Useful information taken from the FAQ's that I will park here in case of use to anyone in the future......
Common external interface, Ethernet, relay, analog video, power etc
(1) Ethernet: 100/1000m is supported, which can transmit video stream and temperature stream. The video stream only displays the characteristic temperature, which cannot be used for temperature analysis. The temperature stream can display the global temperature, which can be used for temperature analysis. (2) Relay: one relay output is only used as a switch (no voltage output) to connect the acousmo-optic alarm device. When the monitoring target reaches the alarm temperature, the relay closes and emits an acousmo-optic alarm. (3) Analog video: No network is needed and the display can be directly connected. Only the infrared picture and characteristic temperature are displayed, not the temperature of each point. (4) Serial ports: supports RS485, can do simple configuration and control of equipment, such as switch palette, capture, video and other commands, and analog video, general industrial equipment, with more to stability requirement is higher, Ethernet has a time delay, industrial less, a serial port can be extended many devices (such as WiFi). (5) Power supply: support 9-15V power supply, generally use 12V power adapter, can be customized 5V.
Is there an interface for data access?
A Based on network SDK to control and access device data, the dual-lights thermal camera with cradle head provided by us supports dual-channel RTSP and infrared RTSP, including only infrared images. (no need to use SDK to access) infrared temperature data, including temperature and image. (Must be accessed using the SDK).
IP setting for direct connection between thermal camera and computer
A (1) Direct connection: After connecting the thermal imager with the computer, the IP of thermal camera should be found in the software selection tool of thermal camera, and then the IPV4 of the computer should be set as the IP of the same network segment with the thermal camera, but not repeated with the default IP address of the thermal camera. (2) Router: under the premise of ensuring that thermal camera, router and computer are in the same IP segment, or all three are dynamically allocated IP, they can be directly connected via wireless or wired channels.
What is the device port number?
A The network protocol provided by the device: ports are as follows Control port 55502 Temperature flow port 55503 Single frame temperature port 55505 Video streaming port 55506 Mixed flow port 55507 (card machine specific) RTSP port 554 #SDK is a device-side + client, 2-side structure. Our devices are not cloud devices. Its just a network device. # Device access issues across networks. There can be a server in the middle or a simple port mapping. Not supported by the SDK # Use device data and follow SDK documentation; You need to look at ports for external access.
Does the SDK support C# language?
A Support C# (Sharp), C++, C language, JAVA.
Fraser
