I find the following fairly unique -- The use of "Rosebud" (Citizen Kane, "Sled") used to describe the FLIR G2 in the kernel boot log (thanks Mike for posting) is quite interesting. At frame 0:42 to 0:43 shows the same kernel load addresses, kernel version, load addresses, etc. JFFS2 kernel image sizes differ (firmware differences?). Also appears G2 no longer has dropbear SSHd running on init/boot (firmware differences?)
Interesting output around G1 and G2 with regard to inserting lepton.ko kernel module, would love to compare differences between the two. Equally interesting is G1 running an SSHd without an ethernet interface. Odd the G2 is reporting SPI and other verbose output not seen in G1. Again, suspect possible firmware differences?
Would love to have 'root' on the G1/G2 and start comparing the kernel modules, modinfo, etc. Very interested to hear about interpolation findings. Thanks all for the thread, very much appreciate the constant learning I have while reading these threads. All the best.
