VGN, you mentioned the difficulty of obtaining bias values for each pixel. Looking at your HDL sources, I now understand that a bias value is sent by FPGA to sensor, for each pixel? That is quite interesting- in that case, it seems to me that there is a significant manufacturing variation for each microbolometer (that is, even more significant than the usual non-uniformity which is handled by the NUC).
Can you share the bias values for your sensor? I wonder if there is any discernible pattern in the values.
Anyway, I'm especially curious about this, because I hooked my unit to a logic analyzer, and the FPGA doesn't seem to send any bias values at all. Consequently after the per-frame command packet, I see something that resembles one image line, and then only the preamble on the data lines from sensor. I wonder if it's a security feature (I've heard about lockdown mode if FPGA receives incorrect data on NV2), or my unit is somehow damaged. There does appear to be some activity on the SPI flash lines, but I'll probably try dumping it next.
Failing that, I wonder what is the way detectors are characterized at the factory. Maybe it's just as simple as as binary search on the bias value for each pixel that yields the most uniform output of the detector.
