Author Topic: New Flir products  (Read 230301 times)
Offline NathanFowler
Re: New Flir products
« Reply #350 on: September 08, 2015, 08:49:54 pm »
Wonder if it's possible to drop a Lepton 3 to replace the Lepton 2 on the F1 Rosebud sled.  I'd be curious to see if there's a software resolution restriction in place or if 160x120 would actually work out.  Call me crazy but I really like the sled since it's an integrated device allowing me to carry one unit as opposed to a dongle.  I only see the 80x60's on Digikey...
Offline cynfab
« Reply #351 on: September 08, 2015, 09:01:39 pm »
Mine just arrived!!
In the sealed box:
Quick start & warranty card
Thank You card from Bill Terrel
microUSB cable
Spacer
Case
Lanyard
Box has a "Made for iPod" sticker inside ( I guess they ran out of Android boxes)
As expected the app doesn't recognise  the camera when plugged in and turned on on my S4 mini.
It does however work ok on my Digiland $49US tablet. Updated the firmware and everything.
Frame rate on the preview is slow, but usable, will take a video & some snapshots soon...
Plugging it into my linux box lsusb -vv gives the following
Bus 002 Device 007: ID 09cb:1996
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x09cb
  idProduct          0x1996
  bcdDevice            1.08
  iManufacturer           1 FLIR Systems
  iProduct                2 FLIR ONE Camera
  iSerial                 3 FLIRONEF0xxxxxxxxx
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           96
    bNumInterfaces          3
    bConfigurationValue     3
    iConfiguration          4 SBIBDP Configuration
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    240
      bInterfaceProtocol      0
      iInterface              5 iAP Interface
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           0
      bInterfaceProtocol      1
      iInterface              6 com.flir.rosebud.fileio
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           0
      iInterface              7 com.flir.rosebud.frame
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           2
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x85  EP 5 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x06  EP 6 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
 It works about the same with my 2012 Nexus 7.
    ...ken...
« Last Edit: September 08, 2015, 09:48:03 pm by cynfab »
Offline marshallh
    • retroactive
« Reply #352 on: September 08, 2015, 11:27:46 pm »
Received, it's a letdown.
Image quality is comparable to the last one (i.e. blurfest). Can't turn off MSX, though the MSX is decent quality and adjustable. If you try to charge with anything besides a 1A charger, it actually slowly dies, presumably because the cpu running linux inside it draws more power than it can charge with.
Charged with my smartphone cable for an hour, now it will not boot under its own power.
Because of this it is not possible to upgrade the firmware.
At this point it seems the Seek is more useful and doesn't require a stupid charging system just to run its own linux-based glue logic.
Verilog tips
BGA soldering intro
Offline in.Vitro
« Reply #353 on: September 09, 2015, 12:28:12 am »
Is the Image quality that bad?
As you say, the first gen was very very blurry.. :/ but they said that it has 4 times the  resolution of the first generation  :-DD
maybe I wait a few years when the F1 has the same resolution as the Seek but its less nosier and has manual adjustible focus....for 250$    ;)
Offline marshallh
    • retroactive
« Reply #354 on: September 09, 2015, 12:45:19 am »
FLIR ONE V2 DISASSEMBLY
Use a plastic spudger to remove the halves, which are conjoined by 4 smalll pads of adhesive.
Lift up the battery connector to unplug it.
Combo LPDDR/NAND is the bga device with the serial QR code on it.
Unscrew 3 outer security torxes and lift the pcb directly straight out.
USB/Lightning pcb is a 4pin connector that plugs into a smd header.
Unclip 2 of the translucent white assembly from the pcb.
Lift vertically to remove assy and lepton from socket.
Verilog tips
BGA soldering intro
Offline Fraser
« Reply #355 on: September 09, 2015, 01:31:39 am »
I do not like the look of that screen connection mess on top of the USB plug !
I am starting to think FLIR could be playing games over the true resolution of the LEPTON 3. Having re visited all the FLIR blurb I get the definite feeling that they did not want to specify the physical pixel count. There is even comment in one pre release document saying that picture appearance is more important than resolution ! This almost appeared to say that the new LEPTON had better image manipulation 'magic'. I wonder if we are back to our old friend of cheap low resolution imaging chips. Namely interpolation.
I would comment further if I had a working unit but as mine was DoA I will have to wait to see the images on my phone.
I will do a side by side comparison of the ONE with two other 160*120 pixel cameras. If FLIR are not being totally honest about the 160*120 physical resolution I think we will spot it.
If this is smoke and mirrors marketing crap, my camera will be heading back to FLIR pronto. I still have the email confirming physical resolution as 160*120 from FLIR CS.
I should have stuck with professional thermal cameras. At least they have real specs and you can trust them !
Aurora
« Reply #356 on: September 09, 2015, 03:02:46 am »
I find the following fairly unique -- The use of "Rosebud" (Citizen Kane, "Sled") used to describe the FLIR G2 in the kernel boot log (thanks Mike for posting) is quite interesting.  At frame 0:42 to 0:43 shows the same kernel load addresses, kernel version, load addresses, etc.  JFFS2 kernel image sizes differ (firmware differences?).  Also appears G2 no longer has dropbear SSHd running on init/boot (firmware differences?)
Interesting output around G1 and G2 with regard to inserting lepton.ko kernel module, would love to compare differences between the two.  Equally interesting is G1 running an SSHd without an ethernet interface.  Odd the G2 is reporting SPI and other verbose output not seen in G1.  Again, suspect possible firmware differences?
Would love to have 'root' on the G1/G2 and start comparing the kernel modules, modinfo, etc.  Very interested to hear about interpolation findings.  Thanks all for the thread, very much appreciate the constant learning I have while reading these threads.  All the best.
« Reply #357 on: September 09, 2015, 03:39:58 am »
http://media.wix.com/ugd/53cdb6_9b698564a2e84af6a955078615b3a9da.pdf notates true 160x120 and a 17 to 12 micron pixel size reduction
Possibly useful
http://www.mako.co.kr/#!---/cyai
Offline marshallh
    • retroactive
« Reply #358 on: September 09, 2015, 04:32:56 am »
After putting it back together, it charges properly, and charge LED does not blink erratically. It seems the battery connector may have loosened to marginal contact during shipping.
Verilog tips
BGA soldering intro
Offline Fraser
« Reply #359 on: September 09, 2015, 04:49:22 am »
I wonder if that is what is wrong with mine. I get no life out of it at all. No LED, nothing.
It's going back to FLIR though so I am loathed to mess with it. A possible weak area in the design ?
At least if we see strange behaviour when charging it will be reasonably easy to open the unit to check that connector.
Aurora
Offline Fraser
« Reply #360 on: September 09, 2015, 05:02:41 am »
Maybe my X-Ray machine can see if the power connector is correctly mated in my unit. The problem will be seeing through or around the Battery. I'll take a look later.
Aurora
    • Mike's Electric Stuff
« Reply #361 on: September 09, 2015, 07:27:19 am »
..well if they don't want the old one back I'd be happy to take a look inside to confirm the physical pixel count  ;D
Day Job: Mostly LEDs
« Reply #362 on: September 09, 2015, 07:30:56 am »
Although I couldn't compare side to side I'd say it was better than the Seek, definitely less noise.
MSX is a big help to improve readability of image - there will be some filtering to scale up the IR image to the phone's screen resolution.
Offline tomas123
« Reply #363 on: September 09, 2015, 08:15:53 am »
BTW just for fun I used the UsbWebCamera App to connect my E4 ub UVC mode to the phone and it works just fine - framerate and lag are not much worse than on the E4's own screen!
Certainly do you know the thread "Flir Ex: Realtime raw radiometric data streaming via UVC  ;)
It's simple, to patch the libuvc library for android to get a E4 RAW stream
Unfortunately the Flir One G2 is not a UVC camera
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x09cb
  idProduct          0x1996
  bcdDevice            1.08
    bLength                 9
    bDescriptorType         2
    wTotalLength           96
    bNumInterfaces          3
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  Self Powered
filtered
>grep -i interface FlirOne.txt
    bNumInterfaces          3
      bInterfaceNumber        0
      bInterfaceNumber        1
      bInterfaceNumber        1
      bInterfaceNumber        2
      bInterfaceNumber        2
the seek camera has also a iAP Interface
The libseek library is using the first interface iAP Interface
https://github.com/zougloub/libseek
>grep -i interface seek.txt
    bNumInterfaces          2
      bInterfaceNumber        0
      iInterface              3 iAP Interface
      bInterfaceNumber        1
      iInterface              4 com.thermal.pir206.1
      bInterfaceNumber        1
compare with E4 UVC camera
check Flir E4 USB announcements
$ lsusb -v
Bus 001 Device 006: ID 09cb:1007
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2 ?
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x09cb
  idProduct          0x1007
  bcdDevice            0.00
  iManufacturer           7 FLIR Systems
  iProduct                8 FLIR Ex-Series
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength          241
    bNumInterfaces          3
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass         14 Video
      bFunctionSubClass       3 Video Interface Collection
      bFunctionProtocol       0
      iFunction              10 FLIR USB Video
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass        14 Video
      bInterfaceSubClass      1 Video Control
      iInterface              2 FLIR Ex-Series
      VideoControl Interface Descriptor:
        bLength                13
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdUVC               1.00
        wTotalLength           85
        dwClockFrequency        0.001000MHz
        bInCollection           1
        baInterfaceNr( 0)       1
        bLength                18
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             1
        wTerminalType      0x0201 Camera Sensor
        bAssocTerminal          0
        iTerminal               0
        wObjectiveFocalLengthMin      0
        wObjectiveFocalLengthMax      0
        wOcularFocalLength            0
        bControlSize                  3
        bmControls           0x00020260
          Focus (Absolute)
          Focus (Relative)
          Zoom (Absolute)
          Focus, Auto
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             3
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bSourceID               6
        iTerminal               0
        bLength                 7
        bDescriptorType        36
        bDescriptorSubtype      4 (SELECTOR_UNIT)
        bUnitID                 4
        bNrInPins               1
        baSource( 0)            1
        iSelector               0
        bLength                11
        bDescriptorType        36
        bDescriptorSubtype      5 (PROCESSING_UNIT)
      Warning: Descriptor too short
        bUnitID                 5
        bSourceID               4
        wMaxMultiplier          0
        bControlSize            2
        bmControls     0x00000217
          Brightness
          Contrast
          Hue
          Sharpness
          Gain
        iProcessing             0
        bmVideoStandards     0x1b
          None
          NTSC - 525/60
          SECAM - 625/50
          NTSC - 625/50
        bLength                27
        bDescriptorType        36
        bDescriptorSubtype      6 (EXTENSION_UNIT)
        bUnitID                 6
        guidExtensionCode         {d41f59fa-5094-463a-b3bb-e7858a831fa3}
        bNumControl             4
        bNrPins                 1
        baSourceID( 0)          5
        bControlSize            2
        bmControls( 0)       0x0f
        bmControls( 1)       0x00
        iExtension              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              16
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      2 Video Streaming
      iInterface              0
      VideoStreaming Interface Descriptor:
        bLength                            14
        bDescriptorType                    36
        bDescriptorSubtype                  1 (INPUT_HEADER)
        bNumFormats                         1
        wTotalLength                       79
        bEndPointAddress                  130
        bmInfo                              0
        bTerminalLink                       3
        bStillCaptureMethod                 0
        bTriggerSupport                     0
        bTriggerUsage                       0
        bControlSize                        1
        bmaControls( 0)                    27
        bLength                            27
        bDescriptorType                    36
        bDescriptorSubtype                  4 (FORMAT_UNCOMPRESSED)
        bFormatIndex                        1
        bNumFrameDescriptors                1
        guidFormat                            {59555932-0000-1000-8000-00aa00389b71}
        bBitsPerPixel                      16
        bDefaultFrameIndex                  1
        bAspectRatioX                       0
        bAspectRatioY                       0
        bmInterlaceFlags                 0x00
          Interlaced stream or variable: No
          Fields per frame: 2 fields
          Field 1 first: No
          Field pattern: Field 1 only
          bCopyProtect                      0
        bLength                            38
        bDescriptorType                    36
        bDescriptorSubtype                  5 (FRAME_UNCOMPRESSED)
        bFrameIndex                         1
        bmCapabilities                   0x03
          Still image supported
          Fixed frame-rate
        wWidth                            320
        wHeight                           240
        dwMinBitRate                   912384
        dwMaxBitRate                   912384
        dwMaxVideoFrameBufferSize      153600
        dwDefaultFrameInterval        2666664
        bFrameIntervalType                  3
        dwFrameInterval( 0)            666666
        dwFrameInterval( 1)           1333332
        dwFrameInterval( 2)           2666664
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         2 ?
  bMaxPacketSize0        64
Device Status:     0x0000
  (Bus Powered)
>grep -i interface E4.txt
    bNumInterfaces          3
      bFirstInterface         0
      bInterfaceCount         2
      bInterfaceNumber        0
        baInterfaceNr( 0)       1
      bInterfaceNumber        1
      iInterface              0
      bInterfaceNumber        2
      iInterface              0
« Last Edit: September 09, 2015, 09:05:01 am by tomas123 »
Offline encryptededdy
« Reply #364 on: September 09, 2015, 08:31:45 am »
Aurora
I think this is just the consequence of 12um pixels paired with that small lens.
The "picture appearance is more important than resolution" quote is probably aimed at people comparing the FLIR to the Seek thermal (since the Seek is still higher res but arguably worse picture)
Offline tomas123
« Reply #365 on: September 09, 2015, 08:40:02 am »
a resolution test with a heating wire will show the true resolution
one square = one sensor pixel of Flir Exx
the result is really sharp (thanks to good optics of the Flir Exx)
Wow
one square = one sensor pixel of Flir One G1 (80x60)
Well, the result is definite poorer, as the 80x60 crop of the Exx ...
I love the artefacts around the heating wire on the RAW image of the Flir One G1  :D
« Last Edit: September 09, 2015, 08:43:13 am by tomas123 »
Offline Fraser
« Reply #366 on: September 09, 2015, 12:26:57 pm »
Well the Faxitron is warming up and I will see is I can get any useful imaging of my units internal. The battery will be a PITA though.
Mike,
Sadly FLIR want the dead unit back. No surprises there. Any decent company will want to characterise production failures to avoid repetition. Pity though. I would have loved to keep it for the core alone. FLIR do not strike me as that generous though.
Aurora
Offline frenky
  • Country: si
    • Frenki.net
« Reply #367 on: September 09, 2015, 02:13:09 pm »
When you will make a comparison with other thermal cameras with similar resolution; please make some photos in the dark so that msx won't interfere.
Sent from my LG-D855 using Tapatalk
Offline Fraser
« Reply #368 on: September 09, 2015, 02:22:37 pm »
The issue wit taking pictures in the dark is the noise floor of the visible light camera. It may add noise to the image as the MSX algorithm searches for edges in the noise  ? I can certainly give it ago though.
Aurora
Offline frenky
  • Country: si
    • Frenki.net
« Reply #369 on: September 09, 2015, 02:25:23 pm »
It would be interesting to see the same scenes with and without light so we can see what happens with the details & noise...
Offline Fraser
« Reply #370 on: September 09, 2015, 02:44:35 pm »
I have tried to X-Ray my faulty FLIR ONE G2 to see if its power connector is correctly fitted. Sadly no dice, there was too much in the way obscuring the connector. Its going back to FLIR tomorrow anyway.
Images are here if anyone wishes to see them:
https://www.eevblog.com/forum/projects/the-x-ray-image-thread-by-aurora-various-electronics-via-x-ray-imaging/msg750572/#msg750572
Aurora
Offline mct75
« Reply #371 on: September 09, 2015, 04:30:14 pm »
Can MSX not be turned off?  It seems like more of an annoyance than anything else, because I would use a Flir One for macro-type imaging than anything else.
Offline in.Vitro
« Reply #372 on: September 09, 2015, 06:24:45 pm »
You can Stick "milky" tape in Front of the Camera
« Reply #373 on: September 09, 2015, 07:19:32 pm »
Yes - if you just blank it out, the camara turns up the gain & noise becomes annoying ( the software really should be able to sense that the light level is low and disable MSX).
Using translucent tape keeps the light level up while suppressing the edges
Offline Fraser
« Reply #374 on: September 09, 2015, 07:54:32 pm »
I have heard from Bill on another matter and have taken the opportunity to ask him about the apparent slow frame rate of the Android camera. I hope he may respond on this with news of whether they expect to improve the situation.
Aurora
