Is anyone else fooling with the Lepton v3 module yet? I have already ripped apart my Flir One v2 to harvest the module. I have it on a breakout board interfaced to a raspberry pi. After some code mods I have it working but it acts a bit strangely compared to what I expected from reading the datasheet. Would be great to compare notes...
Obligatory 160x120 thermal selfie attached...
Hello Arsenix,
i also disassembled an Flir ONE (new Gen) and used this sensor.
But i use a standalone system with the AGC the Lepton provides with my own Color LUTs.
Attached are some Screenshots..
The Thermal Blob that the App creates are awful, but less noisier.
You can disable the MSX while you unplug the visible camera on the Board and there wouldnt be noise from the MSX camera.
But like i said, its just a better thermal blob what you will get.
The screenshots shows the Thermal image received from the lepton in AGC mode.
If you got some Questions about the code differences, just ask them.
Best regards
Pantheron
