, my 260B is working again.
BR
Mike
Offline tunguyengevn
« Reply #3 on: August 09, 2024, 09:54:24 pm »
Hi.
Do u have uti 260B firmware ? and know how to upload to device?
Thanks.
« Reply #4 on: August 10, 2024, 01:04:27 pm »
I will check it today and provide you a download link.
Mike
« Reply #5 on: August 11, 2024, 11:47:20 am »
you can download the backup firmware from here: https://cloud.ordnung.family/s/kFG226Dy46TCy5m
BR
Michael
