As found on ebay, there is old stock of a product that was sold on german ALDI and Otto which is supposedly a Thermal camera for inspecting buildings.
eBay auction: #225083807494it doesnt feature a recording function, nor any temperature readout.
there was a listing for one where the seller wasnt sure if its broken or not, for half the price. so i bought it.
apparently (some said, it might be fake) it uses a 384x288 sensor running at 50hz, 60mk sensitivity, 17µm.
Its fully made of aluminimum, every part inside even the cage housing the Core pcb's. just like most chinese flashlights nowadays.
just the screen protector is made of plastic and glued in. rest is easily accessible and screwed in. everything is plugged, no soldering.
oh yea, about the core. User "Vipitis" wrote its a french core, either ULIS or Lynred. the writing on the front-pcb gave it away,
its a
ULIS / Lynred Pico384 Gen2 in some sort of oem module with a bunch of connections and everything on board.
any documentation about this would really help turning this into something useable. i hope theres some sort of communication interface available to the outside.
https://lynred.com/sites/default/files/2019-10/Pico-384Gen2-datasheet.pdfhttp://www.tecotec.com.vn/en/uncooled-thermal-imaging-sensor/pico384-gen2-qgva.htmlits missing a calibration shutter, maybe thats why there is no temp-readout.
the core's output (analog video composite signal) goes straight to a cheap monitor found in 99% of rear-driving camera kits, but fully housed in Al case.
it has a 3 element germanium or silicon adjustable focus lens, but its quite zoomed it. 19mm at full frame, not at this sensor size apparently.
i also havent found a way to get it out. the lens somehow has to come off.
also it has a quite shallow depth of field. f1.0 it says on the listing.
its useable for pcb fault finding, but when working over head, you might wanna detach the monitor.
min focal distance was about 20..25cm.
the display cable gets bend pretty badly, some wires got fixed in the past and one had open insulation. when it touches the case, it shorts to ground. maybe this is why it was sold as defective.
its just carrying the button signals, video and vcc gnd.
for me it worked out of the box but still gonna fix these issues.
(that smell is gonna stay for a while..)
