Author Topic: Infiray/IRay/Xinfrared IR_Discovery Software  (Read 1730 times)
Offline zevTopic starter
« on: June 28, 2024, 06:20:58 pm »
Just as a heads up, Infiray have been deleting all reference to their IR Discovery software (which goes by many names, including TAS, Ruitan Thermography Analysis System, IR Discovery, Topdon TD View (this one has limited functions), IRPT_TAS (this was the older version, 2021 I think)).  The software used to be accessible under Support>Product Support Center, but they now only have manuals, no software. I have heard different from other folks, but I have not had good luck asking Infiray for downloads, so figured I would put up this post in hopes it helps some people.
Anyway, the archived version of their site still as of the time of this posting has an active link to the latest version:
Archived site link: https://web.archive.org/web/20240225151033/https://www.infiray.com/at1280-online-thermal-camera/
And link to the hosted software download: https://bj1894.apps.aliyunfile.com/disk/s/w7w1xjTwtVc
If it disappears from that link too and you are trying to use it, send me a dm.
The following users thanked this post: pinchies, basecase, Exosia, Phil1977
Offline pinchies
    • Thermal Camera Rental Melbourne
Re: Infiray/IRay/Xinfrared IR_Discovery Software
« Reply #1 on: July 02, 2024, 06:32:07 am »
Thanks for this post Zev.
I noticed the infiray site had gone down and grabbed the files from IA just the same as you did. Now the site is back online, I also noticed a lot of models and a lot of content has disappeared...
I'm very much not happy as the high-end Infiray model I have has been delisted which gives me concerns about support / firmware being unobtainium. Not good.  :--
I also have grabbed if anyone needs:
android_irpt_tas_V1.5.0_S_build_31.apk
P2pro windows.exe
Xtherm windows.exe
Offline basecase
« Reply #2 on: July 03, 2024, 06:01:33 am »
Thanks for the post as well.
What I got:
IR Discovery_V2.8.11(007).ABROAD_WIN64.exe
android_irpt_tas_V1.6.5_S_build_119.apk
Tianxuan M305&M600 User Manual V1.1.0
Tianxuan M305&M600 Technical Data V2.0.0
