Author Topic: SeekOFix - new windows software for SeekThermal  (Read 76241 times)
Offline ebclr
Offline eternalone
Re: SeekOFix - new windows software for SeekThermal
« Reply #51 on: June 25, 2016, 09:19:02 pm »
who me? yes...used on my windows 10 tablet with frenkys seek software.
A external calibration with something at ambient temperature gives me the best pic....usually a plastic material. Then ill do exposure on a not so warm object, usually on my shoe, and switch to manual exposure. depends on the heat source i want to find.
Offline eternalone
« Reply #52 on: June 25, 2016, 10:22:45 pm »
heres one the more crazy palletes i made for it...
can lights at gfs house seem to be lacking in insulation, as well as the top part of window. Theres a window ac cooling the lower part of image. Two cats and a wall outlet in the lower left corner.
Offline ebclr
« Reply #53 on: June 26, 2016, 06:26:26 am »
My is seek is the one with apple connector, Can "run this siftware with a "special wiring ?
Offline eternalone
« Reply #54 on: June 26, 2016, 04:05:45 pm »
ummmmmmm..dunno. maybe try to splice something together? The only apple product i own is an old ipod touch and i havent touched it in eons. Perhaps amazon has a wire that changes it to usb or micro usb.
Ill look after i do the days chores and report my findings. if you do get it working youll like this different software. really breathes some new life into a regular old seek. :popcorn:..lots of manual control over everything. :-DMM :-+
Offline eternalone
« Reply #55 on: June 26, 2016, 04:11:56 pm »
oh... i dont know if its because windows is 100x more powerful than android....but the framerate of my seek is outta this world now. no more jerky cars driving past or laggy movements when you pan around or choppy streaming....smooth as buttermilk.
Offline eternalone
« Reply #56 on: June 26, 2016, 04:40:30 pm »
I have an adapter that changes the seek micro usb to a full sized usb. Then that goes into an otg/charging hub. Then the hub goes into the tablets micro usb port.
Offline joe-c
    • Joe-c.de
« Reply #57 on: June 26, 2016, 07:02:01 pm »
Yes, but i don't know the wiring. but if you open the device, you can use the 5 Pin connector inside (2x GND) to solder USB directly.
i make this with android device and iOS device, and i cant see a difference on board level.
Only the Flex and connector is different, see X-Ray images:
https://www.eevblog.com/forum/thermal-imaging/freeware-software-for-thermal-analysis-thermovision_joec/msg949565/#msg949565
Freeware Thermal Analysis Software: ThermoVision_Joe-C
Some Thermal cameras: Kameras
Offline Trax
  • Country: at
« Reply #58 on: December 07, 2016, 07:36:27 am »
is anyone still working on this software?
does it support the new seek compact ff model as well?
Offline frenkyTopic starter
  • Country: si
    • Frenki.net
« Reply #59 on: December 07, 2016, 08:16:08 am »
I stopped the development of SeekOFix because my SeekThermal module died...
I've put code on github: https://github.com/frenkinet/SeekOFix
If anyone wants to continue developing new features I will be more than happy. :D
P.S.
joe-c is still developing for SeekThemal modules. And his app has a lot more features:
« Last Edit: December 07, 2016, 08:44:40 am by frenky »
Offline Uho
  • Country: ua
« Reply #60 on: December 13, 2016, 07:12:13 pm »
Hi. You know what is broken in the module? I have a little experience repair module. I have twice had a failure of the module. Changed optics. Changed the processor. Changed the security chip USB
Offline KrisMcLean
« Reply #61 on: November 04, 2017, 12:51:28 pm »
Trying to get the windows .exe software from April to run. It crashes complaining about a missing system.io file. Compiling C is beyond my pay grade so grateful if someone has any clues?
  • Country: si
    • Frenki.net
« Reply #62 on: November 05, 2017, 09:17:12 am »
Do you have .net framework installed?
Compiling it from source is really easy. Install VS Community edition: https://www.visualstudio.com/vs/community/
Download all the code: https://github.com/frenkinet/SeekOFix
Open file SeekOFix.sln and click Run button in top toolbar.
Offline scelestus13
« Reply #63 on: February 20, 2018, 07:49:27 am »
This software has been absolutely invaluable to me! Thank you so much for putting this together! One question I have; the arrays are 32448 long; this doesn't really make sense to me. Is there checksum somewhere making it greater than 206 X 156? Where is this? Ultimately, I'm trying to make a graph showing the average of each column so I need to figure out what part(s) of the array to cut out!
  • Country: si
    • Frenki.net
« Reply #64 on: February 20, 2018, 08:19:08 am »
Tnx. :)
Sensor is outputting 208x156 data. But last two columns are not thermal image data.
(Not sure if we have found out what is in last two columns.)
The following users thanked this post: scelestus13
Offline berider
  • Country: cn
« Reply #65 on: April 10, 2018, 03:57:31 pm »
Can SeekOFix be used on Seek CompactPRO?
Offline berider
  • Country: cn
« Reply #66 on: April 11, 2018, 12:47:33 pm »
cannot find the driver for seek, how to do ?
  • Country: si
    • Frenki.net
« Reply #67 on: April 11, 2018, 01:14:05 pm »
It probubly does not work with Pro version because of different resolution.
Use Zadig to install the winusb driver on the "iAP Interface" device that enumerates when you plug it in.
http://zadig.akeo.ie/
The following users thanked this post: berider
Offline djdblaster
« Reply #68 on: December 24, 2018, 10:22:09 am »
Hello,
I'd like to connect Seek Compact Pro to PC. Got the USB cable, connected through one of the ports on the back and PC says I need more power out of the USB to drive the camera. I don't have a motherboard with an extra power USB slot.
But all in all, is it possible to make this camera work with PC?
Offline 7gone
  • Country: lt
« Reply #69 on: January 17, 2019, 07:01:31 pm »
Yes I want it to to connect Seek Compact Pro to pc:) someone knows how?
Offline cq-317
  • Country: cn
« Reply #70 on: February 07, 2019, 02:58:54 am »
The effect is awesome and the image is enhanced?
Offline msalgado
  • Country: pe
« Reply #71 on: October 12, 2020, 10:21:39 pm »
Yes, I bought a 5 mt usb cable with power supply and I managed to connect the camera, what I can't do is make it work with the new Seek CompactPro using SeekoFix, did someone update the code?
Thanks
  • Country: si
    • Frenki.net
« Reply #72 on: October 13, 2020, 06:56:04 am »
I haven't because I don't have it. ( And after I got ThermalExpert Q1 I never wanted to see Seeks noise again... :P )
